Updated from 5.4 to 5.5, then did a check-for-software-updates from within ccs, got an error and following the procedure in the error box.2337.60556FE5-C1A1-4061-8DF8-FFB8393BAE2D.zip
One of the updates failed to complete successfully. Please:
Download http://software-dl.ti.com/ccs/esd/test/ti_cgt_c2000_6.2.8_windows_installer.exe
Run with the command line
ti_cgt_c2000_6.2.8_windows_installer.exe --mode unattended --ccs true --prefix "C:/ti/ccsv5" --eclipseprefix "C:/ti/ccsv5/eclipse"
Edit the file ccsv5\eclipse\ccs_config.xml (if it's renamed ccs_config.xml.bk, remove the .bk extension). Set the "feature registered" to "feature installed".
Please let me know if you run into any problems.
Danish
