• Join
  • Sign In with my.TI Login
Texas Instruments
  • Products
  • Applications
  • Tools & Software
  • Support & Community
  • Sample & Buy
  • About TI
Sample & Purchase Cart Sample & Purchase Cart
  • Search
  • Advanced
TI E2E™ Community
  • Support Forums
  • Blogs
  • Groups
  • Videos
  • 简体中文
  • More ...
TI Home » TI E2E Community » Support Forums » Data Converters » Precision Data Converters » Precision Data Converters Forum » ADC buffer
Share
  • Forum
  • Files
  • E2E Wiki
Options
  • Subscribe via RSS
Check out
The Signal blog
  • $core_v2_blog.Current.Name
    Pop Quiz!
    Posted 1 day ago
    by Bruce Trump
    Put away your books and take out a sheet of paper. Each question...
    Settling Time
    Posted 7 days ago
    by Bruce Trump
    Settling time is the time required for an op amp to respond to...
    Slew Rate—the op amp speed limit
    Posted 15 days ago
    by Bruce Trump
    Slewing behavior of op amps is often misunderstood. It’s...
ADC buffer
ADC buffer
This question is answered
YILMAZ KIRÇİÇEK
Posted by YILMAZ KIRÇİÇEK
on Apr 13 2009 14:22 PM
Intellectual765 points
We are using TLV274 in split supply configuration for some requirements.
For ADC we need to use a buffer with TLV274.Our ADC works fine 0V to 5V (stands for -0.3Vto 5.3V)
I use precision rectifier circuit to protect ADC against negative input. But we experienced that it has some drawbacks.
Sampling is 100 ksps, not very fast but scanning 33 channels with switches. Last chance I have using a resistor and low Vf diode as BAS85 to clamp -320mV. This requires 4.7K resistor.
But it will add some mode error because of leakage and diode capacitance. Could you please give me an advise please ?
 Best regards.
Report Abuse
  • Reply
You have posted to a forum that requires a moderator to approve posts before they are publicly available.
All Replies
  • Miro Oljaca
    Posted by Miro Oljaca
    on Apr 08 2009 12:43 PM
    Intellectual2930 points
    Hi KIRÇİÇEK,
    Which ADC are you using and what is aquisition time?
    Miro
    Report Abuse
    • Reply
  • YILMAZ KIRÇİÇEK
    on Apr 08 2009 14:21 PM
    Hi Mr.Oljaca,
    Weare using microcontroller internal A/D and it has 1.4us aquisition time and conversion time is 8.4us
    I have to scan 33 channel within 1ms, so not reached the limit of ADC yet. (33ksps/100ksps)
    I have enough time to increase aquisition time a little bit more than min. specified.
    Thanks for your interest.
    More details : Under normal circiumtaces ADC and the buffer will not see any negative voltage.
    So when I by-passed precision rectifier and use a simple voltage follower result is quite satisfactory.
    Precision rectifier degrade the overal accuracy. In some extraordinary situation there can be negative
    inputs to any of my 32 apamp (8 pack). Instead of protectin all of them I preffered to protect only the
    ADC against to negative input.
    Report Abuse
    • Reply
  • Miro Oljaca
    on Apr 08 2009 14:39 PM
    Hi KIRÇİÇEK,
    Please can  you give me a part number of uC so I can look internal sructure of ADC?
    Miro
    Report Abuse
    • Reply
  • YILMAZ KIRÇİÇEK
    on Apr 09 2009 02:06 AM
    Good morning,
    The uC we used is PIC18F4620 and here is the internal structure.
    Report Abuse
    • Reply
  • Miro Oljaca
    on Apr 09 2009 18:41 PM
    Verified Answer
    Verified by nancy!
    I can see that absolute maximum ratings specify input voltage at 300mV over or under the rail. So VT=300mV.
    Also current into the pin must be limited to 20mA. If curent exide this value I am asuming (This is Microchip part) that input ESD structure can be damaged.
    If you know what is your maximum/minimum input voltage to the ADC, for example -10V you can calculate resistor that you will need to put between output of the opamp and input of ADC. 10V/20mA=500ohm. So this resistor with two diodes, one from GND to input and another one from input to Vcc will protect input of your ADC.
    If you send me the rest of your schematic I can take a look.
    Report Abuse
    • Reply
  • YILMAZ KIRÇİÇEK
    on Apr 10 2009 11:17 AM
    Good evening Sir,
    I can not able attach a schematic pdf file, could you please give me a e-mail address ?
    Regars.
    Report Abuse
    • Reply
  • Miro Oljaca
    moljaca@ti.com
    Report Abuse
    • Reply
TI E2E™ Community
  • Support Forums
  • Blogs
  • Videos
  • Groups
  • Site Support & Feedback
  • Settings
TI E2E™ Community Groups
  • TI University Program
  • Make the Switch
  • Microcontroller Projects
  • Motor Drive & Control
Other Communities
  • Deyisupport
  • Designsomething.org
  • beagleboard.org
  • TI on Element 14
  • TI on TechXchangeSM
Other Technical & Support Resources
  • WEBENCH® Design Center
  • Product Information Centers
  • Technical Documents
  • TI Design Network
  • TI Technical Articles
  • TI Training
All content and materials on this site are provided "as is". TI and its respective suppliers and providers of content make no representations about the suitability of these materials for any purpose and disclaim all warranties and conditions with regard to these materials, including but not limited to all implied warranties and conditions of merchantability, fitness for a particular purpose, title and non-infringement of any third party intellectual property right. TI and its respective suppliers and providers of content make no representations about the suitability of these materials for any purpose and disclaim all warranties and conditions with respect to these materials. No license, either express or implied, by estoppel or otherwise, is granted by TI. Use of the information on this site may require a license from a third party, or a license from TI.
Content on this site may contain or be subject to specific guidelines or limitations on use. All postings and use of the content on this site are subject to the Terms of Use of the site; third parties using this content agree to abide by any limitations or guidelines and to comply with the Terms of Use of this site. TI, its suppliers and providers of content reserve the right to make corrections, deletions, modifications, enhancements, improvements and other changes to the content and materials, its products, programs and services at any time or to move or discontinue any content, products, programs, or services without notice.
Follow Us Texas Instruments on Facebook Texas Instruments on Twitter Texas Instruments on LinkedIn Texas Instruments on Google+
TI Worldwide | Contact Us | my.TI Login | Site Map | Corporate Citizenship | mobile m.ti.com (Mobile Version)
TI is a global semiconductor design and manufacturing company. Innovate with 100,000+ analog ICs and
embedded processors, along with software, tools and the industry’s largest sales/support staff.
© Copyright 1995-2013 Texas Instruments Incorporated. All rights reserved.
Trademarks | Privacy Policy | Terms of Use
