Hi.
I'm working on new design including analog output, and I have preferred DAC8760 but I met problem about zero drift especially voltage output of DAC8760 (approx 9.5mV at Zero).
Power on my design 12V unipolar as expected. Actually, I know at least -500mV supply rail should be VADD- and GND. But I did not expect offset drift this much. I can use LM7705 and provides negative bias of ~230mV, but pcb space restrict me.
My question about DAC8750. I have checked the datasheet and I saw DAC8750 operates with a unipolar power, this suitable for me (my supply voltage changes 12-36V unipolar). Is there any possibility encounter with the same problem if I used DAC8750 with unipolar power?
Thank you in advance.
