• Join
  • Sign In with my.TI Login
Texas Instruments
  • Products
  • Applications
  • Tools & Software
  • Support & Community
  • Sample & Buy
  • About TI
Sample & Purchase Cart Sample & Purchase Cart
  • Search
  • Advanced
TI E2E™ Community
  • Support Forums
  • Blogs
  • Groups
  • Videos
  • 简体中文
  • More ...
TI Home » TI E2E Community » Support Forums » Development Tools » Code Composer Studio » Code Composer Forum » CCS 5.1.1 build/Debug problem/Could not write metadata
Share
  • Forum
  • Announcements
Options
  • Subscribe via RSS
Common Questions
  • Code Composer Studio Forum Usage Guidelines
  • Resources
  • Code Composer Studio (CCStudio) Product Folder
  • Troubleshooting CCS
  • CCS Wiki
  • Download CCS
  • Order CCS
  • Tools Insider Blog
  • Bug Tracking
  • CCS 5.1.1 build/Debug problem/Could not write metadata
    This question is answered
    Sabina Greenberg101872
    Posted by Sabina Greenberg101872
    on May 03 2012 02:00 AM
    Expert1320 points
    I working with Piccolo device TMS320F28035/CCS 5.1.1.00031 / compiler c2000_6.0.3/SysBios 6_33_03_33
    I get the following messages when try to build/debug an application(any example from SYSBIOS also):
    Could not write metadata for '/TestGuiLib'.
    ..\workspace_v5_1\.metadata\.plugins\org.eclipse.core.resources\.projects\TestGuiLib\.markers.snap (The system cannot find the path specified)
    directory ..\workspace_v5_1\.metadata\.plugins\org.eclipse.core.resources\.projects\TestGuiLib doesn't exist. ShouldI create it ?
    Could you help me with it?
    Thanks,Sabina
    Report Abuse
    • Reply
    You have posted to a forum that requires a moderator to approve posts before they are publicly available.
    All Replies
    • Lisa TI
      Posted by Lisa TI
      on May 03 2012 12:32 PM
      Guru100125 points
      Hi Sabina,
      Do you have full admin privileges?  What OS are you running CCS on?  How did you install CCS?  What directory do you have CCS installed into?
      Were any error logs generated?
      http://processors.wiki.ti.com/index.php/Troubleshooting_CCS
      Please keep us informed.
      LIsa
      Report Abuse
      • Reply
    • Sabina Greenberg101872
      on May 06 2012 01:42 AM
      Expert1320 points
      Hi Lisa,
      1. I have full admin privileges.
      2. Work with Win7, perform installation CCS from internet -CCS5.1.1.00031_win32.zip
      3. Installation done in the directory C:\ti\ccsv5
      4. I get the following message during build: Could not write metadata for '/TestGuiLib'.
        C:\Users\sabina.greenberg\workspace_v5_1\.metadata\.plugins\org.eclipse.core.resources\.projects\TestGuiLib\.markers.snap (The system cannot find the path specified)
      5. Setup Configuration .CCXML attached: 4300.Picollo.zip
      6. Setup Configuration 1781.sdopts.cfg
      7. GEL file: 7457.f28035.gel
      8. Simulator C2000 - ocing-tn USB-EMU[R3]
      9. logging file
      Report Abuse
      • Reply
    • Lisa TI
      Posted by Lisa TI
      on May 07 2012 09:02 AM
      Guru100125 points
      Hi Sabina,
      Would you be able to give this a try in the latest 5.2 beta?  Do you only get the error on build or do you get errors during project creation as well.  I just used the 5.2 beta and could build a SYS/BIOS example for the piccolo with no issues.  I would like to see if I can reproduce what you are doing.  What exact example/steps have you taken?  Did you select the example right from the new project wizard?
      Lisa
      Report Abuse
      • Reply
      on May 08 2012 00:16 AM
      Verified Answer
      Verified by Lisa TI
      Expert1320 points
      Hi Lisa,
      After removing the example and import it again the problem disappeared in the example, but still exist in my project. Last changes that I did before this problem appeared is chanhe .gel file : run application from SRAM and not from the flash. So I changed DEBUG setting: F28035 Flash Setting-> Load RAM Only, and Erase Sector Selection - unchecked all Sectors (A-H).
      Now I restore .gel file and Debug option: running from Flash with erase all sectors - but it doesn't help. it seems that .gel file changing cause some problems  in my CCS.
      So I had to reinstall CCS&SYS/BIOS on another place, copy my project to the new workspace_v5_1 and the project run without any problems.
      question: Could I change .gel file ? Why one file change(for this project) influence to other projects?
      Thanks, Sabina
      Report Abuse
      • Reply
    • Lisa TI
      Posted by Lisa TI
      on May 08 2012 08:41 AM
      Verified Answer
      Verified by Sabina Greenberg101872
      Guru100125 points
      Hi Sabina,
      I am very glad to hear that you now have things building correctly and can work with your project without issues.
      Regarding the gel file.  This depends on where/how you made a change.  For example if you modified the gel file used by a target configuration file, it could be that other projects are using this target configuration file as well and this is why you see this effect.  It could also be that you have changed some setting at the workspace level that affect all projects in a workspace.  So I hope this helps clarify.
      All the best with development.
      Lisa
      Report Abuse
      • Reply
      on May 08 2012 23:40 PM
      Expert1320 points
      Hi Lisa,
      Thank a lot for your support.
      Regards,Sabina
      Report Abuse
      • Reply
    • Lisa TI
      Posted by Lisa TI
      on May 09 2012 07:56 AM
      Guru100125 points
      Hi Sabina,
      that's what we are here for.  Glad if I could help.
      Lisa
      Report Abuse
      • Reply
    TI E2E™ Community
    • Support Forums
    • Blogs
    • Videos
    • Groups
    • Site Support & Feedback
    • Settings
    TI E2E™ Community Groups
    • TI University Program
    • Make the Switch
    • Microcontroller Projects
    • Motor Drive & Control
    Other Communities
    • Deyisupport
    • Designsomething.org
    • beagleboard.org
    • TI on Element 14
    • TI on TechXchangeSM
    Other Technical & Support Resources
    • WEBENCH® Design Center
    • Product Information Centers
    • Technical Documents
    • TI Design Network
    • TI Technical Articles
    • TI Training
    All content and materials on this site are provided "as is". TI and its respective suppliers and providers of content make no representations about the suitability of these materials for any purpose and disclaim all warranties and conditions with regard to these materials, including but not limited to all implied warranties and conditions of merchantability, fitness for a particular purpose, title and non-infringement of any third party intellectual property right. TI and its respective suppliers and providers of content make no representations about the suitability of these materials for any purpose and disclaim all warranties and conditions with respect to these materials. No license, either express or implied, by estoppel or otherwise, is granted by TI. Use of the information on this site may require a license from a third party, or a license from TI.
    Content on this site may contain or be subject to specific guidelines or limitations on use. All postings and use of the content on this site are subject to the Terms of Use of the site; third parties using this content agree to abide by any limitations or guidelines and to comply with the Terms of Use of this site. TI, its suppliers and providers of content reserve the right to make corrections, deletions, modifications, enhancements, improvements and other changes to the content and materials, its products, programs and services at any time or to move or discontinue any content, products, programs, or services without notice.
    Follow Us Texas Instruments on Facebook Texas Instruments on Twitter Texas Instruments on LinkedIn Texas Instruments on Google+
    TI Worldwide | Contact Us | my.TI Login | Site Map | Corporate Citizenship | mobile m.ti.com (Mobile Version)
    TI is a global semiconductor design and manufacturing company. Innovate with 100,000+ analog ICs and
    embedded processors, along with software, tools and the industry’s largest sales/support staff.
    © Copyright 1995-2013 Texas Instruments Incorporated. All rights reserved.
    Trademarks | Privacy Policy | Terms of Use
