Is it possible to create periodic timing events (i.e. calling a function periodically) or keyboard events in CCS version of javascript?
Also, is it possible to query whether a key was pressed?
Stephen
Stephen
Hi Stephen,
Note that there is no "CCS version of javascript". The javascript shell used by CCS/DSS is standard Rhino and supports standard javascript.
As for if javascript can support the actions you ask, I don't know off the top of my head. But googling around yielded some results
http://stackoverflow.com/questions/1224463/is-there-any-way-to-call-a-function-periodically-in-javascript
http://www.w3schools.com/jsref/event_onkeypress.asp
http://dmauro.github.io/Keypress/
ki
DSS is just a bunch of Java APIs. As long as java APIs can be called by the script (even if executed from a webpage), then it is fine. Most examples out there on the web are in context of a webpage since that is the dominant environment for javascript. But in many cases will work outside a webpage environment too.
Also if there is functionality missing from javascript, you may be able to do it via Java (file.io being a prime example). If I come across any examples, I'll let you know.
ki
