Team,
Customer found issue which is related with PWDN signal timing. Please refer to the below for more details, and let us know your answer.
- Device: TPV7002
- Issue description
Initial status of PWDN signal is high. Then, PWDN signal (High to Low) was applied about 4.4msec later than RESET signal (Low to High) during board power-on procedure. Refer to the screenshot in below.
With this timing sequence between PWDN and RESET signals, the TPV7002 device was not working properly.
Questions/Requests
Couldn’t find timing requirements between PWDN and RESET signals from the datasheet. Only below timing diagram is available. Please provide timing requirements between PWDN and RESET signals.
In my understanding, this power-down mode turns off all device blocks during PWDN signal is High status. So we should perform RESET (Device initialization) procedure after this mode. Is it correct?
We found that TPV7002 supports power-down mode thru register configuration as below. What should be done after this power-down mode? Do we require RESET (Device initialization) procedure again after this mode?
Thank you in advance!
