I'm using CCS 6 for the first time to load a SYS/BIOS SMP binary onto DRA7xx/IPU1. I get the following errors in the console window. This same program worked with CCS 5.5.
Cortex_M4_IPU1_C1: Trouble Setting Breakpoint with the Action "Process CIO" at 0x86012942: (Error -1067 @ 0x86012942) There is already a breakpoint at the requested address. This error may be caused by a shared memory SMP configuration. You may consider setting up shared memory in the memory map. (Emulation package 5.1.507.0)
Cortex_M4_IPU1_C1: Breakpoint Manager: Retrying with a AET breakpoint
Cortex_M4_IPU1_C1: Breakpoint Manager: Error enabling this function: Address exceeds the allowed range
Cortex_M4_IPU1_C1: Trouble Setting Breakpoint with the Action "Terminate Program Execution" at 0x86013a30: (Error -1067 @ 0x86013A30) There is already a breakpoint at the requested address. This error may be caused by a shared memory SMP configuration. You may consider setting up shared memory in the memory map. (Emulation package 5.1.507.0)
What should I be doing in order to avoid these errors?
~Ramsey
