  • Resolved
CCS 5.3 missing a couple files / tools?
I was upgrading from Version: 5.1.0.07001 to  Version: 5.3.0.00090 and I can't find a couple of files I use for the post build step to create a .bin file.  The files I used were  ofd470.exe and hex470.exe.  My post build step was: "${CCS_INSTALL_ROOT}/utils/tiobj2bin/tiobj2bin.bat" "${BuildArtifactFileName}" "App_GCB_vXX.bxxxxx_.bin" "${CG_TOOL_ROOT}/bin/ofd470.exe" "${CG_TOOL_ROOT}/bin/hex470.exe" "${CCS_INSTALL_ROOT}/utils/tiobj2bin/mkhex4bin.exe"
Did I install 5.3 wrong or is there a different way I should create the .bin file now?
Thnaks,
Doug
  • Genius 13530 points
    Have a look at "armofd.exe" and "armhex.exe" in the ccsv5\tools\compiler\arm_*\bin folder. The TMS470 compiler had been renamed to ARM, and the various executables have also been renamed.
  • In reply to AndyW:
    Is there any documenation / help files on these tools?
    Doug
  • In reply to Doug Baker:
    Hi Doug,
    Both tools are documented in the ARM Assembly Language User's Guide:
    http://www.ti.com/lit/ug/spnu118k/spnu118k.pdf
    ki
    Did you read the CCS Forum Guidelines & FAQ? If not, PLEASE read it. If you haven't read it in awhile, please read it again to see if any updates were made.
    Having CCS problems? Check out the CCS Troubleshooting Guide
    Looking for CCS Training? Check out the CCS Training Site
    Curious about the status of a bug and know the tracking ID? Track it via the public bug tracking portal
    NOTE: When a bug is filed and a tracking ID is provided, the thread may then be suggested as "TI Thinks Resolved". Why? Please read the first FAQ of the CCS Forum Guidelines & FAQ
  • In reply to Ki-Soo Lee:
    thanks a lot, that helped.
    I encounterd the same trouble and I found the armofd.exe and armhex.exe tools, But where are the /utils/tiobj2bin/tiobj2bin.bat and utils/tiobj2bin/mkhex4bin.exe in CCS5.3? Is there any illustration about these modifications?
    Thx
    Simon
  • In reply to Simon Wang1:
    Simon Wang1
    They are still in the same location: <CCS INSTALL DIR>\ccsv5\utils\tiobj2bin
    NO,it's not there. did I install CCS5.3 unsuccessfully?
    Simon Wang1
    Could be. Do you see a .\utils folder at least? And if so, what subfolders do you see in there (I see 'bin', 'cygwin', and 'tiobj2bin')
    There are folder cygwin and bin,no folder tiobj2bin
    I've attached the tiobj2bin folder from my 5.3.0 install. Hopefully you can just drop that in and you aren't missing any other dependencies.
    ki
    tiobj2bin.zip
