We will use TI P/N TVP5150PBS but replaced by TV5150AM1PBS and TI Dose not recommend new design.
What you recomend this P/N ?
thank you.
thank you.
The TVP5150AM1 is not NRND so you are OK using that device.
Please note that NRND does not mean that the device is unavailable (i.e. it is not end of life [EoL]) it simply means that design in support is limited and only available through the forums, hence if you are designing in to a new product and have issues it might be difficult to get support.
The main difference between the TVP5150 and the TVP5150AM1 is that the internal firmware on the AM1 has updates to make it more robust and able to lock to more abnormal signal types.
BR,
Steve
