• Join
  • Sign In with my.TI Login
Texas Instruments
  • Products
  • Applications
  • Tools & Software
  • Support & Community
  • Sample & Buy
  • About TI
Sample & Purchase Cart Sample & Purchase Cart
  • Search
  • Advanced
TI E2E™ Community
  • Support Forums
  • Blogs
  • Groups
  • Videos
  • 简体中文
  • More ...
TI Home » TI E2E Community » Support Forums » Data Converters » Precision Data Converters » Precision Data Converters Forum » A question about DAC8734
Share
  • Forum
  • Files
  • E2E Wiki
Options
  • Subscribe via RSS
Check out
The Signal blog
  • $core_v2_blog.Current.Name
    Handy Gadgets and Resistor Divider Calculations
    Posted 4 days ago
    by Bruce Trump
    Handy gadgets make our engineering life easier—the little...
    Chopper Op Amps—are they really noisy?
    Posted 11 days ago
    by Bruce Trump
    Chopper op amps offer very low offset voltage and dramatically...
    Bypass Capacitors… yes, but why?
    Posted 24 days ago
    by Bruce Trump
    Everyone knows that op amps should have power supply bypass capacitors...
This question is answered
lie xia
Posted by lie xia
on Oct 22 2009 04:52 AM
Prodigy20 points
In my design,i use the DAC8734,now i met a problem that i cannot sure how can i write the data to Common Register,DAC input Register,Zero Register and Gain Register.As the datasheet says,if we want to fish a DA trasform from Channel A to Channel D,we must write all of the Registers once,as the Time Diagrams mode below.If the data of  input Register is variable,others are fixed ,may i write other Registers every time?
("DAC8734")
Report Abuse
  • Reply
You have posted to a forum that requires a moderator to approve posts before they are publicly available.
All Replies
  • Tony Calabria
    Posted by Tony Calabria
    on Oct 22 2009 13:42 PM
    Mastermind42750 points
    Lie Xia,
    From my understanding, you plan to use all of the channels on the DAC and need to set the registers accordingly. The easiest way to complete this task is to power up the device, then write what you would like to all the Zero Register-x and Gain Register-x.  Now you can set the command register as you would like. These 9 registers will remain fixed and will not change until you write to them again or power down the device.
    Now you can write to the DAC channels DAC-x. There are two ways to update your output. You can either tie /LDAC low and have each output update as soon as /CS returns high (Case 1 on page 9) or you can set /LDAC high, write to all four DACs individually and then pulse /LDAC low to update all four outputs at once (Case 2 on page 9). All of the registers in the DAC8734 will remain at the values you set them to until you write over them. Therefore, you do not need to write to the Command Register, Zero Register-x, or Gain Register-x each time you want to do a conversion.
    As you change the data of the input registers the outputs can be updated in the two ways described above.
    Tony Calabria
    Report Abuse
    • Reply
  • lie xia
    Posted by lie xia
    on Oct 22 2009 21:22 PM
    Prodigy20 points
    Another question,if I want to write Zero Register,this Register is 16 data bits ,but the SPI Shift Register is 24 data bits,does it mean every code must be  24 data bits,even the Zero Register or the Gain Register is 16 data bits?
    Report Abuse
    • Reply
  • Tony Calabria
    on Oct 23 2009 12:31 PM
    Verified Answer
    Verified by Tom Hendrick
    Use page 25 of the data sheet as a guide.
    The first 8 bits indicates if it is a read or write and what register you would like to communicate with.
    The next 7 bits are 'dont care' bits. Writing to them has no effect.
    The last 9 bits (Z8:Z0) are used to set the Zero Register.
    Tony Calabria
    Report Abuse
    • Reply
TI E2E™ Community
  • Support Forums
  • Blogs
  • Videos
  • Groups
  • Site Support & Feedback
  • Settings
TI E2E™ Community Groups
  • TI University Program
  • Make the Switch
  • Microcontroller Projects
  • Motor Drive & Control
Other Communities
  • Deyisupport
  • Designsomething.org
  • beagleboard.org
  • TI on Element 14
  • TI on TechXchangeSM
Other Technical & Support Resources
  • WEBENCH® Design Center
  • Product Information Centers
  • Technical Documents
  • TI Design Network
  • TI Technical Articles
  • TI Training
All content and materials on this site are provided "as is". TI and its respective suppliers and providers of content make no representations about the suitability of these materials for any purpose and disclaim all warranties and conditions with regard to these materials, including but not limited to all implied warranties and conditions of merchantability, fitness for a particular purpose, title and non-infringement of any third party intellectual property right. TI and its respective suppliers and providers of content make no representations about the suitability of these materials for any purpose and disclaim all warranties and conditions with respect to these materials. No license, either express or implied, by estoppel or otherwise, is granted by TI. Use of the information on this site may require a license from a third party, or a license from TI.
Content on this site may contain or be subject to specific guidelines or limitations on use. All postings and use of the content on this site are subject to the Terms of Use of the site; third parties using this content agree to abide by any limitations or guidelines and to comply with the Terms of Use of this site. TI, its suppliers and providers of content reserve the right to make corrections, deletions, modifications, enhancements, improvements and other changes to the content and materials, its products, programs and services at any time or to move or discontinue any content, products, programs, or services without notice.
Follow Us Texas Instruments on Facebook Texas Instruments on Twitter Texas Instruments on LinkedIn Texas Instruments on Google+
TI Worldwide | Contact Us | my.TI Login | Site Map | Corporate Citizenship | mobile m.ti.com (Mobile Version)
TI is a global semiconductor design and manufacturing company. Innovate with 100,000+ analog ICs and
embedded processors, along with software, tools and the industry’s largest sales/support staff.
© Copyright 1995-2013 Texas Instruments Incorporated. All rights reserved.
Trademarks | Privacy Policy | Terms of Use
