• Join
  • Sign In with my.TI Login
Texas Instruments
  • Products
  • Applications
  • Tools & Software
  • Support & Community
  • Sample & Buy
  • About TI
Sample & Purchase Cart Sample & Purchase Cart
  • Search
  • Advanced
TI E2E™ Community
  • Support Forums
  • Blogs
  • Groups
  • Videos
  • 简体中文
  • More ...
TI Home » TI E2E Community » Support Forums » Development Tools » Code Composer Studio » Code Composer Forum » License Server Administration for CCS - tidspssw problem
Share
  • Forum
  • Announcements
Options
  • Subscribe via RSS
Common Questions
  • Code Composer Studio Forum Usage Guidelines
  • Resources
  • Code Composer Studio (CCStudio) Product Folder
  • Troubleshooting CCS
  • CCS Wiki
  • Download CCS
  • Order CCS
  • Tools Insider Blog
  • Bug Tracking
  • License Server Administration for CCS - tidspssw problem
    • Zdravko Pribeg
      Posted by Zdravko Pribeg
      on Jul 31 2012 22:09 PM
      Prodigy50 points
      Hi
      we purchased a floating license for CCS5.  Our server is a 32-bit CentOS 5.5, running as a virtual server under Dell OEM version of VMware ESXi (aka VMware vSphere) 4.1. Attempting to use install and use lmgrd, I get the following in the log:
      21:50:59 (lmgrd) License file(s): /opt/license_server/licenses/TMDSCCS-ALLF01-v5.lic
      21:50:59 (lmgrd) lmgrd tcp-port 27000
      21:50:59 (lmgrd) Starting vendor daemons ...
      21:50:59 (lmgrd) Using vendor daemon port 27100 specified in license file
      21:50:59 (tidspssw) FLEXnet Licensing version v11.4.100.0 build 50818 i86_re3
      21:50:59 (tidspssw) lmgrd version 11.10, tidspssw version 11.4
      21:50:59 (lmgrd) Started tidspssw (internet tcp_port 27100 pid 5646)
      21:50:59 (tidspssw) Server started on localhost for:    CCS_CONNECTION_ALL
      21:50:59 (tidspssw) CCS_DEBUGGER    CCS_LINKER_FULL CCS_ISA_ALL
      21:50:59 (tidspssw) EXTERNAL FILTERS are OFF
      21:51:09 (tidspssw) Vendor daemon can't talk to lmgrd (Cannot connect to license server system. (-15,570:115 "Operation now in progress"))
      21:51:09 (tidspssw) EXITING DUE TO SIGNAL 37 Exit reason 5
      21:51:09 (lmgrd) tidspssw exited with status 37 (Communications error)
      21:51:09 (lmgrd) Since this is an unknown status, license server
      21:51:09 (lmgrd) manager (lmgrd) will attempt to re-start the vendor daemon.
      Hosts file contains:
      127.0.0.1    localhost.localdomain    localhost centos this_host
      #::1    localhost6.localdomain6    localhost6
      98.129.139.41    et1.sourcehosting.net    et1
      #192.168.101.41 this_host
      License file contains
      #Please Do not delete this comment line.
      #SERVER this_host 000C298D865A
      SERVER localhost 000C298D865A 27000
      #SERVER 192.168.101.41 000C298D865A
      VENDOR tidspssw PORT=27100
      USE_SERVER
      INCREMENT CCS_CONNECTION_ALL tidspssw 5.99 permanent 1 \
          VENDOR_STRING=...
      This problem did not show when install was attempted on an Ubuntu machine. However, I must use CentOS.
      Help will be greatly appreciated.
      Report Abuse
      • Reply
      You have posted to a forum that requires a moderator to approve posts before they are publicly available.
    • Lisa TI
      Posted by Lisa TI
      on Aug 01 2012 07:47 AM
      Guru103395 points
      can you please ensure you have all permissions and antivirus turn off?  Or at the very least an exception created for the vendor daemon.
      Did you follow these steps?  Is the issue with the flexnet software?  If so, have you gone to them for support with their software on CentOS?
      http://processors.wiki.ti.com/index.php/License_Server_Administration_for_CCS
      Lisa
      Report Abuse
      • Reply
    • Zdravko Pribeg
      on Aug 02 2012 14:18 PM
      Prodigy50 points
      Hi there
      there is no antivirus software on the server. Regarding permissions, I followed instructions as per http://processors.wiki.ti.com/index.php/License_Server_Administration_for_CCS#UNIX:_graphical_setup. I started the program under non-root account, as required.
      "Or at the very least an exception created for the vendor daemon": is there a way to get more detailed exception information? If so please let me know how to obtain it.
      I am not sure if the issue is with the flexnet software or the TI daemon. When I tried to get access to Flexera on-line knowledge base, I was asked to create a login account and refer to support contract ID. We have no such support contract with Flexera, we purchased the license from TI.
      Report Abuse
      • Reply
    • Lisa TI
      Posted by Lisa TI
      on Aug 02 2012 14:22 PM
      Guru103395 points
      do you have the port allowed through the firewall?  Can you send a screenshot of the flexnet license manager administration screen? Did you have trouble at any step in the instructions?
      Lisa
      Report Abuse
      • Reply
    • Zdravko Pribeg
      on Aug 02 2012 19:23 PM
      Prodigy50 points
      Hi
      the firewall is temporarily off. I can telnet port 27000:
      telnet localhost 27000
      Trying 127.0.0.1...
      Connected to localhost.localdomain (127.0.0.1).
      Escape character is '^]'.
      Sorry for the confusion, I am using command line setup, not the graphical one. There were no problems following the instructions, up to the point of running lmgrd with the vendor daemon.
      Report Abuse
      • Reply
    • Lisa TI
      Posted by Lisa TI
      on Aug 03 2012 09:40 AM
      Guru103395 points
      what do you mean by the firewall being temporarily off?  This port needs to be allowed through to get the license.  What do you mean by up to running lmgrd with the vendor daemon?  What exactly do you experience? Are the vendor daemon executable and manifest file both in the same directory as the lmadmin?
      Lisa
      Report Abuse
      • Reply
    • Zdravko Pribeg
      on Aug 03 2012 13:13 PM
      Prodigy50 points
      Software firewall is temporarily off. Hardware firewall has ports 27000-27010 and 27100 open. I am running lmgrd, see step 11 in http://processors.wiki.ti.com/index.php/License_Server_Administration_for_CCS#UNIX:_command_line_setup.
      lmgrd is attempting to start the vendor daemon (tidspssw) and then there is a problem. It is all in my original post. Licenses can not be served if the vendor daemon can't start, can they?
      lmadmin is not being used, this is command line setup.
      Report Abuse
      • Reply
    • Lisa TI
      Posted by Lisa TI
      on Aug 07 2012 09:29 AM
      Guru103395 points
      Hi Zdravko,
      the error you are getting seems to be a communication error between lmgrd and the vendor daemon.  I am unfortunately no a flexnet expert but am wondering if it could be caused by the port number.  It also seems like lmgrd is trying to use 27000 and for some reason it has been put it to try and force 27100.  Check this and please keep us informed.
      Best REgards,
      Lisa
      Report Abuse
      • Reply
    • Zdravko Pribeg
      on Aug 07 2012 11:33 AM
      Prodigy50 points
      Hi Lisa
      when I encountered the problem, and before I resorted to to posting on this forum, I did a lot of searching on the Internet for issues related to "(tidspssw) EXITING DUE TO SIGNAL 37 Exit reason 5 (lmgrd) tidspssw exited with status 37 (Communications error)".
      None of the few solutions I encountered directly applied to my case. To ensure that port usage is clearly determined, I used the options to set explicit port numbers in the license file:
      I started with defaults (port numbers in the above statements were omitted) ; the erorr messages were the same.
      It has to be something about CentOS or its configuration, as on Ubuntu it gets past this point. Unfortunaly I can not use Ubuntu.
      Zdravko
      Report Abuse
      • Reply
    • Lisa TI
      Posted by Lisa TI
      on Aug 07 2012 12:38 PM
      Guru103395 points
      Zdravko,
      have you double checked various compatibility items with CentOS.  I did a look for you myself and it does seem flexera supports a couple versions of it.   Let me see if our vendor daemon is incompatible and might be causing an issue.
      Lisa
      Report Abuse
      • Reply
    • Lisa TI
      Posted by Lisa TI
      on Aug 13 2012 12:57 PM
      Guru103395 points
      Hi Zdravko,
      unfortunately we can not test all OS/Linux varients and have not done much with CentOS.   I doubt this is a problem with the daemon as Red Hat has been tested, however, there is likely not much further I can do for you unfortunately.  Especially as it works in Ubuntu.
      Lisa
      Report Abuse
      • Reply
    • Pragnesh Patel
      Posted by Pragnesh Patel
      on Dec 13 2012 10:01 AM
      Intellectual775 points
      So this means if we can't find machine that runs UBUNTU we should not use TI ????
      TI has to understand that servers are under IT's control not under embedded software people. There has to be some better licensing policy available.
      Here is my issue it is exactly same.
      I have similar issues and I am trying to resolve same things.
      I have remote server running Linux version 2.6.18-53.1.14.el5 (mockbuild@builder6.centos.org) (gcc version 4.1.2. 20070626 (Red Hat 4.1.2-14)) # 1 SMP .
      I followed all steps listed in Floating License Installation on Unix / Linux.
      lmgrd seems to be running after setting LM_LICENSE_FILE=/opt/license_server/licenses/
      How ever this was never mentioned in license installation WIKI. (Needs update but this is my opinion).
      I am getting message
      vendor darmon can't talk to lmgrd
      I spent almost two days setting this up so that I can use the license from desktop as well as from my laptop. But can not get it work.  At this point I am so frustrated with this licensing issues that any help is appreciated. I am also going to refer the issue to my AVNET FAE so that he can get better answer from TI.
      Report Abuse
      • Reply
    TI E2E™ Community
    • Support Forums
    • Blogs
    • Videos
    • Groups
    • Site Support & Feedback
    • Settings
    TI E2E™ Community Groups
    • TI University Program
    • Make the Switch
    • Microcontroller Projects
    • Motor Drive & Control
    Other Communities
    • Deyisupport
    • Designsomething.org
    • beagleboard.org
    • TI on Element 14
    • TI on TechXchangeSM
    Other Technical & Support Resources
    • WEBENCH® Design Center
    • Product Information Centers
    • Technical Documents
    • TI Design Network
    • TI Technical Articles
    • TI Training
    All content and materials on this site are provided "as is". TI and its respective suppliers and providers of content make no representations about the suitability of these materials for any purpose and disclaim all warranties and conditions with regard to these materials, including but not limited to all implied warranties and conditions of merchantability, fitness for a particular purpose, title and non-infringement of any third party intellectual property right. TI and its respective suppliers and providers of content make no representations about the suitability of these materials for any purpose and disclaim all warranties and conditions with respect to these materials. No license, either express or implied, by estoppel or otherwise, is granted by TI. Use of the information on this site may require a license from a third party, or a license from TI.
    Content on this site may contain or be subject to specific guidelines or limitations on use. All postings and use of the content on this site are subject to the Terms of Use of the site; third parties using this content agree to abide by any limitations or guidelines and to comply with the Terms of Use of this site. TI, its suppliers and providers of content reserve the right to make corrections, deletions, modifications, enhancements, improvements and other changes to the content and materials, its products, programs and services at any time or to move or discontinue any content, products, programs, or services without notice.
    Follow Us Texas Instruments on Facebook Texas Instruments on Twitter Texas Instruments on LinkedIn Texas Instruments on Google+
    TI Worldwide | Contact Us | my.TI Login | Site Map | Corporate Citizenship | mobile m.ti.com (Mobile Version)
    TI is a global semiconductor design and manufacturing company. Innovate with 100,000+ analog ICs and
    embedded processors, along with software, tools and the industry’s largest sales/support staff.
    © Copyright 1995-2013 Texas Instruments Incorporated. All rights reserved.
    Trademarks | Privacy Policy | Terms of Use
