Can each channel of the TVP5158 convert a different video format? For example, can channel 0 & 3 decode PAL and channel 1 & 2 decode NTSC simultaneously?
I ask because the description of the IC suggests that it can do this, however the datasheet has a single register for "Video Standard Status".
Or, is this register actually duplicated inside the IC and the "Decoder Read Enable" is used to select which decoder to access?
