Hello E2E,
Please let me know how to calculate for output impedance of DAC7718.
I found it that 0.5-Ω when code = 0x from datasheet.
I want to know output impedance when from 0x000h to 0xFFFh.
ACGUY
Hello E2E,
ACGUY
Hello Kevin,
Thank you for reply.
>> Can I ask exactly what you are hoping to use the output impedance figure for?
Are you requesting detail informartion about application or business volume?
I can't post it in E2E.
>> I've seen some pretty interesting DAC Zo frequency response curves in the past and there is some smaller dependency on code.
What is the dependency of DAC's Zo?
Is Zo a calculable parameter?
ACGUY
ACGUY,
Sorry for the delays, I've been out of office on business travel for the last several days.
ACGUY said:>> Can I ask exactly what you are hoping to use the output impedance figure for?
I'm not necessarily asking for the application and not asking anything for the business volume. To phrase it directly, why is it necessary in this case to know more detail about the output impedance?
ACGUY said:>> I've seen some pretty interesting DAC Zo frequency response curves in the past and there is some smaller dependency on code.
Anything that is modeled via SPICE can be calculated, but it becomes more of a question of practicality. This is something you'd probably be better off with a SPICE model for than an equation for.
ACGUY,
I see - I finally understand the root cause of this question! Thanks.
The reason the specification is provided at code 0x800 is that this is the mid-scale code of the DAC which is a fairly typical method of specifying DAC output impedance. The value to choosing the mid-scale code is output impedance will look different when the output amplifier is operating near either the positive or negative rails.
So in the end when I said that there is no real dependency on code, perhaps I should have more carefully and precisely explained that within the linear region of operation there is very little, if any, dependency on code. Near the rails where the amplifier is non-linear, there would be some change in output impedance, which one might call a "code dependent" output impedance, though it's more directly the amplifier operating near a rail than it is anything intrinsic to the string DAC.
