I want to making a project "ECG system design using Msp430 with ads1292" how i connect it.
Rakesh kumar
Hi Rakesh,
I think you will get better help on how to connect the ADS1292 if you post in the Precision Data Converters forum, so I have moved this thread there. You may also want to search that forum to see if someone has done something similar in the past: http://e2e.ti.com/support/data_converters/precision_data_converters/f/73.aspx
In addition, it looks like there is an eval board that connects the similar ADS1292R device with an MSP430: http://www.ti.com/tool/ads1292recg-fe That may be a good reference for you.
Katie
I have purchased ads1292 demokit & installed software on window 7 OS. After this I connect the Kit with mini usb cable for driver installing but according to manual 'found new hardware wizard' window will come, but not came here & in device manager, update driver automatically. but no install successfully show here.
I have purchased ads1292 demo kit. waveform are came on live ECG display window. how to save this ECG data about 2 or 3 minute for later analysis & how to browse this on this software.pl reply quickly.
rakesh
Hi Rakesh,
There is a limit on the number of points that the ADS1292 EVM can record and save. On each channel, you may collect up to 65,500 points. At 500SPS, this will give you 2:11 minutes worth of data.
To save the data, please refer to Section 4.1.3 of the User's Guide.
I have saved the data on saved tab but error occured. error window show- " error occured with error code-8. open/create/replace file in ADSx9xevm\saved\device_0_temp.xis". Pl suggest me how to saved. I want to save ecg data & later run on scope window. Pl reply quickly.
Hi Rakesh -
This is an issue that arose with Win7 that requires permission to change Program Files folder.
If you go to the root directory of the application (should be something like 'Program Files\ADS1x9xevm') and create a folder called "saved", this should resolve you problem. You will probably be required to have Admin access to create the folder and you may be prompted to elevate your user level before the folder is added.
