• Join
  • Sign In with my.TI Login
Texas Instruments
  • Products
  • Applications
  • Tools & Software
  • Support & Community
  • Sample & Buy
  • About TI
Sample & Purchase Cart Sample & Purchase Cart
  • Search
  • Advanced
TI E2E™ Community
  • Support Forums
  • Blogs
  • Groups
  • Videos
  • 简体中文
  • More ...
TI Home » TI E2E Community » Support Forums » Development Tools » Code Composer Studio » Code Composer Forum » error connecting to target
Share
  • Forum
  • Announcements
Options
  • Subscribe via RSS
Common Questions
  • Code Composer Studio Forum Usage Guidelines
  • Resources
  • Code Composer Studio (CCStudio) Product Folder
  • Troubleshooting CCS
  • CCS Wiki
  • Download CCS
  • Order CCS
  • Tools Insider Blog
  • Bug Tracking
  • error connecting to target
    This question is answered
    Kaumil Desai1
    Posted by Kaumil Desai1
    on May 07 2012 23:07 PM
    Prodigy170 points
    I m working with TMDX5535EZDSP kit.
    trying to connect to target to load new code. it showing error of connecting target Error -600.
    It says required dynamic library could not be located. The library isn't on search path.
    Report Abuse
    • Reply
    You have posted to a forum that requires a moderator to approve posts before they are publicly available.
    All Replies
    • Lisa TI
      Posted by Lisa TI
      on May 08 2012 08:00 AM
      Guru100045 points
      Hi Kaumil,
      how have you setup your project and target configuration?  Or are you purely using the load code in debug mode?  Could you please provide a few further details?
      Would you be able to send your ccxml?  If you are using a project, please check your include paths and options.  See this useful wiki
      http://processors.wiki.ti.com/index.php/Include_paths_and_options
      Lisa
      Report Abuse
      • Reply
    • Kaumil Desai1
      on May 08 2012 23:59 PM
      Prodigy170 points
       Hi I am using TMDX5535ESDSP kit. My OS is windows 7 64 bit. TMDX demo kit has XDS 100 V2 jtag.
      I m using example code of blinking led given in CD. I am loading code in debug mode,
      <?xml version="1.0" encoding="UTF-8" standalone="no"?>
      <configurations XML_version="1.2" id="configurations_0">
      <configuration XML_version="1.2" id="Texas Instruments XDS100v2 USB Emulator_0">
              <instance XML_version="1.2" desc="Texas Instruments XDS100v2 USB Emulator_0" href="connections\TIXDS100v2_Connection.xml" id="Texas Instruments XDS100v2 USB Emulator_0" xml="TIXDS100v2_Connection.xml" xmlpath="connections"/>
              <connection XML_version="1.2" id="Texas Instruments XDS100v2 USB Emulator_0">
                  <instance XML_version="1.2" href="drivers\tixds100v2c55x.xml" id="drivers" xml="tixds100v2c55x.xml" xmlpath="drivers"/>
                  <platform XML_version="1.2" id="platform_0">
                      <instance XML_version="1.2" desc="EZDSP5535_0" href="boards\ezdsp5535.xml" id="EZDSP5535_0" xml="ezdsp5535.xml" xmlpath="boards"/>
                  </platform>
              </connection>
          </configuration>
      </configurations>
      Report Abuse
      • Reply
    • Lisa TI
      Posted by Lisa TI
      on May 09 2012 10:20 AM
      Guru100045 points
      Hi Kaumil,
      it seems your ccxml is fine.  Could you please provide the requested further details?  Did you have a look at the wiki I sent?  Did you try to determine whether there was a library path you needed to correct?  Which example exactly are you trying to run?  Do you get any build errors?
      Best REgards,
      Lisa
      Report Abuse
      • Reply
    • Kaumil Desai1
      on May 10 2012 00:46 AM
      Prodigy170 points
      i looked at wiki, but it is for ccs 5, and i m using ccs 4. i m trying led blinking example. i m not getting any build error.
      Report Abuse
      • Reply
    • Lisa TI
      Posted by Lisa TI
      on May 11 2012 09:53 AM
      Guru100045 points
      Hi Kaumil,
      we are looking into this but could you please have a look at this thread and let me know if it helps?
      http://e2e.ti.com/support/development_tools/code_composer_studio/f/81/t/113152.aspx
      Lisa
      Report Abuse
      • Reply
    • Kaumil Desai1
      on May 16 2012 00:18 AM
      Prodigy170 points
      Hi
      I installed CCS in different location than programme files, removed all folders and drivers of previous installation.
      still it is giving same error.
      my ccs version is Version: 4.2.4.00033 .
      please find plug in details in attached jpeg file.
      is it possible that, hardware may have some problem?
      please reply ASAP as it is creating problem for me.
      Report Abuse
      • Reply
    • Lisa TI
      Posted by Lisa TI
      on May 16 2012 12:01 PM
      Guru100045 points
      Hi Kaumil,
      Could you please try to resend the jpg and any steps/furhter information you can?   I can not reproduce this error at all here on a couple different 5535 examples.
      One thing I have now noticed ... in your target configuration you chose the ezdsp?  Is this the kit you have ?  If not, try selecting a different 5535 (standard one for example) ... and see how that goes.
      This is the target config line I noticed.
      Please keep us informed.
      Lisa
      Report Abuse
      • Reply
    • Kaumil Desai1
      on May 16 2012 14:22 PM
      Prodigy170 points
      Hi
      ya i m using ezdsp kit. and following steps mentioned in document.
      i m sending jpeg file again here.
      Report Abuse
      • Reply
    • Lisa TI
      Posted by Lisa TI
      on May 16 2012 14:30 PM
      Guru100045 points
      Hi Kaumil,
      could you please send detailed information on your settings and the steps you take?  Is your project a CCS project? Could you double check you get no build errors.  What do you see if you go to Window->Preferences->Code Composer Studio->Build->Code Generation Tools  .... Could you send a screenshot?
      Are you simply trying an example application?  Which one? Do you get any error logs?
      LIsa
      Report Abuse
      • Reply
    • Kaumil Desai1
      on May 16 2012 19:38 PM
      Prodigy170 points
      please find attached screen shot of code generation tool.
      it is ccs project.
      steps how i created project and configuration file.
      [1] open ccs v4 , click target menu, select new target configuration file
      [2] select XDS 100v2 usb emulator and device field select eZdsp5535
      [3] import project file from directory.
      [4] build active project
      below is build result of project.
      **** Build of configuration Debug for project led ****
      C:\Kaumil\Texas Instruments\ccsv4\utils\gmake\gmake -k all
      'Building file: ../led_test.c'
      'Invoking: Compiler'
      "C:/Kaumil/Texas Instruments/ccsv4/tools/compiler/c5500/bin/cl55" -v5515 -g --include_path="C:/Kaumil/Texas Instruments/ccsv4/tools/compiler/c5500/include" --include_path="C:/Kaumil/Texas Instruments/ccsv4/emulation/boards/ezdsp5535_v1/tests/led/../../c55xx_csl/inc" --include_path="C:/Kaumil/Texas Instruments/ccsv4/emulation/boards/ezdsp5535_v1/tests/led/../../include" --diag_warning=225 --ptrdiff_size=16 --memory_model=large --preproc_with_compile --preproc_dependency="led_test.pp" "../led_test.c"
      'Finished building: ../led_test.c'
      'Building file: ../main.c'
      "C:/Kaumil/Texas Instruments/ccsv4/tools/compiler/c5500/bin/cl55" -v5515 -g --include_path="C:/Kaumil/Texas Instruments/ccsv4/tools/compiler/c5500/include" --include_path="C:/Kaumil/Texas Instruments/ccsv4/emulation/boards/ezdsp5535_v1/tests/led/../../c55xx_csl/inc" --include_path="C:/Kaumil/Texas Instruments/ccsv4/emulation/boards/ezdsp5535_v1/tests/led/../../include" --diag_warning=225 --ptrdiff_size=16 --memory_model=large --preproc_with_compile --preproc_dependency="main.pp" "../main.c"
      'Finished building: ../main.c'
      'Building target: led.out'
      'Invoking: Linker'
      "C:/Kaumil/Texas Instruments/ccsv4/tools/compiler/c5500/bin/cl55" -v5515 -g --diag_warning=225 --ptrdiff_size=16 --memory_model=large -z -m"led.map" --warn_sections -i"C:/Kaumil/Texas Instruments/ccsv4/tools/compiler/c5500/lib" -i"C:/Kaumil/Texas Instruments/ccsv4/tools/compiler/c5500/include" -i"C:/Kaumil/Texas Instruments/ccsv4/emulation/boards/ezdsp5535_v1/tests/led/../../c55xx_csl/ccs_v4.0_examples/cslVC5505/Debug" -i"C:/Kaumil/Texas Instruments/ccsv4/emulation/boards/ezdsp5535_v1/tests/led/../../lib" --reread_libs --rom_model -o "led.out" "./main.obj" "./led_test.obj" -l"cslVC5505.lib" -l"ezdsp5535bsl.lib" -l"rts55x.lib" "../lnkx.cmd"
      <Linking>
      'Finished building target: led.out'
      Build complete for project led
      when it starts build, it shows something in red color but when it completes. shows build is finished but not showing any error in red.
      Report Abuse
      • Reply
    • Lisa TI
      Posted by Lisa TI
      on May 17 2012 08:54 AM
      Guru100045 points
      Hi Kaumil,
      can you verify the target configuration you created is indeed attached to the project?  It appears you do things correctly and the build log seems to indicate no problems.
      And now .. what steps do you take next?  How do you launch?  When do you see the error? Are there any logs you could send?  Perhaps further screenshots.
      Lisa
      Report Abuse
      • Reply
    • Kaumil Desai1
      on May 17 2012 23:18 PM
      Prodigy170 points
      hi
      my next step is go to target and clicke on debug active project. and it shows error message "
      Error connecting to the target:
      (Error -600 @ 0x0)
      A required dynamic library could not be located.
      The library isn't on the search path.
      (Release 5.0.429.0)
      how to verify target configuration is indeed attached to project?
      please find attached screen shot when i build, but it is not there in console, so i have to take screen shot. i hope it will be helpful
      Report Abuse
      • Reply
    • Lisa TI
      Posted by Lisa TI
      on May 18 2012 10:56 AM
      Guru100045 points
      Hi Kaumil,
      this looks like a build error/it can't seem to find some files.  From this screenshot it looks like your project does not build properly..
      Could you please build the project and send a screenshot?  I would like to confirm there are no build errors.
      Lisa
      Report Abuse
      • Reply
    • Kaumil Desai1
      on May 18 2012 13:03 PM
      Prodigy170 points
      i again build project, below is build deatails. It is not showing those errors, that's why i took screen shot of it.
      'Invoking: Linker'
      <Linking>
      how to verify target configuration created is indeed attached to the project?
      Report Abuse
      • Reply
    • Lisa TI
      Posted by Lisa TI
      on May 18 2012 13:12 PM
      Guru100045 points
      Hi Kaumil,
      can you send a screenshot of your project explorer?  Is there a ccxml listed with your project indicating active?
      LIsa
      Report Abuse
      • Reply
    12
    TI E2E™ Community
    • Support Forums
    • Blogs
    • Videos
    • Groups
    • Site Support & Feedback
    • Settings
    TI E2E™ Community Groups
    • TI University Program
    • Make the Switch
    • Microcontroller Projects
    • Motor Drive & Control
    Other Communities
    • Deyisupport
    • Designsomething.org
    • beagleboard.org
    • TI on Element 14
    • TI on TechXchangeSM
    Other Technical & Support Resources
    • WEBENCH® Design Center
    • Product Information Centers
    • Technical Documents
    • TI Design Network
    • TI Technical Articles
    • TI Training
    All content and materials on this site are provided "as is". TI and its respective suppliers and providers of content make no representations about the suitability of these materials for any purpose and disclaim all warranties and conditions with regard to these materials, including but not limited to all implied warranties and conditions of merchantability, fitness for a particular purpose, title and non-infringement of any third party intellectual property right. TI and its respective suppliers and providers of content make no representations about the suitability of these materials for any purpose and disclaim all warranties and conditions with respect to these materials. No license, either express or implied, by estoppel or otherwise, is granted by TI. Use of the information on this site may require a license from a third party, or a license from TI.
    Content on this site may contain or be subject to specific guidelines or limitations on use. All postings and use of the content on this site are subject to the Terms of Use of the site; third parties using this content agree to abide by any limitations or guidelines and to comply with the Terms of Use of this site. TI, its suppliers and providers of content reserve the right to make corrections, deletions, modifications, enhancements, improvements and other changes to the content and materials, its products, programs and services at any time or to move or discontinue any content, products, programs, or services without notice.
    Follow Us Texas Instruments on Facebook Texas Instruments on Twitter Texas Instruments on LinkedIn Texas Instruments on Google+
    TI Worldwide | Contact Us | my.TI Login | Site Map | Corporate Citizenship | mobile m.ti.com (Mobile Version)
    TI is a global semiconductor design and manufacturing company. Innovate with 100,000+ analog ICs and
    embedded processors, along with software, tools and the industry’s largest sales/support staff.
    © Copyright 1995-2013 Texas Instruments Incorporated. All rights reserved.
    Trademarks | Privacy Policy | Terms of Use
