• Join
  • Sign In with my.TI Login
Texas Instruments
  • Products
  • Applications
  • Tools & Software
  • Support & Community
  • Sample & Buy
  • About TI
Sample & Purchase Cart Sample & Purchase Cart
  • Search
  • Advanced
TI E2E™ Community
  • Support Forums
  • Blogs
  • Groups
  • Videos
  • 简体中文
  • More ...
TI Home » TI E2E Community » Support Forums » Data Converters » Video Converters » Video Converters - Forum » controling TVP7002EVM using a microcontroller
Share
Video Converters
  • Forum
  • Announcements
Options
  • Subscribe via RSS
Check out
Analog Wire blog
  • $core_v2_blog.Current.Name
    Cable equalization 101 – Automating your design
    Posted 1 day ago
    by Hooman Hashemi
    Judging by the number of views on a post related to numerical...
    RS-485 - Who says you can't teach an old dog new tricks?
    Posted 5 days ago
    by Neel Seshan
    Would you agree that RS-485 has turned out to be one of the most...
    Filter for thought
    Posted 6 days ago
    by Soufiane Bendaoud
    Have you ever wondered how engineers designed active filters...
This question is not answered
Gilad Schnurmacher85577
Posted by Gilad Schnurmacher85577
on Mar 15 2012 15:52 PM
Prodigy90 points
i want to design a board according to the TVP7002EVM and using several settings.
i want to config the board using microcontroller
for now i want to simulate the programming of the microcontroller with the TVP7002EVM.
my question is how to connect the microcontroller to the TVP7002EVM, should i connect it directly to the board? of should i connect it to the right pins (I2C) in the parallel port?
thanks
Report Abuse
  • Reply
You have posted to a forum that requires a moderator to approve posts before they are publicly available.
All Replies
  • Larry Taylor
    Posted by Larry Taylor
    on Mar 19 2012 12:22 PM
    Genius16810 points
    You can can connect SCL and SDA to the SCL/SDA testpoints pads on the PCB.  These points are after the 74AHC05 and will be pulled high (3.3V) when the printer port cable is disconnected.  You will also need a ground connection.
    TVP7002
    Report Abuse
    • Reply
  • Gilad Schnurmacher85577
    on May 02 2012 05:52 AM
    Prodigy90 points
    in the tvp7002evm i can see the points SDA and SCL, those are filled, i can't put a wire in there.
    in the ths8200 i can see holes near the SDA and SCL where i can put the wires.
    i can try to to connect through the 25pin in the TVP7002EVM directly to the DB11 and DB15.
    what is the best option? if i connect to the ths8200, will i get full control? will the 25pin will be enough?
    Report Abuse
    • Reply
    on Jun 05 2012 15:52 PM
    Prodigy90 points
    okay, i connected microcontroler throgh the SCL and SDA ports in the THS8200.
    where should i take the ground connection? i thought first to use one of the lpt ground ports, is it a good idea?
    also, i have a problem with the signal, i have the signals that i got with a scope, what is wrong?
     (yellow is SCL, and green is SDA)
    Report Abuse
    • Reply
TI E2E™ Community
  • Support Forums
  • Blogs
  • Videos
  • Groups
  • Site Support & Feedback
  • Settings
TI E2E™ Community Groups
  • TI University Program
  • Make the Switch
  • Microcontroller Projects
  • Motor Drive & Control
Other Communities
  • Deyisupport
  • Designsomething.org
  • beagleboard.org
  • TI on Element 14
  • TI on TechXchangeSM
Other Technical & Support Resources
  • WEBENCH® Design Center
  • Product Information Centers
  • Technical Documents
  • TI Design Network
  • TI Technical Articles
  • TI Training
All content and materials on this site are provided "as is". TI and its respective suppliers and providers of content make no representations about the suitability of these materials for any purpose and disclaim all warranties and conditions with regard to these materials, including but not limited to all implied warranties and conditions of merchantability, fitness for a particular purpose, title and non-infringement of any third party intellectual property right. TI and its respective suppliers and providers of content make no representations about the suitability of these materials for any purpose and disclaim all warranties and conditions with respect to these materials. No license, either express or implied, by estoppel or otherwise, is granted by TI. Use of the information on this site may require a license from a third party, or a license from TI.
Content on this site may contain or be subject to specific guidelines or limitations on use. All postings and use of the content on this site are subject to the Terms of Use of the site; third parties using this content agree to abide by any limitations or guidelines and to comply with the Terms of Use of this site. TI, its suppliers and providers of content reserve the right to make corrections, deletions, modifications, enhancements, improvements and other changes to the content and materials, its products, programs and services at any time or to move or discontinue any content, products, programs, or services without notice.
Follow Us Texas Instruments on Facebook Texas Instruments on Twitter Texas Instruments on LinkedIn Texas Instruments on Google+
TI Worldwide | Contact Us | my.TI Login | Site Map | Corporate Citizenship | mobile m.ti.com (Mobile Version)
TI is a global semiconductor design and manufacturing company. Innovate with 100,000+ analog ICs and
embedded processors, along with software, tools and the industry’s largest sales/support staff.
© Copyright 1995-2013 Texas Instruments Incorporated. All rights reserved.
Trademarks | Privacy Policy | Terms of Use
