we using the ADS1015.
The communication to the device works fine, we can configure and read the signals.
At this moment we using a delayed loop to check the end of the ADC conversion.
In the data sheet we had seen that we can using the output signal ALERT/RDY to check when the conversion is ready to read.
Therefore we should information to the Lo_thresh and Hi_thresh registers.
If we had good understand the description from the data sheet, the Lo register should be 0x0000 and the HI register 0x8000.
What is imported to let works the conversion RDY signal?
What we must write to the different registers?
many thanks
