• Join
  • Sign In with my.TI Login
Texas Instruments
  • Products
  • Applications
  • Tools & Software
  • Support & Community
  • Sample & Buy
  • About TI
Sample & Purchase Cart Sample & Purchase Cart
  • Search
  • Advanced
TI E2E™ Community
  • Support Forums
  • Blogs
  • Groups
  • Videos
  • 简体中文
  • More ...
TI Home » TI E2E Community » Support Forums » Data Converters » Video Converters » Video Converters - Forum » How about TVP7002 ?
Share
Video Converters
  • Forum
  • Announcements
Options
  • Subscribe via RSS
Check out
Analog Wire blog
  • $core_v2_blog.Current.Name
    This amplifier doesn't exist...now what!?
    Posted 18 hours ago
    by Xavier Ramus
    Sometimes it’s impossible to find an amplifier with the...
    Cable equalization 101 – Automating your design
    Posted 3 days ago
    by Hooman Hashemi
    Judging by the number of views on a post related to numerical...
    RS-485 - Who says you can't teach an old dog new tricks?
    Posted 7 days ago
    by Neel Seshan
    Would you agree that RS-485 has turned out to be one of the most...
How about TVP7002 ?
How about TVP7002 ?
This question is answered
Eric Kim38719
Posted by Eric Kim38719
on Mar 19 2012 04:45 AM
Intellectual850 points
Hi
I'd lik to replace with TI from TDA9955(nxp)?
(http://www.nxp.com/documents/data_sheet/TDA9955HL.pdf)
How about TVP7002 ?
Is it compatible with TI vs NXP in functionality aspects?
Thanks...
Report Abuse
  • Reply
You have posted to a forum that requires a moderator to approve posts before they are publicly available.
All Replies
  • Larry Taylor
    Posted by Larry Taylor
    on Mar 19 2012 13:30 PM
    Verified Answer
    Verified by Eric Kim38719
    Genius16810 points
    Yes, the TVP7002 could replace this device.  The digital I/O for the TVP7002 is 3.3V.
    Support of 24Hz, 25Hz and 30Hz 1080p and 720p formats with sync-on-Y will require an external sync separator, however.
    TVP7002
    Report Abuse
    • Reply
  • Alan Ocampo
    Posted by Alan Ocampo
    on Mar 23 2012 12:46 PM
    Expert4160 points
    LMH1981 and LMH1980 are two video sync separator with automatic format detection that can support all frame rates of 480i/p, 576i/p, 720p, 1080i/p video standards.  These parts are from National Semiconductor's video timing portfolio.
    LMH1981 has 50% sync slicing, low additive jitter, and is commonly used for genlock circuits in broadcast and pro video systems.
    LMH1980 has fixed-level sync slicing and also support Sync on Green for many PC graphics (VESA) timing.  This part is targeted for consume, pro-sumer, and PC applications.
    LMH1982 and LMH1983 are the companion video/audio clock & timing generators.
    EVMs are offered for all these devices as well.
    Alan
    LMH1983 LMH198x A/V clock video clock audio clock LMH1981 sync separator genlock LMH1982 video timing LMH1980 LM1881
    Report Abuse
    • Reply
  • jack jiang
    Posted by jack jiang
    on Mar 30 2012 21:52 PM
    Prodigy50 points
    Hi:
          Can TVP7002 auto- detect all frame input?
         Thanks!
    Report Abuse
    • Reply
  • jack jiang
    on Mar 30 2012 21:59 PM
    Prodigy50 points
    Hi all:
           Can TVP7002 auto-detect all frame input form VGA?
           i want to use TVP7002 that:
                      VGA input to TVP7002 , and digital output to FPGA,  need FPGA deal with the position of the  effective pixel?
                      And FPGA output drive LCD to re-display video?
          Any total solution by TI for this video convert!
         Thanks very much!
    Report Abuse
    • Reply
  • Sinoj B S
    Posted by Sinoj B S
    on Mar 15 2013 02:05 AM
    Intellectual510 points
    Hi Alan,
    We are using a monochrome video camera whose DC offset and Black Level varies from camera to camera (of the same model). For our application we have to extract only the video content (700mV).Has there any single IC which extracts only the video content out of the composite video signal? An attachment is given describing different voltage levels of the camera output. Referring to the attachment levels C and D changes from camera to camera. We need an IC which gives out only D-E portion out of the composite video signal.
    I tried AC coupling, but it caused the DC level to vary w.r.t the video amplitude.
    Regards | Sinoj
    Report Abuse
    • Reply
  • Alan Ocampo
    on Mar 15 2013 14:47 PM
    Expert4160 points
    Sinoj,
    The only solution that comes to mind is to use a limiting op amp to do the sync stripping.
    See Application Report SLOA057A section 3.2 Sync Stripping.
    I'm not intimately familiar with this design, but just remember seeing it a while back...maybe it's applicable in your application?
    If you need help on these op amp designs, I suggest posting your questions on the High Speed Amps forum (fyi- I work on clocking device now).
    Alan
    Report Abuse
    • Reply
TI E2E™ Community
  • Support Forums
  • Blogs
  • Videos
  • Groups
  • Site Support & Feedback
  • Settings
TI E2E™ Community Groups
  • TI University Program
  • Make the Switch
  • Microcontroller Projects
  • Motor Drive & Control
Other Communities
  • Deyisupport
  • Designsomething.org
  • beagleboard.org
  • TI on Element 14
  • TI on TechXchangeSM
Other Technical & Support Resources
  • WEBENCH® Design Center
  • Product Information Centers
  • Technical Documents
  • TI Design Network
  • TI Technical Articles
  • TI Training
All content and materials on this site are provided "as is". TI and its respective suppliers and providers of content make no representations about the suitability of these materials for any purpose and disclaim all warranties and conditions with regard to these materials, including but not limited to all implied warranties and conditions of merchantability, fitness for a particular purpose, title and non-infringement of any third party intellectual property right. TI and its respective suppliers and providers of content make no representations about the suitability of these materials for any purpose and disclaim all warranties and conditions with respect to these materials. No license, either express or implied, by estoppel or otherwise, is granted by TI. Use of the information on this site may require a license from a third party, or a license from TI.
Content on this site may contain or be subject to specific guidelines or limitations on use. All postings and use of the content on this site are subject to the Terms of Use of the site; third parties using this content agree to abide by any limitations or guidelines and to comply with the Terms of Use of this site. TI, its suppliers and providers of content reserve the right to make corrections, deletions, modifications, enhancements, improvements and other changes to the content and materials, its products, programs and services at any time or to move or discontinue any content, products, programs, or services without notice.
Follow Us Texas Instruments on Facebook Texas Instruments on Twitter Texas Instruments on LinkedIn Texas Instruments on Google+
TI Worldwide | Contact Us | my.TI Login | Site Map | Corporate Citizenship | mobile m.ti.com (Mobile Version)
TI is a global semiconductor design and manufacturing company. Innovate with 100,000+ analog ICs and
embedded processors, along with software, tools and the industry’s largest sales/support staff.
© Copyright 1995-2013 Texas Instruments Incorporated. All rights reserved.
Trademarks | Privacy Policy | Terms of Use
