I am developing an UVC solution using TVP5150AM1. I am successfully getting NTSC video but there are color issues. When there's white text on black
background visible amount of color flickering and false color happens as seen from the image.
I've tried lowering saturation with considerable success but color quality is then sacrificed. Also, I have a pull-up resistor on pin 27 and after startup I enable VBLK so it should probably not be and issue. Is there something else I can do? I am using comb filters enabled by default
