I'm trying to install Uniflash v3 on Windows 7. When I run the uniflash setup I keep getting errors about 30 seconds after it starts. In the logs it says "com.ti.ccstudio.p2app could not be found in the registry". Is there a way to fix this issue?
Hi Quincey,
Please delete the contents of the install directory before you try to re-install. It looks like you have an incomplete installation.
If this is not the case, please post install logs. Depending on the version of uniflash, you can find them in <installdir>/install_logs* or c:\program files\installjammer registry\uniflashv3 (program files (x86) if you're on a 64 bit computer). Note, the installjammer registry folder is a hidden folder.
Danish
