  • Resolved
profiling on CCS 5.2
I tried to get all functions profiling, but I couldn't.
As running my program, I setup
Tool -> Profile -> Setup Profile Data Collection
All I get is like this,
I know there is another way to get profile using "time.h"
But it's very inconvenience. Is there anyone can help me to get profiling of all functions?
Thanks a lot.
IDE version - CCS 5.2
Processor - DM8168, trying to analyze a program on C674x
Chiung
  • Hello Chiung,
    The CCS function profiler is not supported on C6000 HW. Depending on what emulator and if you using BIOS or not, you may have other options for profiling. Please provide as much details on your environment as possible.
    ki
    Did you read the CCS Forum Guidelines & FAQ? If not, PLEASE read it. If you haven't read it in awhile, please read it again to see if any updates were made.
    Having CCS problems? Check out the CCS Troubleshooting Guide
    Looking for CCS Training? Check out the CCS Training Site
    Curious about the status of a bug and know the tracking ID? Track it via the public bug tracking portal
    NOTE: When a bug is filed and a tracking ID is provided, the thread may then be suggested as "TI Thinks Resolved". Why? Please read the first FAQ of the CCS Forum Guidelines & FAQ
  • In reply to Ki-Soo Lee:
    Hi Ki-Soo Lee,
    My simulation environment is
    no BIOS, TI XDS100v2 USB emulator
    Using BIOS, I can log timing information by LOG events, but it's really inconvinence.
    By the way, as my code size becomes larger, I cannot use XDC tool because the memory location is fixed in some defualt files, and it's not large enough for my program.
    Where can I modify the memory setting?
    Thanks.
    Chiung
  • In reply to Lin Chiung:
    Hi Chiung,
    Sorry for the lat response.
    Unfortunately your options for function profiling support with the debugger on C6000 HW with an XDS100v2 is limited.
    One possible options is because you are using C6000, you can try taking a look at Path Profiling. Basically the compiler will add additional instrumentation code to you application to collect profiling data. This will add to your code size (for the additional instrumentation code and for memory to store the collected data) but the benefits are that it is non-intrusive in the way it collects the data. You can then view profiling data via function and line level in CCS.
    More information on this is in the C6000 Compiler User's Guide (section 3.8 and 3.9);
    http://www.ti.com/lit/ug/spru187u/spru187u.pdf
    Hope this helps
    ki
