A customer I am working with has been having a problem with the clock output. They are working with 720p video which the datasheet recommends using a pixel rate of 74.25 MHz and the medium VCO range. They had an improvement in performance of the clock when they changed the VCO setting to low. Is there any issue for using this configuration for production?
Also, the clock output has 7 nsec of jitter which is much greater than the spec of 500 psec of jitter. Any idea as to what is causing it or how to improve it?
Adrian
