Texas Instruments
  • Samples Cart - Add Samples Samples & Purchase Cart
  • Contact Us
  • TI Worldwide: United States
  • my.TI Login
  • Products
  • Applications
  • Design Support
  • Sample & Buy
  • All Searches
TI Home » TI E2E Community » Support Forums » Development Tools » Code Composer Studio » Code Composer Forum » Unable to find/install TI Simulator
  • Join
  • Sign In with my.TI Login
TI E2E™ Community
  • Home
  • Support Forums
  • Videos
  • Blogs
  • Groups
  • More ...
  • Go
  • Advanced Search
Share
Details
Rate This
  • 3 Replies
  • 3 Subscribers
  • 344 Views
  • Posted3 months ago
Options
  • Subscribe via RSS
Helpful Links
  • Troubleshooting CCS
  • CCS Wiki
  • Download CCS
  • Order CCS
  • Tools Insider Blog
  • Bug Tracking
  • Common Questions
  • Code Composer Studio Forum Usage Guidelines
  • Latest Blog Posts:
  • HALCoGen makes software development easier on Hercules™ safety microcontrollers
  • DESIGN West attendees "dug" the 'Bone this week!
  • TI has caught March Madness fever. And you can, too!
  • Make your MSP430 LaunchPad Rock!
  • Sharing our expertise at Android Builders Summit
  • Forum - Title
    Welcome to the Code Composer Studio Section of the TI E2E Support Community. Ask questions, share knowledge, explore ideas, and help solve problems with fellow engineers. To post a question, click on the forum tab then "New Post".
    • Get this RSS feed
    • Home
    • Announcements
    • Forum
    New Post
    • Jaco Schutte
      Posted by Jaco Schutte
      on Feb 11, 2012 6:43 AM
      Prodigy20 points
      Hi!
      Could someone please help me. I installed code compose 5.1 with a free license. I started a new project using the TSM320C6455.
      The thing is, when I tried to choose a connector, the TI Simulator option is not there? I thought, maybe I should install it separately by going to Help -> Install new software, but
      when I choose TI Simulators - http://software-dl.ti.com/dsps/dsps_public_sw/sdo_ccstudio/CCSv5/Updates/simulation/p2win32, it says that there are no items available?
      So I chose the --All Available Sites-- option and checked "hide items that are already installed", the TI Simulator's not in the list, that means that it is installed? Right?
      Please could someone help me, I'm new to the environment and just cant seem to find the TI Simulator? TIA!
      Jaco :)
      TI Simulator TSM320C6455
      Report Abuse
      • Reply
      You have posted to a forum that requires a moderator to approve posts before they are publicly available.
    • JohnS
      Posted by JohnS
      on Feb 11, 2012 8:37 PM
      Mastermind49480 points
      Jaco,
      If when you create a new target configuration if TI Simulator is not listed as an option then it is likely that you didn't select simulation when installing.  You can run the installer again to add features to your existing installation.  Just run the installer and point it to your existing install.
      John
      If my reply answers your question please mark the thread as answered
      Report Abuse
      • Reply
    • Jaco Schutte
      on Feb 12, 2012 2:24 AM
      Prodigy20 points
      Hey John!
      Thanks for the advice. I tried it, and the simulator seems to have been selected during the install (but I just ran it again to make sure).
      Still I'm unable to see it, then I changed the device to TMS320C671X, sure enough this has the TI simulator as an option. Is it just that the TMS320C64XX does not have a simulator for CCS 5 (is this an older development kit?).
      One more thing, I tried running the hello world project with the TMS320C671XX's simulator but then I got this error: TMS320C671X: Can't Initialize Target CPU: Error in getting the config file(ESS).
      Thanks for the help.
      Jaco
      Report Abuse
      • Reply
    • JohnS
      Posted by JohnS
      on Feb 12, 2012 6:06 PM
      Jaco,
      Working with a simulator is a little different than real hw.  Normally when you use the project wizard to create a new project you select your device and the type of JTAG emulator you are using and then it also generates the debugger/target configuration file (.ccxml) as part of your project.  For simulators it does not work this way as there is no 1 to 1 matching of device to simulator.  If you created a project for a simulator you will need to double click on the .ccxml file afterwards (if there is no .ccxml file in your project just right click on the project and select new->target configuration).  Double clicking on it will open the file in a special editor.  The first drop box is the connection type.  Scroll down and select TI simulator.  The box below this is the device/board selection.  For simulators this will list the various simulators that are available.  In general the TI strategy is to point users to low cost development kits instead of simulators so you will see the number of simulators in CCS decrease over time.
      Are you running 5.1.0 or 5.1.1?  In the 5.1.1 build that is on the web right now some of the simulators don't show up in the target configuration tool automatically (there will be an updated build later this week that corrects that).  You can still access them if you click on the Advanced tab down at the bottom and then click on the Import button on the right hand side.  Some of the simulators that are no longer actively maintained were moved into a different folder that causes them not to show up in the first screen.
      John
      Report Abuse
      • Reply
    Share
    ALL CONTENT AND MATERIALS ON THIS SITE ARE PROVIDED "AS IS". TI AND ITS RESPECTIVE SUPPLIERS AND PROVIDERS OF CONTENT MAKE NO REPRESENTATIONS ABOUT THE SUITABILITY OF THESE MATERIALS FOR ANY PURPOSE AND DISCLAIM ALL WARRANTIES AND CONDITIONS WITH REGARD TO THESE MATERIALS, INCLUDING BUT NOT LIMITED TO ALL IMPLIED WARRANTIES AND CONDITIONS OF MERCHANTABILITY, FITNESS FOR A PARTICULAR PURPOSE, TITLE AND NON-INFRINGEMENT OF ANY THIRD PARTY INTELLECTUAL PROPERTY RIGHT. TI AND ITS RESPECTIVE SUPPLIERS AND PROVIDERS OF CONTENT MAKE NO REPRESENTATIONS ABOUT THE SUITABILITY OF THESE MATERIALS FOR ANY PURPOSE AND DISCLAIM ALL WARRANTIES AND CONDITIONS WITH RESPECT TO THESE MATERIALS. NO LICENSE, EITHER EXPRESS OR IMPLIED, BY ESTOPPEL OR OTHERWISE, IS GRANTED BY TI. USE OF THE INFORMATION ON THIS SITE MAY REQUIRE A LICENSE FROM A THIRD PARTY, OR A LICENSE FROM TI.
    Content on this site may contain or be subject to specific guidelines or limitations on use. All postings and use of the content on this site are subject to the Terms of Use of the site; third parties using this content agree to abide by any limitations or guidelines and to comply with the Terms of Use of this site. TI, its suppliers and providers of content reserve the right to make corrections, deletions, modifications, enhancements, improvements and other changes to the content and materials, its products, programs and services at any time or to move or discontinue any content, products, programs, or services without notice.
    Products | Applications | Design Support | Sample & Buy RSS
    TI Worldwide | About TI | Contact Us | Investor Relations | Press Center | Corporate Citizenship | Careers | Tags | my.TI Login | All Searches | Site Map
    © Copyright 1995- Texas Instruments Incorporated. All rights reserved. Trademarks | Privacy Policy | Terms of Use
