• Join
  • Sign In with my.TI Login
Texas Instruments
  • Products
  • Applications
  • Tools & Software
  • Support & Community
  • Sample & Buy
  • About TI
Sample & Purchase Cart Sample & Purchase Cart
  • Search
  • Advanced
TI E2E™ Community
  • Support Forums
  • Blogs
  • Groups
  • Videos
  • 简体中文
  • More ...
TI Home » TI E2E Community » Support Forums » Development Tools » Code Composer Studio » Code Composer Forum » why "memory access not attempted by the driver" ?
Share
  • Forum
  • Announcements
Options
  • Subscribe via RSS
Common Questions
  • Code Composer Studio Forum Usage Guidelines
  • Resources
  • Code Composer Studio (CCStudio) Product Folder
  • Troubleshooting CCS
  • CCS Wiki
  • Download CCS
  • Order CCS
  • Tools Insider Blog
  • Bug Tracking
  • why "memory access not attempted by the driver" ?
    This question is not answered
    xunliang ma
    Posted by xunliang ma
    on Mar 21 2012 05:26 AM
    Intellectual285 points
    Hi all
          I look for my ROM revision on the OMAP-L138EVM( logic PD ) refering the instruction in SPRAB41D《Using the OMAP-L132/L138 Bootloader》,after connect the EVM to my PC,  i find nothing on the memory window as below.
                   so i want to know why i can't view the memory value?is that need more setting on CCS4.2? or i need to change my GEL file? my GEL file was copy from the SD card on OMAP-L138EVM ,which is " ****\OMAP-L138_GEL_BSL_Files_v2.3\gel\OMAPL138_ARM.gel".
                  besides, every time when i connect  the  EVM to my PC, there will be a box as below , it show "the GEL callback "ontargetconnect"......is still processing", so i think the problem above may be cause by it, am i correct? and how can i get the correct GEL file if my GEL file is incorrect?
    regards
    xunliang
    omapl138 CCS4 memory access
    Report Abuse
    • Reply
    You have posted to a forum that requires a moderator to approve posts before they are publicly available.
    All Replies
    • Ki-Soo Lee
      Posted by Ki-Soo Lee
      on Mar 21 2012 11:26 AM
      Guru116780 points
      Hello xunliang,
      xunliang ma
      It is displaying the contents of memory. You have 'Character' selected for the format type. hence it is trying to display the ASCII value (showing "NULL" for '0x0'). Change the format type to see the actual value.
      xunliang ma
      I believe this is a known issue when using XDS100v1 with the L138. Because of the slow performance of the XDS100v1, some actions in the OnTargetConnect routine may timeout and that dialog can pop-up.
      However I don't see that issue with my 4.2.5 install. If you are not using 4.2.5, you may want to try updating to that and see if it helps.
      ki
      Don't forget to verify answers to your forum questions by using the green "Verify Answer" button.
      Did you read the CCS Forum Guidelines & FAQ? If not, PLEASE read it. If you haven't read it in awhile, please read it again to see if any updates were made.
      Having CCSv5 problems? Check out the CCSv5 Troubleshooting Guide
      Click here to track an issue. Enter your bug id in the "Find Record ID" box
      Report Abuse
      • Reply
    • xunliang ma
      on Mar 21 2012 19:38 PM
      HI  ki
      "It is displaying the contents of memory. You have 'Character' selected for the format type. hence it is trying to display the ASCII value (showing "NULL" for '0x0'). Change the format type to see the actual value."
      i have tried  all format type and find that it no use, it display all "0", such as the figure below. how it can be this?
      Report Abuse
      • Reply
    • xunliang ma
      on Mar 22 2012 01:07 AM
      besides, when i run my program and put my mouse on the dot, it will display:"memory request failed[adrs 0xfffd0000-0xfffd0000]  memory update info.is aborted = ture", like the figure below:
      my CCS revision is 4.2.0, need i update it to the latest revision?
      Report Abuse
      • Reply
    TI E2E™ Community
    • Support Forums
    • Blogs
    • Videos
    • Groups
    • Site Support & Feedback
    • Settings
    TI E2E™ Community Groups
    • TI University Program
    • Make the Switch
    • Microcontroller Projects
    • Motor Drive & Control
    Other Communities
    • Deyisupport
    • Designsomething.org
    • beagleboard.org
    • TI on Element 14
    • TI on TechXchangeSM
    Other Technical & Support Resources
    • WEBENCH® Design Center
    • Product Information Centers
    • Technical Documents
    • TI Design Network
    • TI Technical Articles
    • TI Training
    All content and materials on this site are provided "as is". TI and its respective suppliers and providers of content make no representations about the suitability of these materials for any purpose and disclaim all warranties and conditions with regard to these materials, including but not limited to all implied warranties and conditions of merchantability, fitness for a particular purpose, title and non-infringement of any third party intellectual property right. TI and its respective suppliers and providers of content make no representations about the suitability of these materials for any purpose and disclaim all warranties and conditions with respect to these materials. No license, either express or implied, by estoppel or otherwise, is granted by TI. Use of the information on this site may require a license from a third party, or a license from TI.
    Content on this site may contain or be subject to specific guidelines or limitations on use. All postings and use of the content on this site are subject to the Terms of Use of the site; third parties using this content agree to abide by any limitations or guidelines and to comply with the Terms of Use of this site. TI, its suppliers and providers of content reserve the right to make corrections, deletions, modifications, enhancements, improvements and other changes to the content and materials, its products, programs and services at any time or to move or discontinue any content, products, programs, or services without notice.
    Follow Us Texas Instruments on Facebook Texas Instruments on Twitter Texas Instruments on LinkedIn Texas Instruments on Google+
    TI Worldwide | Contact Us | my.TI Login | Site Map | Corporate Citizenship | mobile m.ti.com (Mobile Version)
    TI is a global semiconductor design and manufacturing company. Innovate with 100,000+ analog ICs and
    embedded processors, along with software, tools and the industry’s largest sales/support staff.
    © Copyright 1995-2013 Texas Instruments Incorporated. All rights reserved.
    Trademarks | Privacy Policy | Terms of Use
