I'm using TMS470F03107 with custom designed board and XDS200 usb debugger. I'm able to enter debug session and debug my code but after while (approx. less then 1-2 minutes)CCS hangs out and becomes not responsive untill i unplug the debugger. after which ccs restores and gives the following error:
Memory Map Setup for Flash @ Address 0x0IcePick: Error: (Error -2172 @ 0x0) Unable to communicate with the emulator. Confirm emulator configuration and connections, reset the emulator, and retry the operation. (Emulation package 5.1.507.0)
Dap: Error: (Error -2172 @ 0x0) Unable to communicate with the emulator. Confirm emulator configuration and connections, reset the emulator, and retry the operation. (Emulation package 5.1.507.0)
CortexM3_0: JTAG Communication Error: (Error -2172 @ 0x0) Unable to communicate with the emulator. Confirm emulator configuration and connections, reset the emulator, and retry the operation. (Emulation package 5.1.507.0)
CCS version 6
i have noticed that duration for which i'm able to debug decreases as i increase TCK clock.
attached is the log files generated by ccs
