I'd like to build ccs5.5 project from the command line...yes, I have to use ccs5.5 because the Keystone 2 MCSDK does not support ccs6. Running it from the command line seems like it works, but it's raising an exception, so I'm not sure it isn't skipping any important steps before catching the exception. The exception isn't raised when the command is sudo'd, but that isn't an acceptable solution because not everyone will be on the sudo list.
user@ubuntu:~/workspace_v5_5$ ~/ti/ccsv5/eclipse/eclipse -noSplash -data ~/workspace_v5_5/ -application com.ti.ccstudio.apps.projectBuild -ccs.projects semaphore_direct_access_test -ccs.clean2014-08-21 15:05:11.876:WARN:oejuc.AbstractLifeCycle:FAILED SelectChannelConnector@0.0.0.0:80: java.net.SocketException: Permission denied java.net.SocketException: Permission denied at sun.nio.ch.Net.bind(Native Method) at sun.nio.ch.ServerSocketChannelImpl.bind(Unknown Source) at sun.nio.ch.ServerSocketAdaptor.bind(Unknown Source) at org.eclipse.jetty.server.nio.SelectChannelConnector.open(SelectChannelConnector.java:182) at org.eclipse.jetty.server.AbstractConnector.doStart(AbstractConnector.java:311) at org.eclipse.jetty.server.nio.SelectChannelConnector.doStart(SelectChannelConnector.java:260) at org.eclipse.jetty.util.component.AbstractLifeCycle.start(AbstractLifeCycle.java:59) at org.eclipse.jetty.server.Server.doStart(Server.java:273) at org.eclipse.jetty.util.component.AbstractLifeCycle.start(AbstractLifeCycle.java:59) at org.eclipse.equinox.http.jetty.internal.HttpServerManager.updated(HttpServerManager.java:113) at org.eclipse.equinox.http.jetty.internal.Activator.start(Activator.java:62) at org.eclipse.osgi.framework.internal.core.BundleContextImpl$1.run(BundleContextImpl.java:711) at java.security.AccessController.doPrivileged(Native Method) at org.eclipse.osgi.framework.internal.core.BundleContextImpl.startActivator(BundleContextImpl.java:702) at org.eclipse.osgi.framework.internal.core.BundleContextImpl.start(BundleContextImpl.java:683) at org.eclipse.osgi.framework.internal.core.BundleHost.startWorker(BundleHost.java:381) at org.eclipse.osgi.framework.internal.core.AbstractBundle.resume(AbstractBundle.java:390) at org.eclipse.osgi.framework.internal.core.Framework.resumeBundle(Framework.java:1176) at org.eclipse.osgi.framework.internal.core.StartLevelManager.resumeBundles(StartLevelManager.java:559) at org.eclipse.osgi.framework.internal.core.StartLevelManager.resumeBundles(StartLevelManager.java:544) at org.eclipse.osgi.framework.internal.core.StartLevelManager.incFWSL(StartLevelManager.java:457) at org.eclipse.osgi.framework.internal.core.StartLevelManager.doSetStartLevel(StartLevelManager.java:243) at org.eclipse.osgi.framework.internal.core.StartLevelManager.dispatchEvent(StartLevelManager.java:438) at org.eclipse.osgi.framework.internal.core.StartLevelManager.dispatchEvent(StartLevelManager.java:1) at org.eclipse.osgi.framework.eventmgr.EventManager.dispatchEvent(EventManager.java:230) at org.eclipse.osgi.framework.eventmgr.EventManager$EventThread.run(EventManager.java:340) 2014-08-21 15:05:11.877:WARN:oejuc.AbstractLifeCycle:FAILED org.eclipse.jetty.server.Server@ba6c13: java.net.SocketException: Permission denied java.net.SocketException: Permission denied at sun.nio.ch.Net.bind(Native Method) at sun.nio.ch.ServerSocketChannelImpl.bind(Unknown Source) at sun.nio.ch.ServerSocketAdaptor.bind(Unknown Source) at org.eclipse.jetty.server.nio.SelectChannelConnector.open(SelectChannelConnector.java:182) at org.eclipse.jetty.server.AbstractConnector.doStart(AbstractConnector.java:311) at org.eclipse.jetty.server.nio.SelectChannelConnector.doStart(SelectChannelConnector.java:260) at org.eclipse.jetty.util.component.AbstractLifeCycle.start(AbstractLifeCycle.java:59) at org.eclipse.jetty.server.Server.doStart(Server.java:273) at org.eclipse.jetty.util.component.AbstractLifeCycle.start(AbstractLifeCycle.java:59) at org.eclipse.equinox.http.jetty.internal.HttpServerManager.updated(HttpServerManager.java:113) at org.eclipse.equinox.http.jetty.internal.Activator.start(Activator.java:62) at org.eclipse.osgi.framework.internal.core.BundleContextImpl$1.run(BundleContextImpl.java:711) at java.security.AccessController.doPrivileged(Native Method) at org.eclipse.osgi.framework.internal.core.BundleContextImpl.startActivator(BundleContextImpl.java:702) at org.eclipse.osgi.framework.internal.core.BundleContextImpl.start(BundleContextImpl.java:683) at org.eclipse.osgi.framework.internal.core.BundleHost.startWorker(BundleHost.java:381) at org.eclipse.osgi.framework.internal.core.AbstractBundle.resume(AbstractBundle.java:390) at org.eclipse.osgi.framework.internal.core.Framework.resumeBundle(Framework.java:1176) at org.eclipse.osgi.framework.internal.core.StartLevelManager.resumeBundles(StartLevelManager.java:559) at org.eclipse.osgi.framework.internal.core.StartLevelManager.resumeBundles(StartLevelManager.java:544) at org.eclipse.osgi.framework.internal.core.StartLevelManager.incFWSL(StartLevelManager.java:457) at org.eclipse.osgi.framework.internal.core.StartLevelManager.doSetStartLevel(StartLevelManager.java:243) at org.eclipse.osgi.framework.internal.core.StartLevelManager.dispatchEvent(StartLevelManager.java:438) at org.eclipse.osgi.framework.internal.core.StartLevelManager.dispatchEvent(StartLevelManager.java:1) at org.eclipse.osgi.framework.eventmgr.EventManager.dispatchEvent(EventManager.java:230) at org.eclipse.osgi.framework.eventmgr.EventManager$EventThread.run(EventManager.java:340) %%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%% CCS headless build starting... [Thu Aug 21 15:05:13 EDT 2014] %%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%% ================================================================================ Pre processing... ================================================================================ Building... **** Clean-only build of configuration Debug for project semaphore_direct_access_test **** /home/c2e/ti/ccsv5/utils/bin/gmake -k clean rm -rf "configPkg/linker.cmd" "configPkg/compiler.opt" "semaphore_direct_access_test.out" rm -rf "configPkg/" rm -rf "main_direct.pp" "platform_osal.pp" "resourcemgr.pp" rm -rf "main_direct.obj" "platform_osal.obj" "resourcemgr.obj" Finished clean **** Build Finished **** ================================================================================ CCS headless build complete!
