When I try to open CCS5.5 (I've tried a new workspace and existing workspace) I get a message that there was an error. I have attached the log.
CCS5.5 has worked fine in the past, the only change I have made is installing CCS6.
David
!SESSION 2014-09-16 10:56:10.223 ----------------------------------------------- eclipse.buildId=M20120914-1540 java.version=1.6.0_13 java.vendor=Sun Microsystems Inc. BootLoader constants: OS=win32, ARCH=x86, WS=win32, NL=en_US Framework arguments: -product com.ti.ccstudio.branding.product Command-line arguments: -os win32 -ws win32 -arch x86 -product com.ti.ccstudio.branding.product !ENTRY org.eclipse.ui 4 4 2014-09-16 10:56:47.058 !MESSAGE The proxied handler for 'com.ti.ccstudio.debug.internal.ui.modules.ShowPreferencesHandler' could not be loaded !ENTRY org.eclipse.ui 4 0 2014-09-16 10:56:47.095 !MESSAGE The proxied handler for 'com.ti.ccstudio.debug.internal.ui.modules.ShowPreferencesHandler' could not be loaded !STACK 1 org.eclipse.core.runtime.CoreException: Plug-in "com.ti.ccstudio.debug.ui" was unable to instantiate class "com.ti.ccstudio.debug.internal.ui.modules.ShowPreferencesHandler". at org.eclipse.core.internal.registry.osgi.RegistryStrategyOSGI.throwException(RegistryStrategyOSGI.java:194) at org.eclipse.core.internal.registry.osgi.RegistryStrategyOSGI.createExecutableExtension(RegistryStrategyOSGI.java:188) at org.eclipse.core.internal.registry.ExtensionRegistry.createExecutableExtension(ExtensionRegistry.java:905) at org.eclipse.core.internal.registry.ConfigurationElement.createExecutableExtension(ConfigurationElement.java:243) at org.eclipse.core.internal.registry.ConfigurationElementHandle.createExecutableExtension(ConfigurationElementHandle.java:55) at org.eclipse.ui.internal.handlers.HandlerProxy.loadHandler(HandlerProxy.java:347) at org.eclipse.ui.internal.handlers.HandlerProxy.isEnabled(HandlerProxy.java:316) at org.eclipse.core.commands.Command.isEnabled(Command.java:862) at org.eclipse.core.commands.Command.setHandler(Command.java:1025) at org.eclipse.ui.internal.handlers.HandlerAuthority.updateCommand(HandlerAuthority.java:459) at org.eclipse.ui.internal.handlers.HandlerAuthority.activateHandler(HandlerAuthority.java:249) at org.eclipse.ui.internal.handlers.HandlerService.activateHandler(HandlerService.java:120) at org.eclipse.ui.internal.handlers.HandlerService.activateHandler(HandlerService.java:112) at org.eclipse.ui.internal.handlers.HandlerPersistence.readHandlersFromRegistry(HandlerPersistence.java:313) at org.eclipse.ui.internal.handlers.HandlerPersistence.reRead(HandlerPersistence.java:219) at org.eclipse.ui.internal.handlers.HandlerPersistence.read(HandlerPersistence.java:167) at org.eclipse.ui.internal.handlers.HandlerService.readRegistry(HandlerService.java:186) at org.eclipse.ui.internal.handlers.HandlerServiceFactory.create(HandlerServiceFactory.java:61) at org.eclipse.ui.internal.services.WorkbenchServiceRegistry.getService(WorkbenchServiceRegistry.java:103) at org.eclipse.ui.internal.services.ServiceLocator.getService(ServiceLocator.java:174) at org.eclipse.ui.internal.Workbench$49.runWithException(Workbench.java:1892) at org.eclipse.ui.internal.StartupThreading$StartupRunnable.run(StartupThreading.java:31) at org.eclipse.swt.widgets.RunnableLock.run(RunnableLock.java:35) at org.eclipse.swt.widgets.Synchronizer.runAsyncMessages(Synchronizer.java:135) at org.eclipse.swt.widgets.Display.runAsyncMessages(Display.java:4144) at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java:3761) at org.eclipse.ui.internal.Workbench.runUI(Workbench.java:2609) at org.eclipse.ui.internal.Workbench.access$4(Workbench.java:2499) at org.eclipse.ui.internal.Workbench$7.run(Workbench.java:679) at org.eclipse.core.databinding.observable.Realm.runWithDefault(Realm.java:332) at org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Workbench.java:668) at org.eclipse.ui.PlatformUI.createAndRunWorkbench(PlatformUI.java:149) at org.eclipse.ui.internal.ide.application.IDEApplication.start(IDEApplication.java:124) at org.eclipse.equinox.internal.app.EclipseAppHandle.run(EclipseAppHandle.java:196) at org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher.runApplication(EclipseAppLauncher.java:110) at org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher.start(EclipseAppLauncher.java:79) at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:353) at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:180) at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method) at sun.reflect.NativeMethodAccessorImpl.invoke(Unknown Source) at sun.reflect.DelegatingMethodAccessorImpl.invoke(Unknown Source) at java.lang.reflect.Method.invoke(Unknown Source) at org.eclipse.equinox.launcher.Main.invokeFramework(Main.java:629) at org.eclipse.equinox.launcher.Main.basicRun(Main.java:584) at org.eclipse.equinox.launcher.Main.run(Main.java:1438) Caused by: java.lang.NoClassDefFoundError: com/ti/debug/engine/events/types/IObjectEventListener at com.ti.ccstudio.debug.ui.commands.AbstractDebugHandler.<init>(AbstractDebugHandler.java:42) at com.ti.ccstudio.debug.internal.ui.modules.ShowPreferencesHandler.<init>(ShowPreferencesHandler.java:29) at sun.reflect.NativeConstructorAccessorImpl.newInstance0(Native Method) at sun.reflect.NativeConstructorAccessorImpl.newInstance(Unknown Source) at sun.reflect.DelegatingConstructorAccessorImpl.newInstance(Unknown Source) at java.lang.reflect.Constructor.newInstance(Unknown Source) at java.lang.Class.newInstance0(Unknown Source) at java.lang.Class.newInstance(Unknown Source) at org.eclipse.core.internal.registry.osgi.RegistryStrategyOSGI.createExecutableExtension(RegistryStrategyOSGI.java:184) ... 43 more Caused by: java.lang.ClassNotFoundException: com.ti.debug.engine.events.types.IObjectEventListener at org.eclipse.osgi.internal.loader.BundleLoader.findClassInternal(BundleLoader.java:501) at org.eclipse.osgi.internal.loader.BundleLoader.findClass(BundleLoader.java:421) at org.eclipse.osgi.internal.loader.BundleLoader.findClass(BundleLoader.java:412) at org.eclipse.osgi.internal.baseadaptor.DefaultClassLoader.loadClass(DefaultClassLoader.java:107) at java.lang.ClassLoader.loadClass(Unknown Source) at java.lang.ClassLoader.loadClassInternal(Unknown Source) ... 52 more !SUBENTRY 1 org.eclipse.equinox.registry 4 1 2014-09-16 10:56:47.095 !MESSAGE Plug-in "com.ti.ccstudio.debug.ui" was unable to instantiate class "com.ti.ccstudio.debug.internal.ui.modules.ShowPreferencesHandler". !STACK 0 java.lang.NoClassDefFoundError: com/ti/debug/engine/events/types/IObjectEventListener at com.ti.ccstudio.debug.ui.commands.AbstractDebugHandler.<init>(AbstractDebugHandler.java:42) at com.ti.ccstudio.debug.internal.ui.modules.ShowPreferencesHandler.<init>(ShowPreferencesHandler.java:29) at sun.reflect.NativeConstructorAccessorImpl.newInstance0(Native Method) at sun.reflect.NativeConstructorAccessorImpl.newInstance(Unknown Source) at sun.reflect.DelegatingConstructorAccessorImpl.newInstance(Unknown Source) at java.lang.reflect.Constructor.newInstance(Unknown Source) at java.lang.Class.newInstance0(Unknown Source) at java.lang.Class.newInstance(Unknown Source) at org.eclipse.core.internal.registry.osgi.RegistryStrategyOSGI.createExecutableExtension(RegistryStrategyOSGI.java:184) at org.eclipse.core.internal.registry.ExtensionRegistry.createExecutableExtension(ExtensionRegistry.java:905) at org.eclipse.core.internal.registry.ConfigurationElement.createExecutableExtension(ConfigurationElement.java:243) at org.eclipse.core.internal.registry.ConfigurationElementHandle.createExecutableExtension(ConfigurationElementHandle.java:55) at org.eclipse.ui.internal.handlers.HandlerProxy.loadHandler(HandlerProxy.java:347) at org.eclipse.ui.internal.handlers.HandlerProxy.isEnabled(HandlerProxy.java:316) at org.eclipse.core.commands.Command.isEnabled(Command.java:862) at org.eclipse.core.commands.Command.setHandler(Command.java:1025) at org.eclipse.ui.internal.handlers.HandlerAuthority.updateCommand(HandlerAuthority.java:459) at org.eclipse.ui.internal.handlers.HandlerAuthority.activateHandler(HandlerAuthority.java:249) at org.eclipse.ui.internal.handlers.HandlerService.activateHandler(HandlerService.java:120) at org.eclipse.ui.internal.handlers.HandlerService.activateHandler(HandlerService.java:112) at org.eclipse.ui.internal.handlers.HandlerPersistence.readHandlersFromRegistry(HandlerPersistence.java:313) at org.eclipse.ui.internal.handlers.HandlerPersistence.reRead(HandlerPersistence.java:219) at org.eclipse.ui.internal.handlers.HandlerPersistence.read(HandlerPersistence.java:167) at org.eclipse.ui.internal.handlers.HandlerService.readRegistry(HandlerService.java:186) at org.eclipse.ui.internal.handlers.HandlerServiceFactory.create(HandlerServiceFactory.java:61) at org.eclipse.ui.internal.services.WorkbenchServiceRegistry.getService(WorkbenchServiceRegistry.java:103) at org.eclipse.ui.internal.services.ServiceLocator.getService(ServiceLocator.java:174) at org.eclipse.ui.internal.Workbench$49.runWithException(Workbench.java:1892) at org.eclipse.ui.internal.StartupThreading$StartupRunnable.run(StartupThreading.java:31) at org.eclipse.swt.widgets.RunnableLock.run(RunnableLock.java:35) at org.eclipse.swt.widgets.Synchronizer.runAsyncMessages(Synchronizer.java:135) at org.eclipse.swt.widgets.Display.runAsyncMessages(Display.java:4144) at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java:3761) at org.eclipse.ui.internal.Workbench.runUI(Workbench.java:2609) at org.eclipse.ui.internal.Workbench.access$4(Workbench.java:2499) at org.eclipse.ui.internal.Workbench$7.run(Workbench.java:679) at org.eclipse.core.databinding.observable.Realm.runWithDefault(Realm.java:332) at org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Workbench.java:668) at org.eclipse.ui.PlatformUI.createAndRunWorkbench(PlatformUI.java:149) at org.eclipse.ui.internal.ide.application.IDEApplication.start(IDEApplication.java:124) at org.eclipse.equinox.internal.app.EclipseAppHandle.run(EclipseAppHandle.java:196) at org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher.runApplication(EclipseAppLauncher.java:110) at org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher.start(EclipseAppLauncher.java:79) at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:353) at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:180) at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method) at sun.reflect.NativeMethodAccessorImpl.invoke(Unknown Source) at sun.reflect.DelegatingMethodAccessorImpl.invoke(Unknown Source) at java.lang.reflect.Method.invoke(Unknown Source) at org.eclipse.equinox.launcher.Main.invokeFramework(Main.java:629) at org.eclipse.equinox.launcher.Main.basicRun(Main.java:584) at org.eclipse.equinox.launcher.Main.run(Main.java:1438) Caused by: java.lang.ClassNotFoundException: com.ti.debug.engine.events.types.IObjectEventListener at org.eclipse.osgi.internal.loader.BundleLoader.findClassInternal(BundleLoader.java:501) at org.eclipse.osgi.internal.loader.BundleLoader.findClass(BundleLoader.java:421) at org.eclipse.osgi.internal.loader.BundleLoader.findClass(BundleLoader.java:412) at org.eclipse.osgi.internal.baseadaptor.DefaultClassLoader.loadClass(DefaultClassLoader.java:107) at java.lang.ClassLoader.loadClass(Unknown Source) at java.lang.ClassLoader.loadClassInternal(Unknown Source) ... 52 more !ENTRY org.eclipse.ui 4 4 2014-09-16 10:56:47.098 !MESSAGE The proxied handler for 'com.ti.ccstudio.debug.ui.commands.FindSymbol' could not be loaded !ENTRY org.eclipse.ui 4 0 2014-09-16 10:56:47.098 !MESSAGE The proxied handler for 'com.ti.ccstudio.debug.ui.commands.FindSymbol' could not be loaded !STACK 1 org.eclipse.core.runtime.CoreException: Plug-in "com.ti.ccstudio.debug.ui" was unable to instantiate class "com.ti.ccstudio.debug.ui.commands.FindSymbol". at org.eclipse.core.internal.registry.osgi.RegistryStrategyOSGI.throwException(RegistryStrategyOSGI.java:194) at org.eclipse.core.internal.registry.osgi.RegistryStrategyOSGI.createExecutableExtension(RegistryStrategyOSGI.java:188) at org.eclipse.core.internal.registry.ExtensionRegistry.createExecutableExtension(ExtensionRegistry.java:905) at org.eclipse.core.internal.registry.ConfigurationElement.createExecutableExtension(ConfigurationElement.java:243) at org.eclipse.core.internal.registry.ConfigurationElementHandle.createExecutableExtension(ConfigurationElementHandle.java:55) at org.eclipse.ui.internal.handlers.HandlerProxy.loadHandler(HandlerProxy.java:347) at org.eclipse.ui.internal.handlers.HandlerProxy.isEnabled(HandlerProxy.java:316) at org.eclipse.core.commands.Command.isEnabled(Command.java:862) at org.eclipse.core.commands.Command.setHandler(Command.java:1025) at org.eclipse.ui.internal.handlers.HandlerAuthority.updateCommand(HandlerAuthority.java:459) at org.eclipse.ui.internal.handlers.HandlerAuthority.activateHandler(HandlerAuthority.java:249) at org.eclipse.ui.internal.handlers.HandlerService.activateHandler(HandlerService.java:120) at org.eclipse.ui.internal.handlers.HandlerService.activateHandler(HandlerService.java:112) at org.eclipse.ui.internal.handlers.HandlerPersistence.readHandlersFromRegistry(HandlerPersistence.java:313) at org.eclipse.ui.internal.handlers.HandlerPersistence.reRead(HandlerPersistence.java:219) at org.eclipse.ui.internal.handlers.HandlerPersistence.read(HandlerPersistence.java:167) at org.eclipse.ui.internal.handlers.HandlerService.readRegistry(HandlerService.java:186) at org.eclipse.ui.internal.handlers.HandlerServiceFactory.create(HandlerServiceFactory.java:61) at org.eclipse.ui.internal.services.WorkbenchServiceRegistry.getService(WorkbenchServiceRegistry.java:103) at org.eclipse.ui.internal.services.ServiceLocator.getService(ServiceLocator.java:174) at org.eclipse.ui.internal.Workbench$49.runWithException(Workbench.java:1892) at org.eclipse.ui.internal.StartupThreading$StartupRunnable.run(StartupThreading.java:31) at org.eclipse.swt.widgets.RunnableLock.run(RunnableLock.java:35) at org.eclipse.swt.widgets.Synchronizer.runAsyncMessages(Synchronizer.java:135) at org.eclipse.swt.widgets.Display.runAsyncMessages(Display.java:4144) at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java:3761) at org.eclipse.ui.internal.Workbench.runUI(Workbench.java:2609) at org.eclipse.ui.internal.Workbench.access$4(Workbench.java:2499) at org.eclipse.ui.internal.Workbench$7.run(Workbench.java:679) at org.eclipse.core.databinding.observable.Realm.runWithDefault(Realm.java:332) at org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Workbench.java:668) at org.eclipse.ui.PlatformUI.createAndRunWorkbench(PlatformUI.java:149) at org.eclipse.ui.internal.ide.application.IDEApplication.start(IDEApplication.java:124) at org.eclipse.equinox.internal.app.EclipseAppHandle.run(EclipseAppHandle.java:196) at org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher.runApplication(EclipseAppLauncher.java:110) at org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher.start(EclipseAppLauncher.java:79) at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:353) at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:180) at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method) at sun.reflect.NativeMethodAccessorImpl.invoke(Unknown Source) at sun.reflect.DelegatingMethodAccessorImpl.invoke(Unknown Source) at java.lang.reflect.Method.invoke(Unknown Source) at org.eclipse.equinox.launcher.Main.invokeFramework(Main.java:629) at org.eclipse.equinox.launcher.Main.basicRun(Main.java:584) at org.eclipse.equinox.launcher.Main.run(Main.java:1438) Caused by: java.lang.NoClassDefFoundError: com/ti/debug/engine/events/types/IObjectEventListener at com.ti.ccstudio.debug.ui.commands.AbstractDebugHandler.<init>(AbstractDebugHandler.java:42) at com.ti.ccstudio.debug.ui.commands.FindSymbol.<init>(FindSymbol.java:26) at sun.reflect.NativeConstructorAccessorImpl.newInstance0(Native Method) at sun.reflect.NativeConstructorAccessorImpl.newInstance(Unknown Source) at sun.reflect.DelegatingConstructorAccessorImpl.newInstance(Unknown Source) at java.lang.reflect.Constructor.newInstance(Unknown Source) at java.lang.Class.newInstance0(Unknown Source) at java.lang.Class.newInstance(Unknown Source) at org.eclipse.core.internal.registry.osgi.RegistryStrategyOSGI.createExecutableExtension(RegistryStrategyOSGI.java:184) ... 43 more Caused by: java.lang.ClassNotFoundException: com.ti.debug.engine.events.types.IObjectEventListener at org.eclipse.osgi.internal.loader.BundleLoader.findClassInternal(BundleLoader.java:501) at org.eclipse.osgi.internal.loader.BundleLoader.findClass(BundleLoader.java:421) at org.eclipse.osgi.internal.loader.BundleLoader.findClass(BundleLoader.java:412) at org.eclipse.osgi.internal.baseadaptor.DefaultClassLoader.loadClass(DefaultClassLoader.java:107) at java.lang.ClassLoader.loadClass(Unknown Source) at java.lang.ClassLoader.loadClassInternal(Unknown Source) ... 52 more !SUBENTRY 1 org.eclipse.equinox.registry 4 1 2014-09-16 10:56:47.098 !MESSAGE Plug-in "com.ti.ccstudio.debug.ui" was unable to instantiate class "com.ti.ccstudio.debug.ui.commands.FindSymbol". !STACK 0 java.lang.NoClassDefFoundError: com/ti/debug/engine/events/types/IObjectEventListener at com.ti.ccstudio.debug.ui.commands.AbstractDebugHandler.<init>(AbstractDebugHandler.java:42) at com.ti.ccstudio.debug.ui.commands.FindSymbol.<init>(FindSymbol.java:26) at sun.reflect.NativeConstructorAccessorImpl.newInstance0(Native Method) at sun.reflect.NativeConstructorAccessorImpl.newInstance(Unknown Source) at sun.reflect.DelegatingConstructorAccessorImpl.newInstance(Unknown Source) at java.lang.reflect.Constructor.newInstance(Unknown Source) at java.lang.Class.newInstance0(Unknown Source) at java.lang.Class.newInstance(Unknown Source) at org.eclipse.core.internal.registry.osgi.RegistryStrategyOSGI.createExecutableExtension(RegistryStrategyOSGI.java:184) at org.eclipse.core.internal.registry.ExtensionRegistry.createExecutableExtension(ExtensionRegistry.java:905) at org.eclipse.core.internal.registry.ConfigurationElement.createExecutableExtension(ConfigurationElement.java:243) at org.eclipse.core.internal.registry.ConfigurationElementHandle.createExecutableExtension(ConfigurationElementHandle.java:55) at org.eclipse.ui.internal.handlers.HandlerProxy.loadHandler(HandlerProxy.java:347) at org.eclipse.ui.internal.handlers.HandlerProxy.isEnabled(HandlerProxy.java:316) at org.eclipse.core.commands.Command.isEnabled(Command.java:862) at org.eclipse.core.commands.Command.setHandler(Command.java:1025) at org.eclipse.ui.internal.handlers.HandlerAuthority.updateCommand(HandlerAuthority.java:459) at org.eclipse.ui.internal.handlers.HandlerAuthority.activateHandler(HandlerAuthority.java:249) at org.eclipse.ui.internal.handlers.HandlerService.activateHandler(HandlerService.java:120) at org.eclipse.ui.internal.handlers.HandlerService.activateHandler(HandlerService.java:112) at org.eclipse.ui.internal.handlers.HandlerPersistence.readHandlersFromRegistry(HandlerPersistence.java:313) at org.eclipse.ui.internal.handlers.HandlerPersistence.reRead(HandlerPersistence.java:219) at org.eclipse.ui.internal.handlers.HandlerPersistence.read(HandlerPersistence.java:167) at org.eclipse.ui.internal.handlers.HandlerService.readRegistry(HandlerService.java:186) at org.eclipse.ui.internal.handlers.HandlerServiceFactory.create(HandlerServiceFactory.java:61) at org.eclipse.ui.internal.services.WorkbenchServiceRegistry.getService(WorkbenchServiceRegistry.java:103) at org.eclipse.ui.internal.services.ServiceLocator.getService(ServiceLocator.java:174) at org.eclipse.ui.internal.Workbench$49.runWithException(Workbench.java:1892) at org.eclipse.ui.internal.StartupThreading$StartupRunnable.run(StartupThreading.java:31) at org.eclipse.swt.widgets.RunnableLock.run(RunnableLock.java:35) at org.eclipse.swt.widgets.Synchronizer.runAsyncMessages(Synchronizer.java:135) at org.eclipse.swt.widgets.Display.runAsyncMessages(Display.java:4144) at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java:3761) at org.eclipse.ui.internal.Workbench.runUI(Workbench.java:2609) at org.eclipse.ui.internal.Workbench.access$4(Workbench.java:2499) at org.eclipse.ui.internal.Workbench$7.run(Workbench.java:679) at org.eclipse.core.databinding.observable.Realm.runWithDefault(Realm.java:332) at org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Workbench.java:668) at org.eclipse.ui.PlatformUI.createAndRunWorkbench(PlatformUI.java:149) at org.eclipse.ui.internal.ide.application.IDEApplication.start(IDEApplication.java:124) at org.eclipse.equinox.internal.app.EclipseAppHandle.run(EclipseAppHandle.java:196) at org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher.runApplication(EclipseAppLauncher.java:110) at org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher.start(EclipseAppLauncher.java:79) at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:353) at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:180) at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method) at sun.reflect.NativeMethodAccessorImpl.invoke(Unknown Source) at sun.reflect.DelegatingMethodAccessorImpl.invoke(Unknown Source) at java.lang.reflect.Method.invoke(Unknown Source) at org.eclipse.equinox.launcher.Main.invokeFramework(Main.java:629) at org.eclipse.equinox.launcher.Main.basicRun(Main.java:584) at org.eclipse.equinox.launcher.Main.run(Main.java:1438) Caused by: java.lang.ClassNotFoundException: com.ti.debug.engine.events.types.IObjectEventListener at org.eclipse.osgi.internal.loader.BundleLoader.findClassInternal(BundleLoader.java:501) at org.eclipse.osgi.internal.loader.BundleLoader.findClass(BundleLoader.java:421) at org.eclipse.osgi.internal.loader.BundleLoader.findClass(BundleLoader.java:412) at org.eclipse.osgi.internal.baseadaptor.DefaultClassLoader.loadClass(DefaultClassLoader.java:107) at java.lang.ClassLoader.loadClass(Unknown Source) at java.lang.ClassLoader.loadClassInternal(Unknown Source) ... 52 more !ENTRY org.eclipse.ui 2 0 2014-09-16 10:56:47.599 !MESSAGE Warnings while parsing the viewer contributions from the 'org.eclipse.ui.popupMenus' extension point !SUBENTRY 1 org.eclipse.ui 2 0 2014-09-16 10:56:47.599 !MESSAGE invalid keybinding: Cannot bind to an incomplete key sequence: plug-in='org.eclipse.cdt.debug.ui', id='AUTOGEN:::org.eclipse.cdt.debug.ui.CEditorRulerActions/org.eclipse.cdt.debug.internal.ui.actions.CBreakpointPropertiesRulerActionDelegate' !SUBENTRY 1 org.eclipse.ui 2 0 2014-09-16 10:56:47.599 !MESSAGE invalid keybinding: Cannot bind to an incomplete key sequence: plug-in='org.eclipse.cdt.debug.ui', id='AUTOGEN:::org.eclipse.cdt.debug.ui.CEditorRulerActions/org.eclipse.cdt.debug.internal.ui.actions.EnableDisableBreakpointRulerActionDelegate' !SUBENTRY 1 org.eclipse.ui 2 0 2014-09-16 10:56:47.599 !MESSAGE invalid keybinding: Cannot bind to an incomplete key sequence: plug-in='org.eclipse.cdt.debug.ui', id='AUTOGEN:::org.eclipse.cdt.debug.ui.CEditorRulerActions/org.eclipse.cdt.debug.ui.actions.RulerCreateBreakpointInteractiveAction' !SUBENTRY 1 org.eclipse.ui 2 0 2014-09-16 10:56:47.599 !MESSAGE invalid keybinding: Cannot bind to an incomplete key sequence: plug-in='org.eclipse.cdt.debug.ui', id='AUTOGEN:::org.eclipse.cdt.debug.ui.AsmEditorRulerActions/org.eclipse.cdt.debug.internal.ui.actions.asm.CBreakpointPropertiesRulerActionDelegate' !SUBENTRY 1 org.eclipse.ui 2 0 2014-09-16 10:56:47.599 !MESSAGE invalid keybinding: Cannot bind to an incomplete key sequence: plug-in='org.eclipse.cdt.debug.ui', id='AUTOGEN:::org.eclipse.cdt.debug.ui.AsmEditorRulerActions/org.eclipse.cdt.debug.internal.ui.actions.asm.EnableDisableBreakpointRulerActionDelegate' !SUBENTRY 1 org.eclipse.ui 2 0 2014-09-16 10:56:47.599 !MESSAGE invalid keybinding: Cannot bind to an incomplete key sequence: plug-in='org.eclipse.cdt.debug.ui', id='AUTOGEN:::org.eclipse.cdt.debug.ui.AsmEditorRulerActions/org.eclipse.cdt.debug.ui.actions.asm.RulerCreateBreakpointInteractiveAction' !SUBENTRY 1 org.eclipse.ui 2 0 2014-09-16 10:56:47.599 !MESSAGE invalid keybinding: Cannot bind to an incomplete key sequence: plug-in='org.eclipse.cdt.dsf.ui', id='AUTOGEN:::org.eclipse.cdt.dsf.debug.ui.disassemblyRulerActions/org.eclipse.debug.ui.actions.RulerAddBreakpointAction' !SUBENTRY 1 org.eclipse.ui 2 0 2014-09-16 10:56:47.599 !MESSAGE invalid keybinding: Cannot bind to an incomplete key sequence: plug-in='org.eclipse.cdt.dsf.ui', id='org.eclipse.cdt.dsf.debug.ui.disassembly.commands.rulerToggleBreakpoint' !ENTRY org.eclipse.osgi 4 0 2014-09-16 10:56:50.169 !MESSAGE Application error !STACK 1 java.lang.NoClassDefFoundError: com/ti/xpcom/XPCOMException at com.ti.ccstudio.debug.ui.profileClockStatus.ProfileClockStatusBar.createControl(ProfileClockStatusBar.java:36) at org.eclipse.jface.action.ControlContribution.fill(ControlContribution.java:98) at org.eclipse.ui.internal.menus.DynamicMenuContributionItem.fill(DynamicMenuContributionItem.java:210) at org.eclipse.jface.action.ToolBarManager.update(ToolBarManager.java:353) at org.eclipse.jface.action.ToolBarManager.createControl(ToolBarManager.java:111) at org.eclipse.ui.internal.menus.TrimContributionManager$ToolBarTrimProxy.dock(TrimContributionManager.java:88) at org.eclipse.ui.internal.menus.TrimContributionManager.update(TrimContributionManager.java:265) at org.eclipse.ui.internal.WorkbenchWindow.updateLayoutDataForContents(WorkbenchWindow.java:3874) at org.eclipse.ui.internal.WorkbenchWindow.setLayoutDataForContents(WorkbenchWindow.java:3885) at org.eclipse.ui.internal.WorkbenchWindow.createDefaultContents(WorkbenchWindow.java:1157) at org.eclipse.ui.internal.WorkbenchWindowConfigurer.createDefaultContents(WorkbenchWindowConfigurer.java:623) at org.eclipse.ui.application.WorkbenchWindowAdvisor.createWindowContents(WorkbenchWindowAdvisor.java:300) at org.eclipse.ui.internal.WorkbenchWindow.createContents(WorkbenchWindow.java:1043) at org.eclipse.jface.window.Window.create(Window.java:431) at org.eclipse.ui.internal.Workbench$22.runWithException(Workbench.java:1216) at org.eclipse.ui.internal.StartupThreading$StartupRunnable.run(StartupThreading.java:31) at org.eclipse.swt.widgets.RunnableLock.run(RunnableLock.java:35) at org.eclipse.swt.widgets.Synchronizer.runAsyncMessages(Synchronizer.java:135) at org.eclipse.swt.widgets.Display.runAsyncMessages(Display.java:4144) at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java:3761) at org.eclipse.ui.application.WorkbenchAdvisor.openWindows(WorkbenchAdvisor.java:803) at org.eclipse.ui.internal.Workbench$33.runWithException(Workbench.java:1600) at org.eclipse.ui.internal.StartupThreading$StartupRunnable.run(StartupThreading.java:31) at org.eclipse.swt.widgets.RunnableLock.run(RunnableLock.java:35) at org.eclipse.swt.widgets.Synchronizer.runAsyncMessages(Synchronizer.java:135) at org.eclipse.swt.widgets.Display.runAsyncMessages(Display.java:4144) at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java:3761) at org.eclipse.ui.internal.Workbench.runUI(Workbench.java:2609) at org.eclipse.ui.internal.Workbench.access$4(Workbench.java:2499) at org.eclipse.ui.internal.Workbench$7.run(Workbench.java:679) at org.eclipse.core.databinding.observable.Realm.runWithDefault(Realm.java:332) at org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Workbench.java:668) at org.eclipse.ui.PlatformUI.createAndRunWorkbench(PlatformUI.java:149) at org.eclipse.ui.internal.ide.application.IDEApplication.start(IDEApplication.java:124) at org.eclipse.equinox.internal.app.EclipseAppHandle.run(EclipseAppHandle.java:196) at org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher.runApplication(EclipseAppLauncher.java:110) at org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher.start(EclipseAppLauncher.java:79) at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:353) at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:180) at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method) at sun.reflect.NativeMethodAccessorImpl.invoke(Unknown Source) at sun.reflect.DelegatingMethodAccessorImpl.invoke(Unknown Source) at java.lang.reflect.Method.invoke(Unknown Source) at org.eclipse.equinox.launcher.Main.invokeFramework(Main.java:629) at org.eclipse.equinox.launcher.Main.basicRun(Main.java:584) at org.eclipse.equinox.launcher.Main.run(Main.java:1438) Caused by: java.lang.ClassNotFoundException: com.ti.xpcom.XPCOMException at org.eclipse.osgi.internal.loader.BundleLoader.findClassInternal(BundleLoader.java:501) at org.eclipse.osgi.internal.loader.BundleLoader.findClass(BundleLoader.java:421) at org.eclipse.osgi.internal.loader.BundleLoader.findClass(BundleLoader.java:412) at org.eclipse.osgi.internal.baseadaptor.DefaultClassLoader.loadClass(DefaultClassLoader.java:107) at java.lang.ClassLoader.loadClass(Unknown Source) at java.lang.ClassLoader.loadClassInternal(Unknown Source) ... 46 more !ENTRY org.eclipse.core.jobs 2 2 2014-09-16 10:56:50.769 !MESSAGE Job found still running after platform shutdown. Jobs should be canceled by the plugin that scheduled them during shutdown: org.eclipse.ui.internal.AbstractWorkingSetManager$10 !ENTRY org.eclipse.core.jobs 2 2 2014-09-16 10:56:50.769 !MESSAGE Job found still running after platform shutdown. Jobs should be canceled by the plugin that scheduled them during shutdown: org.eclipse.ui.internal.AbstractWorkingSetManager$10 !ENTRY org.eclipse.core.jobs 2 2 2014-09-16 10:56:50.770 !MESSAGE Job found still running after platform shutdown. Jobs should be canceled by the plugin that scheduled them during shutdown: org.eclipse.ui.internal.AbstractWorkingSetManager$10 !ENTRY org.eclipse.core.jobs 2 2 2014-09-16 10:56:50.770 !MESSAGE Job found still running after platform shutdown. Jobs should be canceled by the plugin that scheduled them during shutdown: org.eclipse.ui.internal.AbstractWorkingSetManager$10 !ENTRY org.eclipse.core.jobs 2 2 2014-09-16 10:56:50.772 !MESSAGE Job found still running after platform shutdown. Jobs should be canceled by the plugin that scheduled them during shutdown: org.eclipse.ui.internal.AbstractWorkingSetManager$10 !ENTRY org.eclipse.core.jobs 2 2 2014-09-16 10:56:50.772 !MESSAGE Job found still running after platform shutdown. Jobs should be canceled by the plugin that scheduled them during shutdown: org.eclipse.ui.internal.AbstractWorkingSetManager$10 !ENTRY org.eclipse.core.jobs 2 2 2014-09-16 10:56:50.773 !MESSAGE Job found still running after platform shutdown. Jobs should be canceled by the plugin that scheduled them during shutdown: org.eclipse.ui.internal.AbstractWorkingSetManager$10
