Hi all,
I am currently trying to work with the ADS1298R evaluation module. I am very new to this, but I couldn't find an answer to my question in the community so far.
The ADS1298RECG-FE EVM is in its default jumper configuration for the internal test signal and I didn't add anything to the circuitry. However, I am not able to see a respiration signal. I also use a Rigel 333 patient simulator to simulate a three lead signal and respiration the ECG signal looks fine, but I have problems to see any respiration signal at all even though I changed the jumper configuration of JP35/34 as described in the manual. Did I understand correctly that the on-board respiration circuitry should simulate a test-signal without any external output? And how will I be able to see the signal of the Rigel simulator?
I would be very grateful for any comments or tips, I'm starting to become a little bit desperate here. :)
Thank you very much in advance!
Clara
