• Join
  • Sign In with my.TI Login
Texas Instruments
  • Products
  • Applications
  • Tools & Software
  • Support & Community
  • Sample & Buy
  • About TI
Sample & Purchase Cart Sample & Purchase Cart
  • Search
  • Advanced
TI E2E™ Community
  • Support Forums
  • Blogs
  • Groups
  • Videos
  • 简体中文
  • More ...
TI Home » TI E2E Community » Support Forums » Data Converters » Precision Data Converters » Precision Data Converters Forum » ads1258, If ADCINP < ADCINM
Share
  • Forum
  • Files
  • E2E Wiki
Options
  • Subscribe via RSS
Check out
The Signal blog
  • $core_v2_blog.Current.Name
    Grounding Principles
    Posted 9 hours ago
    by Bruce Trump
    In a previous blog on supply bypassing , I cautioned that poor...
    Handy Gadgets and Resistor Divider Calculations
    Posted 8 days ago
    by Bruce Trump
    Handy gadgets make our engineering life easier—the little...
    Chopper Op Amps—are they really noisy?
    Posted 15 days ago
    by Bruce Trump
    Chopper op amps offer very low offset voltage and dramatically...
This question is answered
Dmitron
Posted by Dmitron
on Apr 29 2009 12:14 PM
Prodigy105 points
ssory for full qustion, I'm not familiar with sigma-delta and differential-input ADC.
(Schematic on page 43 of ADS1258.pdf (SBAS297E–JUNE 2005–REVISED OCTOBER 2007) figure 67)
question: If ADCINP < ADCINN what code will I get? For example, ADCINP-ADCINN = -0.5(RefP-RefN) I will get 1xxxxxx code, and if ADCINP-ADCINN = 0.5(RefP-RefN) I will get 0xxxxx code?
Report Abuse
  • Reply
You have posted to a forum that requires a moderator to approve posts before they are publicly available.
All Replies
  • Dmitron
    Posted by Dmitron
    on Apr 29 2009 12:51 PM
    Prodigy105 points
    thanks to all, I found reply to my question on page 24.
    Next question: If I connect -2.5V analog supply to RefN  pin, will I have problems with noise in ADC results for unstable -2.5V. I guess -2.5V will be anstable due tu pulsed supply current of ADC.
    Report Abuse
    • Reply
  • Rick Downs - WEBENCH Design Center
    Posted by Rick Downs - WEBENCH Design Center
    on Apr 29 2009 18:52 PM
    Expert5510 points
    Yes, if your reference isn't stable, then you will see that reflected in the output code.
    If the problem is noise coming from the power supply itself, using a simple low-dropout regulator often gives good results along with adequate filtering of the reference input.
    Your question was about if the ADC itself would disturb the supply - perhaps, but with proper bypassing and layout this should not be a problem.
    Remember that the reference the ADC sees is the difference between VREFP and VREFN, so if VREFN goes up, and so does VREFP, then there will be no problem. This is why Figure 67 in the datasheet is done as it is - note that the REF3125 is referenced to the -2.5V.
    Report Abuse
    • Reply
  • Dmitron
    Posted by Dmitron
    on Apr 30 2009 04:54 AM
    Prodigy105 points
    (page 61 of ADS1258: The reference inputs should be driven by a low-impedance source. For rated performance, the reference should have 3uVRMS broadband noise.For references with higher noise, external filtering may be necessary)
    1) In most applications and evaluation boards we can see the reference buffered with Op.Amp. Is it necessary? Can I use a ADR444BRZ Reference with 10 uF (or 220 uF) capacitor without Op. Amp.?
    Will  ADR444BRZ  be stable with 220uF capasitor? (cant find such frase in ADR444BRZ pdf)
    3) If i want to have adc error 0.1% and referense 5V,  I can have  the amplitude of reference noise  5/0.001=5mV? (If the acuracy of reference = 0%, and ADC has no DNL and INL).
    Report Abuse
    • Reply
  • Dmitron
    Posted by Dmitron
    on Apr 30 2009 05:31 AM
    Prodigy105 points
    One more question: (page 17 ADS1258.pdf) Is the Modulator input sampling Rate = fCLK/2 ? So, at 16 MHz clk, I need to reduce adc input noise in 8Mhz, 16Mhz, 24Mhz,32 Mhz...
    Report Abuse
    • Reply
    on Apr 30 2009 07:41 AM
    Expert5510 points
    Buffering the reference is usually necessary on this device. The modulator runs nominally at 8MHz, which means that reference is pulling current every 125ns. A good size bulk capacitance can help, but the charge on it must be replenished quickly, so a fast op amp with low output impedance is necessary.
    I can't tell you much about the ADR444BRZ, you'll need to ask the manufacturer about that. Looking at the output impedance curve of that device's data sheet, I would say it probably would be quite high by the time you get to 8MHz, and so wouldn't be suitable by itself.
    Given the conditions you list (not considering INL/DNL and initial ref accuracy), then yes, your reference calculation is correct.
    Report Abuse
    • Reply
    on Apr 30 2009 07:44 AM
    Verified Answer
    Verified by Tom Hendrick
    Expert5510 points
    And yes, you are correct - the modulator would run at 8Mhz with a 16MHz clock, so you must prevent coupling noise it at 8MHz - usually a simple RC filter works fine, and make sure your layout doesn't do something like run the clock line under the analog input pins (I've seen it happen...)
    Report Abuse
    • Reply
TI E2E™ Community
  • Support Forums
  • Blogs
  • Videos
  • Groups
  • Site Support & Feedback
  • Settings
TI E2E™ Community Groups
  • TI University Program
  • Make the Switch
  • Microcontroller Projects
  • Motor Drive & Control
Other Communities
  • Deyisupport
  • Designsomething.org
  • beagleboard.org
  • TI on Element 14
  • TI on TechXchangeSM
Other Technical & Support Resources
  • WEBENCH® Design Center
  • Product Information Centers
  • Technical Documents
  • TI Design Network
  • TI Technical Articles
  • TI Training
All content and materials on this site are provided "as is". TI and its respective suppliers and providers of content make no representations about the suitability of these materials for any purpose and disclaim all warranties and conditions with regard to these materials, including but not limited to all implied warranties and conditions of merchantability, fitness for a particular purpose, title and non-infringement of any third party intellectual property right. TI and its respective suppliers and providers of content make no representations about the suitability of these materials for any purpose and disclaim all warranties and conditions with respect to these materials. No license, either express or implied, by estoppel or otherwise, is granted by TI. Use of the information on this site may require a license from a third party, or a license from TI.
Content on this site may contain or be subject to specific guidelines or limitations on use. All postings and use of the content on this site are subject to the Terms of Use of the site; third parties using this content agree to abide by any limitations or guidelines and to comply with the Terms of Use of this site. TI, its suppliers and providers of content reserve the right to make corrections, deletions, modifications, enhancements, improvements and other changes to the content and materials, its products, programs and services at any time or to move or discontinue any content, products, programs, or services without notice.
Follow Us Texas Instruments on Facebook Texas Instruments on Twitter Texas Instruments on LinkedIn Texas Instruments on Google+
TI Worldwide | Contact Us | my.TI Login | Site Map | Corporate Citizenship | mobile m.ti.com (Mobile Version)
TI is a global semiconductor design and manufacturing company. Innovate with 100,000+ analog ICs and
embedded processors, along with software, tools and the industry’s largest sales/support staff.
© Copyright 1995-2013 Texas Instruments Incorporated. All rights reserved.
Trademarks | Privacy Policy | Terms of Use
