hi everyone
When I want to use the library files I get some errors.
I'm sure I've added header and library
please tell me how to call the library files and what should i do....
thanks
aria li
Moving this to the CCS forum.
hi ki
thanks for your advice.that error is ok.
Now I want to use the library in example But get some new errors.
d:/.../am43xx_debug\libutils.a(console_utils.o) uses VFP register arguments, libuse_test_2.out does not
d:/.../ld.exe: failed to merge target specific data of file
D:/.../am43xx_debug\libutils.a(console_utils.o)
please give me some advice......
thanks
aria li
aria li said:d:/.../am43xx_debug\libutils.a(console_utils.o) uses VFP register arguments, libuse_test_2.out does not
Sounds like there is some mismatch between the two object files, basically difference in how floating-point is handled (the library and the executable were built with different options for floating point)
