• Join
  • Sign In with my.TI Login
Texas Instruments
  • Products
  • Applications
  • Tools & Software
  • Support & Community
  • Sample & Buy
  • About TI
Sample & Purchase Cart Sample & Purchase Cart
  • Search
  • Advanced
TI E2E™ Community
  • Support Forums
  • Blogs
  • Groups
  • Videos
  • 简体中文
  • More ...
TI Home » TI E2E Community » Support Forums » Development Tools » Code Composer Studio » Code Composer Forum » TI devboard does not works with CCS5.1
Share
  • Forum
  • Announcements
Options
  • Subscribe via RSS
Common Questions
  • Code Composer Studio Forum Usage Guidelines
  • Resources
  • Code Composer Studio (CCStudio) Product Folder
  • Troubleshooting CCS
  • CCS Wiki
  • Download CCS
  • Order CCS
  • Tools Insider Blog
  • Bug Tracking
  • TI devboard does not works with CCS5.1
    This question is answered
    Brown59592
    Posted by Brown59592
    on Jan 27 2012 03:55 AM
    Expert1050 points
    Hi
    Just received a brand new devboard: MSP-TS430PZ100 (http://www.ti.com/tool/msp-ts430pz100)
    Every jumper is left as it is from factory (J6,J7 on), no external power, just the FET430UIF connected to the JTAG port.
    Brand new MSP430F4784 introduced in it.
    CCS5.1: Error connecting to the target: Unknown device
    CCS4.2: Programming works well - no problem.
    So it's not a hardware design as it was suggested on this link: http://e2e.ti.com/support/development_tools/code_composer_studio/f/81/t/155664.aspx
    since the TI devboard reacts in the same way - doesn't work with CCS5.1, v3 FET-UIF firmware
    Might be it's the power failure bug mentioned by Lisa in the previous link but I would need to know what is happening since this issue is a showstopper in our development. I have doubts about power failure since the AFE253 board works well with CCS5.1 with power from the FET-UIF (same 4 fire jtag setup).
    Tried Andreas's fix as well from this link: http://e2e.ti.com/support/microcontrollers/msp43016-bit_ultra-low_power_mcus/f/166/t/155784.aspx
    The results are the same - probably it fixes only for BT5xxx family (if it does).
    Regards, B.
    Report Abuse
    • Reply
    You have posted to a forum that requires a moderator to approve posts before they are publicly available.
    All Replies
    • Lisa TI
      Posted by Lisa TI
      on Jan 27 2012 07:43 AM
      Guru100125 points
      It seems what you are could be symptomatic of dll v2 vs v3.
      Did CCSv5 ask to update the firmware on your FET?  Did you do the update? Have you tried updating to v3 using the upgrade/downgrade utility?
      Please see this wiki:
      http://processors.wiki.ti.com/index.php/MSP_Debug_Stack
      Please keep us informed.  If it is not the version we will keep digging.
      LIsa
      Report Abuse
      • Reply
    • Brown59592
      on Jan 27 2012 07:53 AM
      Expert1050 points
      The FET was updated automatically by CCSv5.1.
      I have installed the Elprotronic Lite FetPro430 which shows the version of the firmware and it shows v3 firmware (3.02.01.009).
      Also tried v3.02.03.002 from the Elprotronic package - same results (not working).
      So the problem appears only with v3 dll's while v2 works.
      We need to buy asap the CCS (tests were done with the free version) and we cannot proceed until we are sure it works for this MCU which is the target for our development.
      It is possible to buy older versions (like 4.2) than upgrade it for 5.1 when TI fixes this issue?
      Brown
      Report Abuse
      • Reply
    • Lisa TI
      Posted by Lisa TI
      on Jan 27 2012 08:07 AM
      Guru100125 points
      Hi Brown,
      ok so it seems like it is then most likely the power issue or the device got lost in the support like the BT5190 unfortunately.  I will have this looked into.
      In the mean time you can purchase and download a license to work with CCSv4.    This comes with a 1 year subscription which would allow you to upgrade to a v5 license in the future.  MOre information on this can be found here:
      http://processors.wiki.ti.com/index.php/Licensing_-_CCS
      Lisa
      Report Abuse
      • Reply
    • Lisa TI
      Posted by Lisa TI
      on Jan 30 2012 13:36 PM
      Verified Answer
      Verified by Lisa TI
      Guru100125 points
      Hi Brown,
      I have been able to confirm your device is also problematic in the v3 dll and is not fixed by the current patch you already tried.
      It seems like someone from the MSP team is likely to touch base with you briefly offline about this.
      Sorry once again for the inconvenience.   I will close the case for now as this is a known issue.
      Lisa
      Report Abuse
      • Reply
    • Louis Kovach
      Posted by Louis Kovach
      on Mar 29 2012 09:19 AM
      Prodigy240 points
      Hello TI,
      I appear to have the same issue. I get a unknown device error when I connect my debugger to the same dev board using 5.1.  Could you post the resolution to this problem as the resolution appears to have taken place off line?
      Lou
      Report Abuse
      • Reply
    TI E2E™ Community
    • Support Forums
    • Blogs
    • Videos
    • Groups
    • Site Support & Feedback
    • Settings
    TI E2E™ Community Groups
    • TI University Program
    • Make the Switch
    • Microcontroller Projects
    • Motor Drive & Control
    Other Communities
    • Deyisupport
    • Designsomething.org
    • beagleboard.org
    • TI on Element 14
    • TI on TechXchangeSM
    Other Technical & Support Resources
    • WEBENCH® Design Center
    • Product Information Centers
    • Technical Documents
    • TI Design Network
    • TI Technical Articles
    • TI Training
    All content and materials on this site are provided "as is". TI and its respective suppliers and providers of content make no representations about the suitability of these materials for any purpose and disclaim all warranties and conditions with regard to these materials, including but not limited to all implied warranties and conditions of merchantability, fitness for a particular purpose, title and non-infringement of any third party intellectual property right. TI and its respective suppliers and providers of content make no representations about the suitability of these materials for any purpose and disclaim all warranties and conditions with respect to these materials. No license, either express or implied, by estoppel or otherwise, is granted by TI. Use of the information on this site may require a license from a third party, or a license from TI.
    Content on this site may contain or be subject to specific guidelines or limitations on use. All postings and use of the content on this site are subject to the Terms of Use of the site; third parties using this content agree to abide by any limitations or guidelines and to comply with the Terms of Use of this site. TI, its suppliers and providers of content reserve the right to make corrections, deletions, modifications, enhancements, improvements and other changes to the content and materials, its products, programs and services at any time or to move or discontinue any content, products, programs, or services without notice.
    Follow Us Texas Instruments on Facebook Texas Instruments on Twitter Texas Instruments on LinkedIn Texas Instruments on Google+
    TI Worldwide | Contact Us | my.TI Login | Site Map | Corporate Citizenship | mobile m.ti.com (Mobile Version)
    TI is a global semiconductor design and manufacturing company. Innovate with 100,000+ analog ICs and
    embedded processors, along with software, tools and the industry’s largest sales/support staff.
    © Copyright 1995-2013 Texas Instruments Incorporated. All rights reserved.
    Trademarks | Privacy Policy | Terms of Use
