DAC7578: Change I2C address after Power-Up
Part Number: DAC7578
Hello TI-Team,
we use the DAC7578 in our application. At the moment we have a hot plug problem. Some times the address detection is wrong. We use a different address for every Slot. The address pins come from the backplane and mate a little bit later then the supply pins. We already tried to delay the power supply of the DAC, it helps but it still doesn't work every time.
In the datasheet it's mentions "The device address can be updated dynamically between serial commands", but i can't find a way to force the DAC to change the address. Is there a way to update  the I2C address after the Power Up.
Thank you
Greetings Mat
