• Join
  • Sign In with my.TI Login
Texas Instruments
  • Products
  • Applications
  • Tools & Software
  • Support & Community
  • Sample & Buy
  • About TI
Sample & Purchase Cart Sample & Purchase Cart
  • Search
  • Advanced
TI E2E™ Community
  • Support Forums
  • Blogs
  • Groups
  • Videos
  • 简体中文
  • More ...
TI Home » TI E2E Community » Support Forums » Data Converters » Precision Data Converters » Precision Data Converters Forum » Seeking ADS1672EVM-PDK Firmware
Share
  • Forum
  • Files
  • E2E Wiki
Options
  • Subscribe via RSS
Check out
The Signal blog
  • $core_v2_blog.Current.Name
    Grounding Principles
    Posted 23 hours ago
    by Bruce Trump
    In a previous blog on supply bypassing , I cautioned that poor...
    Handy Gadgets and Resistor Divider Calculations
    Posted 8 days ago
    by Bruce Trump
    Handy gadgets make our engineering life easier—the little...
    Chopper Op Amps—are they really noisy?
    Posted 16 days ago
    by Bruce Trump
    Chopper op amps offer very low offset voltage and dramatically...
This question is answered
Heniek
Posted by Heniek
on Jan 18 2010 08:59 AM
Prodigy65 points
Hello
I just obtained a ADS1672EVM-PDK and followed the manual to use it in ADCPro. It work well.
I use this evaluation board package to speed up my evaluation.
I would like to connect the ADS1672EVM board to TMS320F28335 processor.
Can I get the firmware source code for ADS11672 to catch up my lost time and finish my evaluation?
Henryk
ADCPro ADS1672EVM-PDK
Report Abuse
  • Reply
You have posted to a forum that requires a moderator to approve posts before they are publicly available.
All Replies
  • Tom Hendrick
    Posted by Tom Hendrick
    on Jan 27 2010 15:02 PM
    Verified Answer
    Verified by Tom Hendrick
    Guru86200 points
    Hello Heniek,
    The source code that we have for the ADS1672 EVM-PDK won't be of much use to you on the TMS320F28335.  The motherboard for the ADS1672 is using the TMS320VC5509 which has a different set of chip support libraries.  Let me look into this a little more for you and if we can develop a driver for the F28335 DSP, we'll let you know.
    Tom
    Report Abuse
    • Reply
  • Heniek
    Posted by Heniek
    on Feb 05 2010 01:58 AM
    Prodigy65 points
    Hello Tom,
    We use Experimenter’s Kits with base board and TMS320F28335/C28343/C28346 processors controlCARD. Now we try rater the C28346 processor (because of higher clock speed).
    And now wit try to connect the ADS1672 Evaluation Module (without the MMB0 board) direct to this Experimenter’s Kit. And we also try to use this adc without the DSP-BIOS system.
    We need the ADS1672 configuration and usage code example for 28335/243/346 processor.
    We see, that the McBSP module on this processors is very similar to McBSP module on VC5507/5509A processor. And also the I2C module is very similar.
    W found that the source code for the ADS1282EVM-PDK (obtained from the post) is very useful for doing adc interface code.
    We hope, that the ADS1672EVM-PDK source code will be very useful example for start to do the ADS1672 interface code.
    Heniek
    Report Abuse
    • Reply
  • Daniele Angelosante
    Posted by Daniele Angelosante
    on May 08 2012 05:08 AM
    Prodigy155 points
    Dear Tom and Heniek,
    I have the similar needs (i.e., driver for ADS1672evm with TMS320C28346). Do you have something that you could share?
    Best
    Report Abuse
    • Reply
  • Greg Hupp
    Posted by Greg Hupp
    on May 08 2012 14:08 PM
    Genius9440 points
    Daniele -
    Have you tried looking at the sample code in the "Design Notes" portion of the forum?  I don't think there is anything that matches your request exactly, but you may be able to find something that will help you in your code development.
    Greg Hupp
    Hardware and Software Platform Development
    Report Abuse
    • Reply
  • Carlos Javier Villag��mez
    Posted by Carlos Javier Villag��mez
    on Jun 04 2012 18:10 PM
    Prodigy30 points
    Hi Tom,
    I would like to make an interface between an ADS1672EVM with a FPGA Xilinx 3AN, can you provide the source code of the  ADS1672EVM-PDK I think this code is usefu to setup the registers and follow a similar code procedure for programming a processor inside the FPGA , I will  appreciate your help
    Report Abuse
    • Reply
  • Greg Hupp
    Posted by Greg Hupp
    on Jun 05 2012 09:04 AM
    Genius9440 points
    Carlos -
    Please find the requested firmware at the below links.  The source is developed in CCS 3.1.
    ftp://ftp.ti.com/pub/data_acquisition/ADCPro2/Source/ads1672evmfw.zip - ADS1672EVM firmware source
    ftp://ftp.ti.com/pub/data_acquisition/ADCPro2/Source/ADCProFW.zip - ADCPro firmware library (may be required for project or reference)
    Keep in mind that this firmware is development for our evaluation system and therefore may not be well suited for end applications.  Also, this source is provided "as-is", so modifications and change support is not provided.
    Greg Hupp
    Report Abuse
    • Reply
    on Jun 05 2012 11:00 AM
    Prodigy30 points
    Thanks a lot Greg!!!
    Report Abuse
    • Reply
  • Sympson
    Posted by Sympson
    on Oct 26 2012 08:19 AM
    Prodigy80 points
    Mr. Greg,
    Files on "ftp://ftp.ti.com/pub/data_acquisition/ADCPro2/Source" looks very useful but they are encrypted. Could you send me the password too?
    Thanks in advanced
    Report Abuse
    • Reply
  • Greg Hupp
    Posted by Greg Hupp
    on Oct 26 2012 09:17 AM
    Genius9440 points
    Sympson -
    Can you either post your email address or "Start a Conversation" with me and we'll be happy to send the passwords to the files.
    Greg Hupp
    Report Abuse
    • Reply
TI E2E™ Community
  • Support Forums
  • Blogs
  • Videos
  • Groups
  • Site Support & Feedback
  • Settings
TI E2E™ Community Groups
  • TI University Program
  • Make the Switch
  • Microcontroller Projects
  • Motor Drive & Control
Other Communities
  • Deyisupport
  • Designsomething.org
  • beagleboard.org
  • TI on Element 14
  • TI on TechXchangeSM
Other Technical & Support Resources
  • WEBENCH® Design Center
  • Product Information Centers
  • Technical Documents
  • TI Design Network
  • TI Technical Articles
  • TI Training
All content and materials on this site are provided "as is". TI and its respective suppliers and providers of content make no representations about the suitability of these materials for any purpose and disclaim all warranties and conditions with regard to these materials, including but not limited to all implied warranties and conditions of merchantability, fitness for a particular purpose, title and non-infringement of any third party intellectual property right. TI and its respective suppliers and providers of content make no representations about the suitability of these materials for any purpose and disclaim all warranties and conditions with respect to these materials. No license, either express or implied, by estoppel or otherwise, is granted by TI. Use of the information on this site may require a license from a third party, or a license from TI.
Content on this site may contain or be subject to specific guidelines or limitations on use. All postings and use of the content on this site are subject to the Terms of Use of the site; third parties using this content agree to abide by any limitations or guidelines and to comply with the Terms of Use of this site. TI, its suppliers and providers of content reserve the right to make corrections, deletions, modifications, enhancements, improvements and other changes to the content and materials, its products, programs and services at any time or to move or discontinue any content, products, programs, or services without notice.
Follow Us Texas Instruments on Facebook Texas Instruments on Twitter Texas Instruments on LinkedIn Texas Instruments on Google+
TI Worldwide | Contact Us | my.TI Login | Site Map | Corporate Citizenship | mobile m.ti.com (Mobile Version)
TI is a global semiconductor design and manufacturing company. Innovate with 100,000+ analog ICs and
embedded processors, along with software, tools and the industry’s largest sales/support staff.
© Copyright 1995-2013 Texas Instruments Incorporated. All rights reserved.
Trademarks | Privacy Policy | Terms of Use
