• Join
  • Sign In with my.TI Login
Texas Instruments
  • Products
  • Applications
  • Tools & Software
  • Support & Community
  • Sample & Buy
  • About TI
Sample & Purchase Cart Sample & Purchase Cart
  • Search
  • Advanced
TI E2E™ Community
  • Support Forums
  • Blogs
  • Groups
  • Videos
  • 简体中文
  • More ...
TI Home » TI E2E Community » Support Forums » Development Tools » Code Composer Studio » Code Composer Forum » CCS v5 Installation Quirkiness
Share
  • Forum
  • Announcements
Options
  • Subscribe via RSS
Common Questions
  • Code Composer Studio Forum Usage Guidelines
  • Resources
  • Code Composer Studio (CCStudio) Product Folder
  • Troubleshooting CCS
  • CCS Wiki
  • Download CCS
  • Order CCS
  • Tools Insider Blog
  • Bug Tracking
  • CCS v5 Installation Quirkiness
    This question is not answered
    Chris Wang1
    Posted by Chris Wang1
    on May 03 2012 16:49 PM
    Prodigy40 points
    I tried to do a fresh install of the latest CCS (CCS5.1.1.00031_win32) on my new computer that runs Windows 7 Enterprise and it did not have prior installations of any TI product.  During the installation right around the setup box indicating "Registering com.ti.ccstudio.debugserver.win32 feature" it created a folder named sonu in my C:\Users directory and the following.
    C:\Users\sonu\workspace_v5_1
    Also eventually in that C:\Users\sonu folder CCS will store the user-defined Target Configuration files.
    Why is it doing that?  Why is not creating that folder under my user account, say C:\User\cwang
    Any idea?
    Chris
    Report Abuse
    • Reply
    You have posted to a forum that requires a moderator to approve posts before they are publicly available.
    All Replies
    • Ki-Soo Lee
      Posted by Ki-Soo Lee
      on May 04 2012 09:11 AM
      Guru117055 points
      Hello Chris,
      It should be creating those folders inside the user folder of the current user account. The installer will use the windows environment variables for the current user logged in. Can you confirm that you are logged in as 'cwang' and not as 'sonu'?
      ki
      Don't forget to verify answers to your forum questions by using the green "Verify Answer" button.
      Did you read the CCS Forum Guidelines & FAQ? If not, PLEASE read it. If you haven't read it in awhile, please read it again to see if any updates were made.
      Having CCSv5 problems? Check out the CCSv5 Troubleshooting Guide
      Click here to track an issue. Enter your bug id in the "Find Record ID" box
      Report Abuse
      • Reply
    • Chris Wang1
      on May 04 2012 09:51 AM
      Prodigy40 points
      Hi Ki,
      Thanks for responding.  I am logged in as cwang.  I have also checked "User Accounts" under Windows 7's Control Panel and there is no such user named "sonu".  Is there any thing specific I can check in Windows 7 (eg, environment variable or registry entry)?
      Chris
      Report Abuse
      • Reply
    • desouza
      Posted by desouza
      on May 07 2012 14:37 PM
      Guru56025 points
      Chris,
      Can you check one thing? Open a Windows Command Prompt box (Windows Key + R --> type CMD) then type:
      echo %HOMEPATH%
      It should read back the name of the path to the home and user directories.
      To see several other environment variables that may be influencing your installation, simply type set on the prompt and see if you get a "sonu" somewhere.
      These variables are set by right-clicking on the icon Computer -->  Advanced System Settings --> tab Advanced --> Environment Variables button
      Hope this helps,
      Rafael
      If my reply answers your question please click on the green button "Verify Answer".
      Search the wiki or go to useful pages for SDOWP, CGT, BIOS, CCSv3, CCSv4, CCSv5
      Report Abuse
      • Reply
    • Chris Wang1
      on May 08 2012 09:46 AM
      Prodigy40 points
      Hi Rafael,
      Thanks for responding.  Echoing HOMEPATH returned the following.
      C:\Users\cwang>echo %HOMEPATH%
      I also did a set command at Windows Command Prompt and inspected the output and I didnot find any "sonu" string.
      My HOMEPATH seems to be empty, containing only a "\" character.  Could this be the root cause?   What does it suppose to look like?
      Thank you,
      Chris
      Report Abuse
      • Reply
    • desouza
      Posted by desouza
      on May 09 2012 10:21 AM
      Guru56025 points
      Chris,
      The fact you are using Windows 7 and your homepath is C:\ may be a source for trouble; if you have UAC enabled, it will try to protect critical areas of the system (root directory included) and therefore it may be the reason why you are having this strange "User" called sonu.
      I would try to create a different user (to avoid destroying any existing data/work), make sure its home directory is the default C:\Users\<username_chosen>, logon to it and run CCS. That should take care of the strange username.
      Some reference threads that talk about UAC and Windows Vista/7:
      http://e2e.ti.com/support/development_tools/code_composer_studio/f/81/t/110030.aspx#389595
      http://e2e.ti.com/support/development_tools/code_composer_studio/f/81/p/110030/525730.aspx
      Hope this helps,
      Rafael
      Report Abuse
      • Reply
    • Chris Wang1
      on May 20 2012 12:38 PM
      Prodigy40 points
      Hi Rafael,
      I think you are right.  The fact that my HOMEPATH is pointing to the root directly seems to be source of the problem.  I have two other systems and both are Windows 7.  CCS installed on there just fine because their HOMEPATH points to the correct user directory.  I am working with my IT people to fix this HOMEPATH issue either through changing settings in User Account Management or reinstall Windows 7 completely (assuming somewhere it would let you set HOMEPATH somehow).
      Do you know a quick way to fix this HOMEPATH mess?  We tried to do it via adding a HOMEPATH environment variable and that didn't have any effect at all because Windows keeps setting it back to root directly when we query it (using echo).  I will also try that UAC setting you mentioned and report back.
      Chris
      Report Abuse
      • Reply
    TI E2E™ Community
    • Support Forums
    • Blogs
    • Videos
    • Groups
    • Site Support & Feedback
    • Settings
    TI E2E™ Community Groups
    • TI University Program
    • Make the Switch
    • Microcontroller Projects
    • Motor Drive & Control
    Other Communities
    • Deyisupport
    • Designsomething.org
    • beagleboard.org
    • TI on Element 14
    • TI on TechXchangeSM
    Other Technical & Support Resources
    • WEBENCH® Design Center
    • Product Information Centers
    • Technical Documents
    • TI Design Network
    • TI Technical Articles
    • TI Training
    All content and materials on this site are provided "as is". TI and its respective suppliers and providers of content make no representations about the suitability of these materials for any purpose and disclaim all warranties and conditions with regard to these materials, including but not limited to all implied warranties and conditions of merchantability, fitness for a particular purpose, title and non-infringement of any third party intellectual property right. TI and its respective suppliers and providers of content make no representations about the suitability of these materials for any purpose and disclaim all warranties and conditions with respect to these materials. No license, either express or implied, by estoppel or otherwise, is granted by TI. Use of the information on this site may require a license from a third party, or a license from TI.
    Content on this site may contain or be subject to specific guidelines or limitations on use. All postings and use of the content on this site are subject to the Terms of Use of the site; third parties using this content agree to abide by any limitations or guidelines and to comply with the Terms of Use of this site. TI, its suppliers and providers of content reserve the right to make corrections, deletions, modifications, enhancements, improvements and other changes to the content and materials, its products, programs and services at any time or to move or discontinue any content, products, programs, or services without notice.
    Follow Us Texas Instruments on Facebook Texas Instruments on Twitter Texas Instruments on LinkedIn Texas Instruments on Google+
    TI Worldwide | Contact Us | my.TI Login | Site Map | Corporate Citizenship | mobile m.ti.com (Mobile Version)
    TI is a global semiconductor design and manufacturing company. Innovate with 100,000+ analog ICs and
    embedded processors, along with software, tools and the industry’s largest sales/support staff.
    © Copyright 1995-2013 Texas Instruments Incorporated. All rights reserved.
    Trademarks | Privacy Policy | Terms of Use
