• Join
  • Sign In with my.TI Login
Texas Instruments
  • Products
  • Applications
  • Tools & Software
  • Support & Community
  • Sample & Buy
  • About TI
Sample & Purchase Cart Sample & Purchase Cart
  • Search
  • Advanced
TI E2E™ Community
  • Support Forums
  • Blogs
  • Groups
  • Videos
  • 简体中文
  • More ...
TI Home » TI E2E Community » Support Forums » Data Converters » Precision Data Converters » Precision Data Converters Forum » ADS1256 + 6416T still can not work.
Share
  • Forum
  • Files
  • E2E Wiki
Options
  • Subscribe via RSS
Check out
The Signal blog
  • $core_v2_blog.Current.Name
    Handy Gadgets and Resistor Divider Calculations
    Posted 6 days ago
    by Bruce Trump
    Handy gadgets make our engineering life easier—the little...
    Chopper Op Amps—are they really noisy?
    Posted 13 days ago
    by Bruce Trump
    Chopper op amps offer very low offset voltage and dramatically...
    Bypass Capacitors… yes, but why?
    Posted 26 days ago
    by Bruce Trump
    Everyone knows that op amps should have power supply bypass capacitors...
This question is answered
Chun-ming Lo
Posted by Chun-ming Lo
on Mar 11 2009 19:03 PM
Prodigy100 points
Hi TI,
   After reconfigure my board, my program is still be blocked by the TTIDCSTATUS WaitDrdy(TADS1256 *pADS). It is the function call from the dc_configure() in my main.c.
   I am wondering What else I should do in addition to configuring DCP generator and modify the .cdb file by adding _DCPDISP_dispatchEdmaIsr? I mean, do I need to add any function to configure the External Interrupt #5 for ADC board or configure the timer?
   I wanna upload my project file to any TI engineers. Could any one give me your email, tonylou.tw@gmail.com.  Hope TI engineers can take a look on my program and test it. This simple program directly copied from the DCP tutorials is supposed to work.
   Thanks.
Following is the hardware setting and DCP software setting.
--- DCP Software Setting
Default Setting except one: I choose Intertupt as Ext Int 5.
Because the DC_INTb (5-6k) ---(Pin 48)--- DC_EINT5 (6416T)
--- Hardware Setting on the ADC board
Top position on the 5-6K Interface Board, which means connection with J16.
S1 ( AIN0-1 Input Select Switch ) -  Middle position of the switch, which makes AIN0 connected to +2.5V and AIN1 connected to Ground.
S2 ( AIN2-3 Input Select Switch ) -  Middle position of the switch, which makes AIN2 connected to +2.5V and AIN3 connected to Ground.
S3 ( Reference Input Select ) - Up position of the switch, which makes VRP connected to +2.5V and VRN connected to AGND.
S5 ( System Clock Select ) - Left position of the switch, which means digital power supply is onboard 7.68MHz crystal.
J4 - default setting - Short the pin #1 and the pin #2. Short the pin #3 and the pin #4.
J6 - SYNC'/PWDN' - Short SYNC'/PWDN' with DVDD
J7 - RESET - Short RESET' with DVDD
J8 - CS - Short CS with GND
J9 - default setting - Don't short any pins.
J10 - default setting - Short the pin #1 and the pin #2. Short the pin #3 and the pin #4. Short the pin #5 and the pin #6.
Chun-ming (Tony)
Report Abuse
  • Reply
You have posted to a forum that requires a moderator to approve posts before they are publicly available.
All Replies
  • Richard Oed
    Posted by Richard Oed
    on Mar 12 2009 08:57 AM
    Verified Answer
    Verified by Tom Hendrick
    Intellectual815 points
    Tony,
    The settings for the EVM are OK, but the interrupt used is interrupt EINT6. If you look at the schematic, EVM_INTb goes to W9 and has the signal name DC_INTc afterwards, which connects to pin 67 of the J19. Pin 67 is DC_EINT6 on the C6416 DSK.
    I'm going to send you an example project to your e-mail address, which should work for you. Please have a look at the main.c file, as the header describes the correct jumper settings on the 5-6K interface card as well.
    Richard
    Report Abuse
    • Reply
TI E2E™ Community
  • Support Forums
  • Blogs
  • Videos
  • Groups
  • Site Support & Feedback
  • Settings
TI E2E™ Community Groups
  • TI University Program
  • Make the Switch
  • Microcontroller Projects
  • Motor Drive & Control
Other Communities
  • Deyisupport
  • Designsomething.org
  • beagleboard.org
  • TI on Element 14
  • TI on TechXchangeSM
Other Technical & Support Resources
  • WEBENCH® Design Center
  • Product Information Centers
  • Technical Documents
  • TI Design Network
  • TI Technical Articles
  • TI Training
All content and materials on this site are provided "as is". TI and its respective suppliers and providers of content make no representations about the suitability of these materials for any purpose and disclaim all warranties and conditions with regard to these materials, including but not limited to all implied warranties and conditions of merchantability, fitness for a particular purpose, title and non-infringement of any third party intellectual property right. TI and its respective suppliers and providers of content make no representations about the suitability of these materials for any purpose and disclaim all warranties and conditions with respect to these materials. No license, either express or implied, by estoppel or otherwise, is granted by TI. Use of the information on this site may require a license from a third party, or a license from TI.
Content on this site may contain or be subject to specific guidelines or limitations on use. All postings and use of the content on this site are subject to the Terms of Use of the site; third parties using this content agree to abide by any limitations or guidelines and to comply with the Terms of Use of this site. TI, its suppliers and providers of content reserve the right to make corrections, deletions, modifications, enhancements, improvements and other changes to the content and materials, its products, programs and services at any time or to move or discontinue any content, products, programs, or services without notice.
Follow Us Texas Instruments on Facebook Texas Instruments on Twitter Texas Instruments on LinkedIn Texas Instruments on Google+
TI Worldwide | Contact Us | my.TI Login | Site Map | Corporate Citizenship | mobile m.ti.com (Mobile Version)
TI is a global semiconductor design and manufacturing company. Innovate with 100,000+ analog ICs and
embedded processors, along with software, tools and the industry’s largest sales/support staff.
© Copyright 1995-2013 Texas Instruments Incorporated. All rights reserved.
Trademarks | Privacy Policy | Terms of Use
