• Join
  • Sign In with my.TI Login
Texas Instruments
  • Products
  • Applications
  • Tools & Software
  • Support & Community
  • Sample & Buy
  • About TI
Sample & Purchase Cart Sample & Purchase Cart
  • Search
  • Advanced
TI E2E™ Community
  • Support Forums
  • Blogs
  • Groups
  • Videos
  • 简体中文
  • More ...
TI Home » TI E2E Community » Support Forums » Development Tools » Code Composer Studio » Code Composer Forum » cannot import the examples CCSv5.1
Share
  • Forum
  • Announcements
Options
  • Subscribe via RSS
Common Questions
  • Code Composer Studio Forum Usage Guidelines
  • Resources
  • Code Composer Studio (CCStudio) Product Folder
  • Troubleshooting CCS
  • CCS Wiki
  • Download CCS
  • Order CCS
  • Tools Insider Blog
  • Bug Tracking
  • cannot import the examples CCSv5.1
    • hasan huseyin
      Posted by hasan huseyin
      on Apr 09 2012 14:23 PM
      Prodigy220 points
      hi,
      i installed CCSv5.1 and peripheral examples for F28035 control card. but i cannot import any of the examples to CCS.
      i copy the directory of an example file and paste it into 'import existing ccs exlipse project' browser. but it gives this error. i installed complete set of CCS twice but the result is the same.
      Report Abuse
      • Reply
      You have posted to a forum that requires a moderator to approve posts before they are publicly available.
    • Lisa TI
      Posted by Lisa TI
      on Apr 09 2012 14:28 PM
      Guru99245 points
      HI Hasan,
      when you installed CCS, did you install C2000 support?  What C2000 compiler versions do you have in your isntallation?  You can see this if you go to Window->Preferences->COde Composer Studio->Build->COde Generation TOols.   COuld you please send a screen shot.
      What if you do not copy anything?  Please try Project->Import exsisting CCS/Eclipse project and do it that way by browsing to the example in its original form.  What if you try to bring in the example from the TI Resource Explorer?
      Do you get asked if you wish to migrate the project to newer code generation tool version?
      A few further details will help us here so that we can try to get you working with the example/CCS.
      Lisa
      Report Abuse
      • Reply
    • hasan huseyin
      on Apr 10 2012 09:15 AM
      Prodigy220 points
      this is the screenshot of the compilers you asked. i tried to import the project by browsing, but it's the same error again, also when i tried to use resource explorer.
      this is the only error/warning it shows, nothing else.
      Report Abuse
      • Reply
    • Lisa TI
      Posted by Lisa TI
      on Apr 10 2012 09:29 AM
      Guru99245 points
      Hi Hasan,
      ok I believe you are getting this error because the example was created with C2000 code generation(compiler) v5.2 and you only seem to have an old 4.x version of the C2000 compiler.  CCS can convert to a newer version but can not convert back to an older one.  This is the problem.
      So you need to get compiler v5.2 or newer.  Could you please go to
      Help->Check for Updates and please see what code generation and emulation updates you have.  Please try to get the newer compiler version this way.
      Keep us informed how that goes.
      Lisa
      Report Abuse
      • Reply
    • hasan huseyin
      on Apr 10 2012 10:23 AM
      Prodigy220 points
      i did the updates and installed them as you told, but it shows the same message. checked for the updates again, there's nothing to update anymore.
      what should i do now? this is the new screenshot of the list.
      Report Abuse
      • Reply
    • Lisa TI
      Posted by Lisa TI
      on Apr 10 2012 10:29 AM
      Guru99245 points
      Hi Hasan,
      so there were no C2000 updates found at all?  No updates at all?  Ok, please try through Help->Install New Software and in the drop down menu select "all available sites".  Please let me know what you see/check whether you can get the C2000 update there.
      While you double check that I am going to check here whether I will be able to send you a newer version offline.  We unfortunately don't have the full version of the C2000 compiler posted, so I would need permission to send this out.
      Once again, please keep us informed.
      Lisa
      Report Abuse
      • Reply
    • hasan huseyin
      on Apr 10 2012 11:27 AM
      Prodigy220 points
      i think i cannot get the update by this way...
      Report Abuse
      • Reply
    • Lisa TI
      Posted by Lisa TI
      on Apr 10 2012 11:35 AM
      Guru99245 points
      Hi Hasan,
      look under C2000 Device support and TI Emulation and let me know.
      Lisa
      Report Abuse
      • Reply
    • hasan huseyin
      on Apr 10 2012 12:23 PM
      Prodigy220 points
      i'm not sure if this is what you asked?
      Report Abuse
      • Reply
    • Lisa TI
      Posted by Lisa TI
      on Apr 10 2012 12:26 PM
      Guru99245 points
      Hi Hasan,
      yes please give that a try.  If it does not update your compiler version, please send me a friend or conversation request and I will send it offline.
      Lisa
      Report Abuse
      • Reply
    • hasan huseyin
      on Apr 10 2012 12:29 PM
      Prodigy220 points
      okay, i sent the request, thank you.
      Report Abuse
      • Reply
    • Lisa TI
      Posted by Lisa TI
      on Apr 10 2012 13:18 PM
      Guru99245 points
      HI Hasan,
      i just sent it offline.  Keep me informed.
      Lisa
      Report Abuse
      • Reply
    • hasan huseyin
      on Apr 11 2012 15:03 PM
      Prodigy220 points
      i recieved your mail, but i don't know how to open an ftp session, i've tried the link at the bottom, it asked userid and password, entered them, but it cannot connect to ti.com.
      if you please help a little more, i'll be grateful.
      Report Abuse
      • Reply
    • Lisa TI
      Posted by Lisa TI
      on Apr 11 2012 15:07 PM
      Guru99245 points
      HI Hasan,
      I am not sure there is anything else I can do.  Try from a command prompt.  ftp ftppickup.ti.com ..etc ... all instructions are in what I send ... ID, password it is step by step all there.
      Keep us informed.
      Lisa
      Report Abuse
      • Reply
    • hasan huseyin
      on Apr 12 2012 13:39 PM
      Prodigy220 points
      okay, i got the file finally and installed it. i still get the same error. i run the setup file to install and chose the ti folder for installation directory.
      is there any other way to install it?
      Report Abuse
      • Reply
    123
    TI E2E™ Community
    • Support Forums
    • Blogs
    • Videos
    • Groups
    • Site Support & Feedback
    • Settings
    TI E2E™ Community Groups
    • TI University Program
    • Make the Switch
    • Microcontroller Projects
    • Motor Drive & Control
    Other Communities
    • Deyisupport
    • Designsomething.org
    • beagleboard.org
    • TI on Element 14
    • TI on TechXchangeSM
    Other Technical & Support Resources
    • WEBENCH® Design Center
    • Product Information Centers
    • Technical Documents
    • TI Design Network
    • TI Technical Articles
    • TI Training
    All content and materials on this site are provided "as is". TI and its respective suppliers and providers of content make no representations about the suitability of these materials for any purpose and disclaim all warranties and conditions with regard to these materials, including but not limited to all implied warranties and conditions of merchantability, fitness for a particular purpose, title and non-infringement of any third party intellectual property right. TI and its respective suppliers and providers of content make no representations about the suitability of these materials for any purpose and disclaim all warranties and conditions with respect to these materials. No license, either express or implied, by estoppel or otherwise, is granted by TI. Use of the information on this site may require a license from a third party, or a license from TI.
    Content on this site may contain or be subject to specific guidelines or limitations on use. All postings and use of the content on this site are subject to the Terms of Use of the site; third parties using this content agree to abide by any limitations or guidelines and to comply with the Terms of Use of this site. TI, its suppliers and providers of content reserve the right to make corrections, deletions, modifications, enhancements, improvements and other changes to the content and materials, its products, programs and services at any time or to move or discontinue any content, products, programs, or services without notice.
    Follow Us Texas Instruments on Facebook Texas Instruments on Twitter Texas Instruments on LinkedIn Texas Instruments on Google+
    TI Worldwide | Contact Us | my.TI Login | Site Map | Corporate Citizenship | mobile m.ti.com (Mobile Version)
    TI is a global semiconductor design and manufacturing company. Innovate with 100,000+ analog ICs and
    embedded processors, along with software, tools and the industry’s largest sales/support staff.
    © Copyright 1995-2013 Texas Instruments Incorporated. All rights reserved.
    Trademarks | Privacy Policy | Terms of Use
