What is difference between memory map defined in .map file and debugger memory map. I am using tms320c6416 device funtional simulator,C6416.cmd linker command file and tisim_init_64xx.gel and tisim_icl.gel startup gel files. But memory map in dubgger is not similar to one defined in .map file.Following are the snapshots for debugger memory map and .map file. According to my interpretion debugger memory map says that all space is avaliable.
