• Join
  • Sign In with my.TI Login
Texas Instruments
  • Products
  • Applications
  • Tools & Software
  • Support & Community
  • Sample & Buy
  • About TI
Sample & Purchase Cart Sample & Purchase Cart
  • Search
  • Advanced
TI E2E™ Community
  • Support Forums
  • Blogs
  • Groups
  • Videos
  • 简体中文
  • More ...
TI Home » TI E2E Community » Support Forums » Development Tools » Code Composer Studio » Code Composer Forum » Compiler definition is not available
Share
  • Forum
  • Announcements
Options
  • Subscribe via RSS
Common Questions
  • Code Composer Studio Forum Usage Guidelines
  • Resources
  • Code Composer Studio (CCStudio) Product Folder
  • Troubleshooting CCS
  • CCS Wiki
  • Download CCS
  • Order CCS
  • Tools Insider Blog
  • Bug Tracking
  • Compiler definition is not available
    • Paul 50485
      Posted by Paul 50485
      on Apr 25 2012 17:17 PM
      Expert1705 points
      Hi
      I am trying to import a CCS4 project into CCS5 and the error below comes up
      Error: Import failed for project -compiler definition is not available
      Any suggestion on how to fix this? I am using Stellaris ARM and it looks like the compiler is listed in window/ preferences/ build/compiler Discovered tools - tms470
      Paul
      Report Abuse
      • Reply
      You have posted to a forum that requires a moderator to approve posts before they are publicly available.
    • Lisa TI
      Posted by Lisa TI
      on Apr 25 2012 19:49 PM
      Guru100145 points
      Hi Paul,
      when you installed CCSv5 - did you install Stellaris support|?  what version of v5 are we talking about?  What OS?
      This message seems to indicate it can't find the compiler tools.
      What do you see if you go to Window->Preferences->Code Composer Studio->Build->Code generation tools?
      what if you try pointing CCSv5 to the compiler version from CCSv4?
      Please keep us informed.
      Lisa
      Report Abuse
      • Reply
    • Paul 50485
      on Apr 26 2012 16:45 PM
      Expert1705 points
      Lisa,
      Yes I installed Stellaris support. I think that is the only option I choose. Version 5.1.1.00031
      Report Abuse
      • Reply
    • Paul 50485
      on Apr 26 2012 16:49 PM
      Expert1705 points
      2nd attempt to paste
      Report Abuse
      • Reply
    • Lisa TI
      Posted by Lisa TI
      on Apr 27 2012 07:54 AM
      Guru100145 points
      Hi Paul,
      how did you attempt to import the project?  Did you go to Project->Import existing CCS/Eclipse Project?  What version compilers do you have in v4 and v5?  Did you try pointing v5 to the v4 compiler version as I suggested?
      Lisa
      Report Abuse
      • Reply
    • Paul 50485
      on Apr 27 2012 11:05 AM
      Expert1705 points
      Hi Lisa,
      Yes Project, Import Existing CCS/Eclipse Project. I also added my old compiler to version 5 see below.  Old CCS version is 4.2.1.00004
      Paul
      Version 5 below:
      Report Abuse
      • Reply
    • Lisa TI
      Posted by Lisa TI
      on Apr 27 2012 12:47 PM
      Guru100145 points
      Hi Paul,
      when do you get the error?  Do you still get the error?  Would you be willing to send the project offline?  It seems your compiler tools are correctly installed ...
      Lisa
      Report Abuse
      • Reply
    • Paul 50485
      on Apr 27 2012 13:15 PM
      Expert1705 points
      Lisa,
      I still get the error. I have run many versions of CCS4 with no problem. I did run an early version of CCS 5. Maybe this was not fully uninstalled?
      Report Abuse
      • Reply
    • Lisa TI
      Posted by Lisa TI
      on Apr 27 2012 13:50 PM
      Guru100145 points
      Hi Paul,
      possibly, you could try reinstalling the latest release into a different directory.  But what import steps did you take?  What I mean more is .. when exactly does this error occur?  Screenshot?  Any error logs?  If you wish to send your project offline, we can try to reproduce the issue here.
      Lisa
      Report Abuse
      • Reply
    • Paul 50485
      on Apr 27 2012 16:54 PM
      Expert1705 points
      Hi Lisa,
      I installed CCS5 on my notebook computer and I receive the same error, See Screenshot. What files do you need for a project?
      Report Abuse
      • Reply
    • Lisa TI
      Posted by Lisa TI
      on Apr 27 2012 17:51 PM
      Guru100145 points
      Hi Paul,
      what exact example or project are you trying to import?  Could you send the project offline (friend or conversation request)  Is it a C6000/DSP project?  If so, you have no C6000 support installed.  Rerunning the installer will let you add this.
      You could give that a try in the mean time.
      Lisa
      Report Abuse
      • Reply
    • Paul 50485
      on Apr 30 2012 13:33 PM
      Expert1705 points
      My projects are Stellaris ARM. What files do you need, I prefer not to send all of my source files
      Paul
      Report Abuse
      • Reply
    • Lisa TI
      Posted by Lisa TI
      on Apr 30 2012 15:20 PM
      Guru100145 points
      Hi Paul, before we do that there is one thing I just noticed.
      I think the problem is that you are using the wrong import utility.
      Please create a fresh workspace and make sure to import with Project->Import existing CCS/Eclipse Project ..
      Lisa
      Report Abuse
      • Reply
    • Paul 50485
      on Apr 30 2012 16:01 PM
      Expert1705 points
      Hi Lisa,
      Same results, see below. I was able to create a new project and compile the code
      Paul
      Report Abuse
      • Reply
    • Lisa TI
      Posted by Lisa TI
      on May 01 2012 08:20 AM
      Guru100145 points
      Hi Paul,
      so is everything imported and building fine now?   The above looks much better as far as an import.
      Lisa
      Report Abuse
      • Reply
    123
    TI E2E™ Community
    • Support Forums
    • Blogs
    • Videos
    • Groups
    • Site Support & Feedback
    • Settings
    TI E2E™ Community Groups
    • TI University Program
    • Make the Switch
    • Microcontroller Projects
    • Motor Drive & Control
    Other Communities
    • Deyisupport
    • Designsomething.org
    • beagleboard.org
    • TI on Element 14
    • TI on TechXchangeSM
    Other Technical & Support Resources
    • WEBENCH® Design Center
    • Product Information Centers
    • Technical Documents
    • TI Design Network
    • TI Technical Articles
    • TI Training
    All content and materials on this site are provided "as is". TI and its respective suppliers and providers of content make no representations about the suitability of these materials for any purpose and disclaim all warranties and conditions with regard to these materials, including but not limited to all implied warranties and conditions of merchantability, fitness for a particular purpose, title and non-infringement of any third party intellectual property right. TI and its respective suppliers and providers of content make no representations about the suitability of these materials for any purpose and disclaim all warranties and conditions with respect to these materials. No license, either express or implied, by estoppel or otherwise, is granted by TI. Use of the information on this site may require a license from a third party, or a license from TI.
    Content on this site may contain or be subject to specific guidelines or limitations on use. All postings and use of the content on this site are subject to the Terms of Use of the site; third parties using this content agree to abide by any limitations or guidelines and to comply with the Terms of Use of this site. TI, its suppliers and providers of content reserve the right to make corrections, deletions, modifications, enhancements, improvements and other changes to the content and materials, its products, programs and services at any time or to move or discontinue any content, products, programs, or services without notice.
    Follow Us Texas Instruments on Facebook Texas Instruments on Twitter Texas Instruments on LinkedIn Texas Instruments on Google+
    TI Worldwide | Contact Us | my.TI Login | Site Map | Corporate Citizenship | mobile m.ti.com (Mobile Version)
    TI is a global semiconductor design and manufacturing company. Innovate with 100,000+ analog ICs and
    embedded processors, along with software, tools and the industry’s largest sales/support staff.
    © Copyright 1995-2013 Texas Instruments Incorporated. All rights reserved.
    Trademarks | Privacy Policy | Terms of Use
