hi,
I got this to work by commenting out the errors and putting in the lines below. both the undefineds are in the driverlib in pin_map.h. everything else linked with the driverlib is working. whats up?
hi,
Hi Daniel,
As you can see at pin_map.h those defines are dependent on a preprocessor symbol,
PART_TM4C1294NCPDT
So, you need to add that at your CCS predefined symbols.
You, can also compare predefined symbols from known working example programs such as uart_echo.
- kel
