• Join
  • Sign In with my.TI Login
Texas Instruments
  • Products
  • Applications
  • Tools & Software
  • Support & Community
  • Sample & Buy
  • About TI
Sample & Purchase Cart Sample & Purchase Cart
  • Search
  • Advanced
TI E2E™ Community
  • Support Forums
  • Blogs
  • Groups
  • Videos
  • 简体中文
  • More ...
TI Home » TI E2E Community » Support Forums » Development Tools » Code Composer Studio » Code Composer Forum » CCS 5.2.1 - multiple issues
Share
  • Forum
  • Announcements
Options
  • Subscribe via RSS
Common Questions
  • Code Composer Studio Forum Usage Guidelines
  • Resources
  • Code Composer Studio (CCStudio) Product Folder
  • Troubleshooting CCS
  • CCS Wiki
  • Download CCS
  • Order CCS
  • Tools Insider Blog
  • Bug Tracking
  • CCS 5.2.1 - multiple issues
    This question is not answered
    Itay Chamiel
    Posted by Itay Chamiel
    on Aug 09 2012 09:39 AM
    Intellectual845 points
    In the daily course of using CCS 5.2.1 under Win7 64-bit I often run into annoying little problems, none of which are critical but which together add up to a very aggravating user experience. I have decided to list them out here in the hope that some of them might be fixed.
    Editor issues
    1. Sometimes when editing, the 'delete' key and 'Ctrl-Z' combination simply stop working, even though all other keys and combinations (such as backspace and Ctrl-S) work properly. This continues until I restart CCS. I haven’t been able to find what triggers the bug.
    2. The editor has a powerful indexer, enabling things like syntax highlighting, auto-complete and “open declaration”. Unfortunately, in some cases these features don’t work – as far as I can see this is due to two problems:
    (a) Compiler built-in defines such as _TMS320C6X and _TMS320C6600 are not known by the indexer and editor. (So a section under #ifdef _TMS320C6X will be grayed out in the editor even though the compiler will compile it.) So for example when including "c6x.h" and using intrinsics, the general ones such as _itoll will be properly highlighted but the processor-specific ones such as _davgu4 will not be, because they are under an #if defined(_TMS320C6600) which the indexer evaluates as false.
    (b) If the include path contains a variable like "${workspace_loc}" the compiler will understand it but the indexer will not.
    GUI issues
    1. When changing a setting (e.g. optimization level) for a single file, a small wrench icon appears on it. However, when manually changing it back to the original project-wide setting the wrench icon remains, even though at this point this file no longer has a custom setting.
    2. Occasionally a bubble appears in the Windows 7 notification pane saying “JVM Heap low”, even though I am not doing anything particularly excessive – perhaps CCS should have a higher default setting for the size of this heap?
    3. In the Problems pane, sometimes errors from previous builds are still shown even when the error has been fixed and did not occur in the most recent build. These “phantom errors” also show up as red ‘X’ marks in the code.
    Project issues
    1. When trying to change properties across multiple projects it is common for me to select a project, right-click > properties, change something, click OK, and move on to the next project and change properties there. When doing this, quite often the properties window opens up with the correct header (“Properties for Project1”) but the actual properties shown are that of a different project! Sometimes the properties are correct but then switching to a different configuration (e.g. Debug to Release) shows wrong properties. Also in this case any changes I make are lost and do not affect either project. The only workaround is to be extra watchful, and if wrong properties are seen close and reopen the properties window.
    2. Also when changing project properties it is common to need to change a certain build setting in both Debug and Release modes. This is a very difficult task with the present UI, as switching configurations will always reset the view to “CCS General”. Also, in some cases (such as CCS Build > Dependencies) when changing the view any changes made are lost – and there is no warning! The only workaround is to click “Apply” before switching configurations, but this is inconsistent across different property pages (many of which don’t have an “Apply” button).
    Build issues
    1. Editing the automatically generated linker.cmd file causes a recompilation of the entire project, even though it only affects the linker stage. This is a huge time waster when experimenting with different section placements in a large project.
    2. Setting a single file to be excluded from build forces a clean and rebuild of the entire project.
    -itay
    Report Abuse
    • Reply
    You have posted to a forum that requires a moderator to approve posts before they are publicly available.
    All Replies
    • Itay Chamiel
      on Aug 21 2012 10:04 AM
      bump
      Report Abuse
      • Reply
    • Josiah McClurg
      Posted by Josiah McClurg
      on Sep 23 2012 19:29 PM
      Prodigy10 points
      I am experiencing the "Ctrl+S not working" problem as well. Let me know if anyone obtains a solution.
      Report Abuse
      • Reply
    • Itay Chamiel
      on Sep 24 2012 04:44 AM
      So far the only problem I've found a solution to is editor issue 2b. The solution is to use ${WorkspaceDirPath} in the include path instead of ${workspace_loc}.
      Report Abuse
      • Reply
    TI E2E™ Community
    • Support Forums
    • Blogs
    • Videos
    • Groups
    • Site Support & Feedback
    • Settings
    TI E2E™ Community Groups
    • TI University Program
    • Make the Switch
    • Microcontroller Projects
    • Motor Drive & Control
    Other Communities
    • Deyisupport
    • Designsomething.org
    • beagleboard.org
    • TI on Element 14
    • TI on TechXchangeSM
    Other Technical & Support Resources
    • WEBENCH® Design Center
    • Product Information Centers
    • Technical Documents
    • TI Design Network
    • TI Technical Articles
    • TI Training
    All content and materials on this site are provided "as is". TI and its respective suppliers and providers of content make no representations about the suitability of these materials for any purpose and disclaim all warranties and conditions with regard to these materials, including but not limited to all implied warranties and conditions of merchantability, fitness for a particular purpose, title and non-infringement of any third party intellectual property right. TI and its respective suppliers and providers of content make no representations about the suitability of these materials for any purpose and disclaim all warranties and conditions with respect to these materials. No license, either express or implied, by estoppel or otherwise, is granted by TI. Use of the information on this site may require a license from a third party, or a license from TI.
    Content on this site may contain or be subject to specific guidelines or limitations on use. All postings and use of the content on this site are subject to the Terms of Use of the site; third parties using this content agree to abide by any limitations or guidelines and to comply with the Terms of Use of this site. TI, its suppliers and providers of content reserve the right to make corrections, deletions, modifications, enhancements, improvements and other changes to the content and materials, its products, programs and services at any time or to move or discontinue any content, products, programs, or services without notice.
    Follow Us Texas Instruments on Facebook Texas Instruments on Twitter Texas Instruments on LinkedIn Texas Instruments on Google+
    TI Worldwide | Contact Us | my.TI Login | Site Map | Corporate Citizenship | mobile m.ti.com (Mobile Version)
    TI is a global semiconductor design and manufacturing company. Innovate with 100,000+ analog ICs and
    embedded processors, along with software, tools and the industry’s largest sales/support staff.
    © Copyright 1995-2013 Texas Instruments Incorporated. All rights reserved.
    Trademarks | Privacy Policy | Terms of Use
