Other Parts Discussed in Thread: TPS7A39
I understand that the recommended supply sequence is VSS -> VCC -> VDD as comment below from DS.
The following supply sequence must be followed: VSS (device substrate) first, then VDD followed by VCC.
Now the customer plan to use TPS7A39 to generate +/- 12V for VSS and VCC, so VSS and VCC will power up simultaneously.
Then can you recommend to power up VSS and VCC simultaneously? Please let me know the concern if you can't recommend it.
Satoshi / Japan Disty
