• Join
  • Sign In with my.TI Login
Texas Instruments
  • Products
  • Applications
  • Tools & Software
  • Support & Community
  • Sample & Buy
  • About TI
Sample & Purchase Cart Sample & Purchase Cart
  • Search
  • Advanced
TI E2E™ Community
  • Support Forums
  • Blogs
  • Groups
  • Videos
  • 简体中文
  • More ...
TI Home » TI E2E Community » Support Forums » Data Converters » Video Converters » Video Converters - Forum » A question to Larry Taylor
Share
Video Converters
  • Forum
  • Announcements
Options
  • Subscribe via RSS
Check out
Analog Wire blog
  • $core_v2_blog.Current.Name
    RS-485 - Who says you can't teach an old dog new tricks?
    Posted 3 days ago
    by Neel Seshan
    Would you agree that RS-485 has turned out to be one of the most...
    Filter for thought
    Posted 4 days ago
    by Soufiane Bendaoud
    Have you ever wondered how engineers designed active filters...
    Let’s take this driver out for a spin
    Posted 10 days ago
    Before I suggest a suitable op amp to drive an ADC, I look at...
This question is answered
Anonymous
Posted by Anonymous
on Mar 15 2011 09:17 AM
Guru13910 points
Dear Larry,
May I ask here questions on impedance?
If I am having 5mil wide track, how should I do to control its impedance to 50 Ohm?
Because when I am referencing EVM6437 design, it found its Gerber files has specification that all signal lines needs to be impedance controlled to 50 Ohm, however I found in the PCB file that
Material
Thickness
Dielectric constant
Core
FR-4
12.6mil
4.8
Prepreg
FR-4
12.6mil
4.8
Using a impedance calculation formula
Z0=(K/ Sqrt (Er+1.41)) * Ln(5.98*h/(0.8*w + t))
I took K=79 because 5<w<15 (87 if 15<w<25), and
1.    Er=4.8
2.    h=12.6
3.    w=5
4.    t=1.4mil
Due to the table above, which resulted in 83.56 Ohm impedance as calculated by the formula.
There are several parameters in the formula and the one thing I am sure about is that 5mil width needs to be ensured, but how about other parameters? Do I have control over h, and is it the same as prepreg thickness?
I have another question over how “h” is defined. If the signal trace is adjacent to a internal power plane, is “h” the thickness of the prepreg or core layer between them? If the signal trace is not adjacent to any power plane, for example, signal layers on layer 3, 4 and 5, and a power plane on layer 6, then how should I define h for trace on layer 4, which are two signal layers separated between power plane 6?
And is GND plane also included in the definition?
Zheng
impedance track width
Report Abuse
  • Reply
You have posted to a forum that requires a moderator to approve posts before they are publicly available.
All Replies
  • Anonymous
    Posted by Anonymous
    on Mar 15 2011 09:20 AM
    Guru13910 points
    This is the layer stack of the EVM.
    Zheng
    stack layer
    Did this answer your question? Yes
    Report Abuse
    • Reply
  • Larry Taylor
    Posted by Larry Taylor
    on Mar 15 2011 14:04 PM
    Verified Answer
    Verified by $verifiedBy.DisplayName
    Genius16810 points
    Zheng,
    The equations that you have been using are for microstrip transmission lines, where a signal trace is run over a ground plane.  "H" is the inside distance between signal bottom edge and plane top edge.  For a given trace width, thighness, and dielectric constant, impedance is adjusted by altering "h", or core thickness.    The ground plane is typically used as the reference plane for the signal trace.  The PCB design and fab company typically tries to maintain the impedance specified by the circuit designer.  I am not sure if this particular EVM was designed for 50-ohm impedance.
    Did this answer your question? No
    Report Abuse
    • Reply
  • Anonymous
    Posted by Anonymous
    on Mar 15 2011 14:27 PM
    Guru13910 points
    Dear Larry,
    Thanks for the answer. I need to study these concepts carefully.
    Zheng
    Report Abuse
    • Reply
TI E2E™ Community
  • Support Forums
  • Blogs
  • Videos
  • Groups
  • Site Support & Feedback
  • Settings
TI E2E™ Community Groups
  • TI University Program
  • Make the Switch
  • Microcontroller Projects
  • Motor Drive & Control
Other Communities
  • Deyisupport
  • Designsomething.org
  • beagleboard.org
  • TI on Element 14
  • TI on TechXchangeSM
Other Technical & Support Resources
  • WEBENCH® Design Center
  • Product Information Centers
  • Technical Documents
  • TI Design Network
  • TI Technical Articles
  • TI Training
All content and materials on this site are provided "as is". TI and its respective suppliers and providers of content make no representations about the suitability of these materials for any purpose and disclaim all warranties and conditions with regard to these materials, including but not limited to all implied warranties and conditions of merchantability, fitness for a particular purpose, title and non-infringement of any third party intellectual property right. TI and its respective suppliers and providers of content make no representations about the suitability of these materials for any purpose and disclaim all warranties and conditions with respect to these materials. No license, either express or implied, by estoppel or otherwise, is granted by TI. Use of the information on this site may require a license from a third party, or a license from TI.
Content on this site may contain or be subject to specific guidelines or limitations on use. All postings and use of the content on this site are subject to the Terms of Use of the site; third parties using this content agree to abide by any limitations or guidelines and to comply with the Terms of Use of this site. TI, its suppliers and providers of content reserve the right to make corrections, deletions, modifications, enhancements, improvements and other changes to the content and materials, its products, programs and services at any time or to move or discontinue any content, products, programs, or services without notice.
Follow Us Texas Instruments on Facebook Texas Instruments on Twitter Texas Instruments on LinkedIn Texas Instruments on Google+
TI Worldwide | Contact Us | my.TI Login | Site Map | Corporate Citizenship | mobile m.ti.com (Mobile Version)
TI is a global semiconductor design and manufacturing company. Innovate with 100,000+ analog ICs and
embedded processors, along with software, tools and the industry’s largest sales/support staff.
© Copyright 1995-2013 Texas Instruments Incorporated. All rights reserved.
Trademarks | Privacy Policy | Terms of Use
