• Join
  • Sign In with my.TI Login
Texas Instruments
  • Products
  • Applications
  • Tools & Software
  • Support & Community
  • Sample & Buy
  • About TI
Sample & Purchase Cart Sample & Purchase Cart
  • Search
  • Advanced
TI E2E™ Community
  • Support Forums
  • Blogs
  • Groups
  • Videos
  • 简体中文
  • More ...
TI Home » TI E2E Community » Support Forums » Data Converters » Video Converters » Video Converters - Forum » 20-bit Input format for THS8200
Share
Video Converters
  • Forum
  • Announcements
Options
  • Subscribe via RSS
Check out
Analog Wire blog
  • $core_v2_blog.Current.Name
    RS-485 - Who says you can't teach an old dog new tricks?
    Posted 4 days ago
    by Neel Seshan
    Would you agree that RS-485 has turned out to be one of the most...
    Filter for thought
    Posted 5 days ago
    by Soufiane Bendaoud
    Have you ever wondered how engineers designed active filters...
    Let’s take this driver out for a spin
    Posted 11 days ago
    Before I suggest a suitable op amp to drive an ADC, I look at...
This question is answered
Chengping Huo
Posted by Chengping Huo
on Mar 16 2011 06:55 AM
Prodigy115 points
I'm using DM365 and THS8200 to output VESA signal. If I use 16-bit RGB input format for THS8200, output is good. But if I use 20-bit YCrCb format for THS8200, output is not good. How to change input format from 16-bit RGB to 20-bit YCrCb?
Thanks  in advance!
THS8200
Report Abuse
  • Reply
You have posted to a forum that requires a moderator to approve posts before they are publicly available.
All Replies
  • Larry Taylor
    Posted by Larry Taylor
    on Mar 16 2011 15:50 PM
    Genius16810 points
    Chengping,
    What DM365 > THS8200 platform are you uing?
    By 16-bit RGB input format, do you mean the 16-bit RGB 4:4:4 as shown in Figure 4-3 of the THS8200 datasheet?  The THS8200 input bit assignment for the RGB 4:4:4 format is different from that of 20-bit 4:2:2.
    If a 16/20-bit 4:2:2 RGB format is being used, instead of the 16-bit RGB 4:4:4,  then you will need to use the color space converter in the THS8200 to convert from the 4:2:2 YCbCr format to RGB out.
    THS8200
    Report Abuse
    • Reply
  • Chengping Huo
    on Mar 16 2011 22:55 PM
    Prodigy115 points
    Larry,
    Thanks for your reply.
    My board is designed by myself, it is based both on DM365EVM and THS8200 Daughter-Card.
    My 16-bit RGB format is 4:4:4 shown in Figure 4-3.
    When I change input format of THS8200 to 20-bit(only 16-bit used) 4:2:2 YCbCr, I also change output format of DM365 and add CSC settings in THS8200. I don't know lost some settings. Do you have any tips?
    In table 4-1 of the THS8200 datasheet, In cross INPUT INTERFACE 20-BIT and [PRESET] VESA, no a 'X' is showed. Do you know, if THS8200 can set to both generate VESA signal(for computer monitor) and input a 20-bit 4:2:2 YCbCr data with DEDICATED TIMING?
    Thanks in advance!
    THS8200
    Report Abuse
    • Reply
  • Larry Taylor
    on Mar 17 2011 15:01 PM
    Verified Answer
    Verified by Chengping Huo
    Genius16810 points
    Chengping,
    After configuring the DM365 for 16-bit 422 YCbCr and ensuring that Y port data is routed to the THS8200 GY input and CbCr port data is routed to the THS8200 BCb port, try the settings below for conversion to RGB.  These settings are for dedicated input syncs and use a VESA slave setup.  A generic setup (not included) is preferred when embedded syncs are used.  Input sync polarities are configured for positive polarity.  Make sure the THS8200 FID pin is tied low or dirven to logic low level.  You will need to make a few changes to match the graphics format that you are using.
    // 422 YCbCr to RGB graohics with dedicated input syncs
    WR_REG,THS8200,0x01,0x03,0x01 // chip_ctl  frequency range=high
    //YCbR to RGB
    WR_REG,THS8200,0x01,0x04,0x81 // csc_ric1
    WR_REG,THS8200,0x01,0x05,0xD5 // csc_rfc1
    WR_REG,THS8200,0x01,0x06,0x00 // csc_ric2
    WR_REG,THS8200,0x01,0x07,0x00 // csc_rfc2
    WR_REG,THS8200,0x01,0x08,0x06 // csc_ric3
    WR_REG,THS8200,0x01,0x09,0x29 // csc_rfc3
    WR_REG,THS8200,0x01,0x0A,0x04 // csc_gic1
    WR_REG,THS8200,0x01,0x0B,0x00 // csc_gfc1
    WR_REG,THS8200,0x01,0x0C,0x04 // csc_gic2
    WR_REG,THS8200,0x01,0x0D,0x00 // csc_gfc2
    WR_REG,THS8200,0x01,0x0E,0x04 // csc_gic3
    WR_REG,THS8200,0x01,0x0F,0x00 // csc_gfc3
    WR_REG,THS8200,0x01,0x10,0x80 // csc_bic1
    WR_REG,THS8200,0x01,0x11,0xBB // csc_bfc1
    WR_REG,THS8200,0x01,0x12,0x07 // csc_bic2
    WR_REG,THS8200,0x01,0x13,0x42 // csc_bfc2
    WR_REG,THS8200,0x01,0x14,0x00 // csc_bic3
    WR_REG,THS8200,0x01,0x15,0x00 // csc_bfc3
    WR_REG,THS8200,0x01,0x16,0x14 // csc_offset1
    WR_REG,THS8200,0x01,0x17,0xAE // csc_offset12
    WR_REG,THS8200,0x01,0x18,0x8B // csc_offset23
    WR_REG,THS8200,0x01,0x19,0x15 // csc_offset3
    WR_REG,THS8200,0x01,0x1C,0x53 // dman_cntl  20bit 422
    WR_REG,THS8200,0x01,0x1D,0x00 // dtg_y_sync1
    WR_REG,THS8200,0x01,0x1E,0x00 // dtg_y_sync2
    WR_REG,THS8200,0x01,0x1F,0x00 // dtg_y_sync3
    WR_REG,THS8200,0x01,0x20,0x00 // dtg_cbcr_sync1
    WR_REG,THS8200,0x01,0x21,0x00 // dtg_cbcr_sync2
    WR_REG,THS8200,0x01,0x22,0x00 // dtg_cbcr_sync3
    WR_REG,THS8200,0x01,0x23,0x2A // dtg_y_sync_upper
    WR_REG,THS8200,0x01,0x24,0x2A // dtg_cbcr_sync_upper
    WR_REG,THS8200,0x01,0x34,0x03 // dtg_total_pixel_msb adjust for various graphics formats
    WR_REG,THS8200,0x01,0x35,0x5A // dtg_total_pixel_lsb
    WR_REG,THS8200,0x01,0x36,0x80 // dtg_linecnt_msb
    WR_REG,THS8200,0x01,0x37,0x01 // dtg_linecnt_lsb
    WR_REG,THS8200,0x01,0x38,0x87 // dtg_mode     VESA Slave
    WR_REG,THS8200,0x01,0x39,0x27 // dtg_frame_field_msb  adjust for various graphics formats
    WR_REG,THS8200,0x01,0x3A,0x0D // dtg_frame_size_lsb
    WR_REG,THS8200,0x01,0x3B,0xFF // dtg_field_size_lsb
    CSM setup to map YCbCr to FS RGB
    WR_REG,THS8200,0x01,0x41,0x40 // csm_clip_gy_low
    WR_REG,THS8200,0x01,0x42,0x40 // csm_clip_bcb_low
    WR_REG,THS8200,0x01,0x43,0x40 // csm_clip_rcr_low
    WR_REG,THS8200,0x01,0x44,0x53 // csm_clip_gy_high
    WR_REG,THS8200,0x01,0x45,0x3F // csm_clip_bcb_high
    WR_REG,THS8200,0x01,0x46,0x3F // csm_clip_rcr_high
    WR_REG,THS8200,0x01,0x47,0x40 // csm_shift_gy
    WR_REG,THS8200,0x01,0x48,0x40 // csm_shift_bcb
    WR_REG,THS8200,0x01,0x49,0x40 // csm_shift_rcr
    WR_REG,THS8200,0x01,0x4A,0xFC // csm_mult_gy_msb
    WR_REG,THS8200,0x01,0x4B,0x44 // csm_mult_bcb_rcr_msb
    WR_REG,THS8200,0x01,0x4C,0xAC // csm_mult_gy_lsb
    WR_REG,THS8200,0x01,0x4D,0xAC // csm_mult_bcb_lsb
    WR_REG,THS8200,0x01,0x4E,0xAC // csm_mult_rcr_lsb
    WR_REG,THS8200,0x01,0x4F,0xFF // csm_mode
    WR_REG,THS8200,0x01,0x70,0x40 // dtg_hlength_lsb    adjust HSOUT width for various formats
    WR_REG,THS8200,0x01,0x71,0x03 // dtg_hdly_msb
    WR_REG,THS8200,0x01,0x72,0x31 // dtg_hdly_lsb
    WR_REG,THS8200,0x01,0x73,0x07 // dtg_vlength_lsb     adjust VSOUT width for various formats
    WR_REG,THS8200,0x01,0x74,0x00 // dtg_vdly_msb
    WR_REG,THS8200,0x01,0x75,0x07 // dtg_vdly_lsb
    WR_REG,THS8200,0x01,0x76,0x00 // dtg_vlength2_lsb
    WR_REG,THS8200,0x01,0x77,0xC7 // dtg_vdly2_msb
    WR_REG,THS8200,0x01,0x78,0xFF // dtg_vdly2_lsb
    WR_REG,THS8200,0x01,0x79,0x00 // dtg_hs_in_dly_msb   adjust for horizontal alignment
    WR_REG,THS8200,0x01,0x7A,0x0F // dtg_hs_in_dly_lsb
    WR_REG,THS8200,0x01,0x7B,0x00 // dtg_vs_in_dly_msb   adjust for vertical alignment
    WR_REG,THS8200,0x01,0x7C,0x00 // dtg_vs_in_dly_lsb
    WR_REG,THS8200,0x01,0x82,0x5B // pol_cntl   HS/VSin ++, HS/VSout++, FID -        adjust HS/VSout polarity for various formats
    THS8200
    Report Abuse
    • Reply
  • Chengping Huo
    on Mar 20 2011 08:21 AM
    Prodigy115 points
    Larry,
    Thank you very much!  I have success to implement VESA output.
    THS8200
    Report Abuse
    • Reply
  • easylwl
    Posted by easylwl
    on May 05 2011 02:28 AM
    Prodigy135 points
    I want to know how to set the dm365 output yuv422 data .  my project is the same with your , i use dm365 +ths8200+ths7303 output VGA 720p 。
    I can get the 720p VGA video now ,  but I found the color is wrong , like this !
    what wrong with me? please help me 。 thank you!
    VGA DM365 THS7303 THS8200 Linux
    Report Abuse
    • Reply
  • Larry Taylor
    on May 05 2011 14:27 PM
    Genius16810 points
    If you are trying to display VGA RGB from a YUV (YCbCr) input, you will need to use the color space convertere in the THS8200 to convert to RGB.  See the CSC setting below for YCbCr>RGB conversion.
    DATASET_NAME," YCbCr to RGB Using HDTV CSC coefficients and CSM for Output Scaling "
    //                                  //CSC setup for YCbCr to RGB Conversion.  HDTV CSC coefficients used
                                                     SA ,  Data
    //Map 64-940 RGB code range to 0-1023 full-scale range
    WR_REG,THS8200,0x01,0x45,0x53 // csm_clip_bcb_high
    WR_REG,THS8200,0x01,0x46,0x53 // csm_clip_rcr_high
    THS8200
    Report Abuse
    • Reply
  • easylwl
    Posted by easylwl
    on May 08 2011 22:51 PM
    Prodigy135 points
    thanks for your reply.
    I have already set the csc and csm, my ths8200 setting is
      //YCbR to RGB
      WR_REG,THS8200,0x01,0x34,0x06 // dtg_total_pixel_msb adjust for various graphics formats
      WR_REG,THS8200,0x01,0x35,0x72 // dtg_total_pixel_lsb
      WR_REG,THS8200,0x01,0x3A,0xEE // dtg_frame_size_lsb
      //CSM setup to map YCbCr to FS RGB
      WR_REG,THS8200,0x01,0x70,0x28 // dtg_hlength_lsb    adjust HSOUT width for various formats
      WR_REG,THS8200,0x01,0x71,0x01 // dtg_hdly_msb
      WR_REG,THS8200,0x01,0x72,0x4 // dtg_hdly_lsb
      WR_REG,THS8200,0x01,0x73,0x05 // dtg_vlength_lsb     adjust VSOUT width for various formats
      WR_REG,THS8200,0x01,0x74,0x02 // dtg_vdly_msb
      WR_REG,THS8200,0x01,0x75,0xED // dtg_vdly_lsb
      WR_REG,THS8200,0x01,0x77,0x07 // dtg_vdly2_msb
      WR_REG,THS8200,0x01,0x7A,0x0A // dtg_hs_in_dly_lsb
      WR_REG,THS8200,0x01,0x7A,0x32 // dtg_hs_in_dly_lsb
      WR_REG,THS8200,0x01,0x03,0x00
      mdelay(50);
    also when display white picture , the G channel wave picture is
    but the R and B channel wave picture is
    I think if the THS8200 is programed in the "RGB output with Sync signal inserted on G channel" mode?
    I want to know how to program   THS8200  in the "RGB output without Sync signal  insertion/General-Purpose Application DAC" mode?
    please help me!
    THS8200
    Report Abuse
    • Reply
  • Larry Taylor
    on May 09 2011 11:32 AM
    Genius16810 points
    Can you double check the REG 0x38 setting after the THS8200 is set up?  Sync insertion is disabled when the THS8200 is in VESA slave mode.  When your settings are used here, a sync tip is not present on the G output.
    Is it  possible that your settings are not being written to the THS8200, or that they are being over written by system software?
    THS8200
    Report Abuse
    • Reply
  • easylwl
    Posted by easylwl
    on May 09 2011 20:41 PM
    Prodigy135 points
    thanks for your reply !
    I have read out the REG 0x38 after write in 0x87;
     err |=i2c_smbus_write_byte_data(ths8200_client, THS8200_DTG1_MODE, 0x87);          //WR_REG,THS8200,0x01,0x38,0x87 // dtg_mode     VESA Slave
    printk ("DTG1_MODE=%x\n",i2c_smbus_read_byte_data(ths8200_client, THS8200_DTG1_MODE));
    printk vale is "0X87", that is mean 0X87 has been written to the THS8200 .
    now I know that about 350mv insert the  G channel  is not the Sync signal but the blank level ! I want to know how can I set the black level in blanking !
    I have tried to  set the blank REG to 0x00 ,
      WR_REG,THS8200,0x01,0x23,0x00 // dtg_y_sync_upper
      WR_REG,THS8200,0x01,0x24,0x00 // dtg_cbcr_sync_upper
    but that is still have 350mv in the G channel.
    but if I set the REG to :
    The  waveform is changed to R,G,B three channel all have 500mv blank level !
    I am crazy !!!   what is wrong ?? how can I set the black level (R,G,B three channel are all 0 mv)  in blanking ??
    THS8200
    Report Abuse
    • Reply
  • Larry Taylor
    on May 10 2011 12:06 PM
    Genius16810 points
    Do you have a DE signal that can be connected to the THS8200 FID pin?
    See the dtg2_fid_de_cntl description in REG 82h for using DE to force a blank level in VESA slave mode.
    THS8200
    Report Abuse
    • Reply
  • easylwl
    Posted by easylwl
    on May 10 2011 23:06 PM
    Prodigy135 points
    thank you very much!
    connect the DE singal to the FID pin ,then set the blank level REG
      WR_REG,THS8200,0x01,0x24,0x23 // dtg_cbcr_sync_upper
    then I can get the black blank level , and the color is right !
    set the 0x24 REG to 0x23 is very important ! If I set to 0x00 then the  350mv will be inserted in the G channel.  I don't konw why?
    thank you !
    THS8200
    Report Abuse
    • Reply
  • Helmut Forren
    Posted by Helmut Forren
    on Nov 30 2011 07:31 AM
    Mastermind6470 points
    Please note that I have no clue how the folks on this thread got to the point of configuring the THS8200, without also fixing up the VPIF driver and clock.  This must use some other platform, and some other _____ whatever.
    If you're searching for how to about VGA from a DM6467 based on the EVM, then here's how I did it:
    See http://e2e.ti.com/support/embedded/f/354/p/149931/542030.aspx#542030
    Report Abuse
    • Reply
TI E2E™ Community
  • Support Forums
  • Blogs
  • Videos
  • Groups
  • Site Support & Feedback
  • Settings
TI E2E™ Community Groups
  • TI University Program
  • Make the Switch
  • Microcontroller Projects
  • Motor Drive & Control
Other Communities
  • Deyisupport
  • Designsomething.org
  • beagleboard.org
  • TI on Element 14
  • TI on TechXchangeSM
Other Technical & Support Resources
  • WEBENCH® Design Center
  • Product Information Centers
  • Technical Documents
  • TI Design Network
  • TI Technical Articles
  • TI Training
All content and materials on this site are provided "as is". TI and its respective suppliers and providers of content make no representations about the suitability of these materials for any purpose and disclaim all warranties and conditions with regard to these materials, including but not limited to all implied warranties and conditions of merchantability, fitness for a particular purpose, title and non-infringement of any third party intellectual property right. TI and its respective suppliers and providers of content make no representations about the suitability of these materials for any purpose and disclaim all warranties and conditions with respect to these materials. No license, either express or implied, by estoppel or otherwise, is granted by TI. Use of the information on this site may require a license from a third party, or a license from TI.
Content on this site may contain or be subject to specific guidelines or limitations on use. All postings and use of the content on this site are subject to the Terms of Use of the site; third parties using this content agree to abide by any limitations or guidelines and to comply with the Terms of Use of this site. TI, its suppliers and providers of content reserve the right to make corrections, deletions, modifications, enhancements, improvements and other changes to the content and materials, its products, programs and services at any time or to move or discontinue any content, products, programs, or services without notice.
Follow Us Texas Instruments on Facebook Texas Instruments on Twitter Texas Instruments on LinkedIn Texas Instruments on Google+
TI Worldwide | Contact Us | my.TI Login | Site Map | Corporate Citizenship | mobile m.ti.com (Mobile Version)
TI is a global semiconductor design and manufacturing company. Innovate with 100,000+ analog ICs and
embedded processors, along with software, tools and the industry’s largest sales/support staff.
© Copyright 1995-2013 Texas Instruments Incorporated. All rights reserved.
Trademarks | Privacy Policy | Terms of Use
