• Join
  • Sign In with my.TI Login
Texas Instruments
  • Products
  • Applications
  • Tools & Software
  • Support & Community
  • Sample & Buy
  • About TI
Sample & Purchase Cart Sample & Purchase Cart
  • Search
  • Advanced
TI E2E™ Community
  • Support Forums
  • Blogs
  • Groups
  • Videos
  • 简体中文
  • More ...
TI Home » TI E2E Community » Support Forums » Development Tools » Code Composer Studio » Code Composer Forum » CCS5.2 check for updates does not work
Share
  • Forum
  • Announcements
Options
  • Subscribe via RSS
Common Questions
  • Code Composer Studio Forum Usage Guidelines
  • Resources
  • Code Composer Studio (CCStudio) Product Folder
  • Troubleshooting CCS
  • CCS Wiki
  • Download CCS
  • Order CCS
  • Tools Insider Blog
  • Bug Tracking
  • CCS5.2 check for updates does not work
    This question is answered
    Adil.O
    Posted by Adil.O
    on Aug 06 2012 09:07 AM
    Intellectual410 points
    I am using CCS5.2.1.00018, if I go to check for updates the progress bar gets stuck at 50% and stays there for ever ( I let it run for a couple of days).  It does not tell me what software it found or anything. Any suggestion on how to solve this.
    thx,
    Report Abuse
    • Reply
    You have posted to a forum that requires a moderator to approve posts before they are publicly available.
    All Replies
    • Lisa TI
      Posted by Lisa TI
      on Aug 07 2012 07:54 AM
      Guru99505 points
      Hi Adil,
      what OS do you use?  Are you looking for a particular update?  How did you install 5.2.1?  What do you see in Window->Preferences->install/Update->Available Software Sites?
      Do you have full permissions and a correctly set proxy?
      Best REgards,
      Lisa
      Report Abuse
      • Reply
    • Adil.O
      Posted by Adil.O
      on Aug 08 2012 08:43 AM
      Hello Lisa,
      what OS do you use? XP
      Are you looking for a particular update? Well I'd rather have it working so I don't have to chase every single components individually
      How did you install 5.2.1? manually I went to a site then downloaded a zipped file then ran it
      What do you see in Window->Preferences->install/Update->Available Software Sites? Please see attached
      Do you have full permissions and a correctly set proxy? I am pretty sure because it used to work before
      I appreciate the help
      Report Abuse
      • Reply
    • Lisa TI
      Posted by Lisa TI
      on Aug 08 2012 08:51 AM
      Verified Answer
      Verified by Adil.O
      Guru99505 points
      Hi Adil,
      that is odd if it used to work.  Did you make any changes to your setup?  What if you uncheck the file:/  ones and try again?
      LIsa
      Report Abuse
      • Reply
    • Adil.O
      Posted by Adil.O
      on Aug 08 2012 09:04 AM
      Not really. I unchecked all and re- enabled some. Same behavior is there any reason why it is saying CCS5.1 in the picture below,  my rev is 5.2?
      Report Abuse
      • Reply
    • Lisa TI
      Posted by Lisa TI
      on Aug 08 2012 09:09 AM
      Guru99505 points
      Hi Adil,
      the site exists so should not be the cause of the issue.  Has anything changed since it started to hang?
      Lisa
      Report Abuse
      • Reply
    • Adil.O
      Posted by Adil.O
      on Aug 08 2012 09:11 AM
      thank you for the prompt responses this issue is so annoying:)
      No nothing that's how it behaves it goes to 50% and stays there.
      Report Abuse
      • Reply
    • Adil.O
      Posted by Adil.O
      on Aug 08 2012 09:47 AM
      I had a new pop up shown below, I hope this can help solve it:
      Report Abuse
      • Reply
    • Lisa TI
      Posted by Lisa TI
      on Aug 08 2012 09:48 AM
      Guru99505 points
      Hi Adil,
      does it always hang at the same one? Ie that emulation one?  Have you tried unchecking that?
      LIsa
      Report Abuse
      • Reply
    • Lisa TI
      Posted by Lisa TI
      on Aug 08 2012 09:49 AM
      Guru99505 points
      Did you uncheck the file ones as suggested?
      Report Abuse
      • Reply
    • Adil.O
      Posted by Adil.O
      on Aug 08 2012 10:38 AM
      Lisa,
      Thanks, when I unchecked all and checked only the one I needed( spectrum digital Emulation updates)it worked fine,
      it must one of those choices that caused the problem. If I have time I might try to figure out which one caused the problem.
      thx.
      Report Abuse
      • Reply
    • Lisa TI
      Posted by Lisa TI
      on Aug 08 2012 10:40 AM
      Guru99505 points
      Hi Adil,
      yes if you find the one causing problems, please do report this back, but I am glad that you updated what you wanted to.
      All the best with development.
      Lisa
      Report Abuse
      • Reply
    • Adil.O
      Posted by Adil.O
      on Aug 08 2012 11:10 AM
      this is weird, it seams like there are a couple of choices that could cause the problem: Target content update, TI simulator...hmm it there anything specific about these that is  different than the one that works (spectrum digital Emulation updates)...
      Report Abuse
      • Reply
    • Lisa TI
      Posted by Lisa TI
      on Aug 09 2012 08:37 AM
      Guru99505 points
      Hi Adil,
      I also find that there seems to, at least currently, be an issue with the target content update site.  However, by default (perhaps with reason) this site was not enabled for me.  Did you enable extra/non default sites?
      Lisa
      Report Abuse
      • Reply
    • Adil.O
      Posted by Adil.O
      on Aug 09 2012 13:37 PM
      I did yesterday when we were testing which ones were working or not, it seams most of them don't work
      Report Abuse
      • Reply
    TI E2E™ Community
    • Support Forums
    • Blogs
    • Videos
    • Groups
    • Site Support & Feedback
    • Settings
    TI E2E™ Community Groups
    • TI University Program
    • Make the Switch
    • Microcontroller Projects
    • Motor Drive & Control
    Other Communities
    • Deyisupport
    • Designsomething.org
    • beagleboard.org
    • TI on Element 14
    • TI on TechXchangeSM
    Other Technical & Support Resources
    • WEBENCH® Design Center
    • Product Information Centers
    • Technical Documents
    • TI Design Network
    • TI Technical Articles
    • TI Training
    All content and materials on this site are provided "as is". TI and its respective suppliers and providers of content make no representations about the suitability of these materials for any purpose and disclaim all warranties and conditions with regard to these materials, including but not limited to all implied warranties and conditions of merchantability, fitness for a particular purpose, title and non-infringement of any third party intellectual property right. TI and its respective suppliers and providers of content make no representations about the suitability of these materials for any purpose and disclaim all warranties and conditions with respect to these materials. No license, either express or implied, by estoppel or otherwise, is granted by TI. Use of the information on this site may require a license from a third party, or a license from TI.
    Content on this site may contain or be subject to specific guidelines or limitations on use. All postings and use of the content on this site are subject to the Terms of Use of the site; third parties using this content agree to abide by any limitations or guidelines and to comply with the Terms of Use of this site. TI, its suppliers and providers of content reserve the right to make corrections, deletions, modifications, enhancements, improvements and other changes to the content and materials, its products, programs and services at any time or to move or discontinue any content, products, programs, or services without notice.
    Follow Us Texas Instruments on Facebook Texas Instruments on Twitter Texas Instruments on LinkedIn Texas Instruments on Google+
    TI Worldwide | Contact Us | my.TI Login | Site Map | Corporate Citizenship | mobile m.ti.com (Mobile Version)
    TI is a global semiconductor design and manufacturing company. Innovate with 100,000+ analog ICs and
    embedded processors, along with software, tools and the industry’s largest sales/support staff.
    © Copyright 1995-2013 Texas Instruments Incorporated. All rights reserved.
    Trademarks | Privacy Policy | Terms of Use
