I am unable to open a file in ccsv6.0 I have included the binary file in the same folder where main.c is present.
After fopen() the file pointer is holding NULL.
I am almost sure the default path is the output directory (either Debug, Release or a custom one), therefore you may be able to open the file if you copy it to the same directory as the .out file being executed.
You can also set a hard coded path (C:\temp or something similar). That never failed for me.
Hope this helps,
Rafael
I copied the file in output directory(Debug) and I tried placing it every where in the workspace, evne then I am getting the same.
The filepointer is having NULL (after having FILE *filepointer=fopen("blinky.bin","rb"));
