I'm building color line scan CCD camera inspired by ChaN's monochromatic version:
http://elm-chan.org/works/lcam/report.html
Digital circuit is relatively simple- it contains FT2232H USB controller and XC9572 CPLD generating timing
waveforms for CCD device. CCD device is NEC UPD8891 from scrap document scanner, and it's tested and
working. Problem is the complicated analog circuit with multiple sample and holds, analog MUX, offset DAC,
VGA and A/D converter. Then I'd discovered IC VSP5622 that's contains everything I need and I ordered
some samples. I've built prototype on protoboard and now studying the datasheet. I've found the
information are incomplete- I'm primary missing some registers map and format of data stream using
CMOS output. Does exist some extended version of the datasheet or some working example with this IC?
Thank's for any advice.
Dan
