I am getting 250 uVpp gaussian noise at all channels, even when shorting inputs to ground and using the configuration which gives the lowest noise levels (G=24). I have no idea why this is happening, so I will give some details about the circuit I designed so as to rule out some possibilities:
-I am using integrated SMD voltage regulators from Texas Instruments and other SMD components in a relatively small design (5x5 cm, dual layer)
-I am using batteries to supply the circuit with power.
-I separated the analog and digital grounds and they only touch at one point in the circuit.
-I hand soldered all the components. (could a little bit of excess lead be an issue?)
-An arduino is used to send data to the PC.
-I tested the device with 100 mVpp sine waves and square waves and there was no problem in visualizing them on the PC, but the noise was still present.
Would you have any idea as to why this noise is present? I can post more details of my circuit if necessary.
Thanks in advance
Pablo
