• Join
  • Sign In with my.TI Login
Texas Instruments
  • Products
  • Applications
  • Tools & Software
  • Support & Community
  • Sample & Buy
  • About TI
Sample & Purchase Cart Sample & Purchase Cart
  • Search
  • Advanced
TI E2E™ Community
  • Support Forums
  • Blogs
  • Groups
  • Videos
  • 简体中文
  • More ...
TI Home » TI E2E Community » Support Forums » Data Converters » Video Converters » Video Converters - Forum » TVP5158 how to handle unused pins
Share
Video Converters
  • Forum
  • Announcements
Options
  • Subscribe via RSS
Check out
Analog Wire blog
  • $core_v2_blog.Current.Name
    RS-485 - Who says you can't teach an old dog new tricks?
    Posted 3 days ago
    by Neel Seshan
    Would you agree that RS-485 has turned out to be one of the most...
    Filter for thought
    Posted 5 days ago
    by Soufiane Bendaoud
    Have you ever wondered how engineers designed active filters...
    Let’s take this driver out for a spin
    Posted 10 days ago
    Before I suggest a suitable op amp to drive an ADC, I look at...
This question is not answered
OC
Posted by OC
on Dec 27 2011 01:53 AM
Intellectual870 points
Dear all,
Can any champs of video decoder help me to answer below questions? Thanks in advance.
1.The below circuit cut from tvp5158evm. The question is if I change the inverse resistor from 0 ohm to 37.4 ohm, the effect shall not have serious change. Is my suppose right? So, I want to know why use the 37.4 ohm.
2. As the above circuit, If I left open on VIN1-4 and AIN1-4, the external noise will interfere on those pins. Is my suppose right?
    For example, if the noise voltage is higher than power IC, the result will generate two ductile problems.
    Q1. Does this situation impact the other channels?
    Q2. Does this situation make the IC latch-up phenomenon?
B.R.
OC
TVP5158 DM365
Report Abuse
  • Reply
You have posted to a forum that requires a moderator to approve posts before they are publicly available.
All Replies
  • Larry Taylor
    Posted by Larry Taylor
    on Jan 06 2012 16:31 PM
    Genius16810 points
    1.  37.4-ohms is recommended to match the Thevenin resistance of a 75-ohm video source impedance terminated with 75 ohms (75//75 = 37.5) .   0 ohms would be best if the inputs were driven by a buffer with low source impedance.  An incorrect resistor could have some an impact on noise cancelation.
    2-1. We sometimes tie unused analog inputs to ground, but this is not an absolute requriement with TVP5158.  The analog video inputs have separate paths and should not be affected by unused inputs.  Tying these pins to ground using a resistor could potentially reduce internal noise and power consumption, but this could also be accomplished by powering down unused channels using REG 1Ah.  Installing a connection to ground using a resistor does provide a way to connect a signal to an input, in case it is needed for evaluation.
    2-2. Floating the pins should not result in latch-up.
    TVP5158
    Report Abuse
    • Reply
  • OC
    Posted by OC
    on Jan 09 2012 19:17 PM
    Dear Larry,
    Thank you so much for your confirmation.
    B.R.
    OC
    Report Abuse
    • Reply
  • OC
    Posted by OC
    on Mar 12 2012 01:49 AM
    Dear Larry,
    Another question want to consult with you. How do handle the unused pins like pin 16、17 and 19? Can you provide a internal circuit to explain the reason why that can leave open or connect a resistor to the ground? Thanks in advance.
    B.R.
    OC
    TVP5158
    Report Abuse
    • Reply
TI E2E™ Community
  • Support Forums
  • Blogs
  • Videos
  • Groups
  • Site Support & Feedback
  • Settings
TI E2E™ Community Groups
  • TI University Program
  • Make the Switch
  • Microcontroller Projects
  • Motor Drive & Control
Other Communities
  • Deyisupport
  • Designsomething.org
  • beagleboard.org
  • TI on Element 14
  • TI on TechXchangeSM
Other Technical & Support Resources
  • WEBENCH® Design Center
  • Product Information Centers
  • Technical Documents
  • TI Design Network
  • TI Technical Articles
  • TI Training
All content and materials on this site are provided "as is". TI and its respective suppliers and providers of content make no representations about the suitability of these materials for any purpose and disclaim all warranties and conditions with regard to these materials, including but not limited to all implied warranties and conditions of merchantability, fitness for a particular purpose, title and non-infringement of any third party intellectual property right. TI and its respective suppliers and providers of content make no representations about the suitability of these materials for any purpose and disclaim all warranties and conditions with respect to these materials. No license, either express or implied, by estoppel or otherwise, is granted by TI. Use of the information on this site may require a license from a third party, or a license from TI.
Content on this site may contain or be subject to specific guidelines or limitations on use. All postings and use of the content on this site are subject to the Terms of Use of the site; third parties using this content agree to abide by any limitations or guidelines and to comply with the Terms of Use of this site. TI, its suppliers and providers of content reserve the right to make corrections, deletions, modifications, enhancements, improvements and other changes to the content and materials, its products, programs and services at any time or to move or discontinue any content, products, programs, or services without notice.
Follow Us Texas Instruments on Facebook Texas Instruments on Twitter Texas Instruments on LinkedIn Texas Instruments on Google+
TI Worldwide | Contact Us | my.TI Login | Site Map | Corporate Citizenship | mobile m.ti.com (Mobile Version)
TI is a global semiconductor design and manufacturing company. Innovate with 100,000+ analog ICs and
embedded processors, along with software, tools and the industry’s largest sales/support staff.
© Copyright 1995-2013 Texas Instruments Incorporated. All rights reserved.
Trademarks | Privacy Policy | Terms of Use
