CCS 6 cannot be opened. it says an error has occurred. see the log file.
I am running Windows 7
log file:
!SESSION 2015-01-16 17:16:58.828 -----------------------------------------------
eclipse.buildId=4.3.0.M20130911-1000
java.version=1.6.0_13
java.vendor=Sun Microsystems Inc.
BootLoader constants: OS=win32, ARCH=x86, WS=win32, NL=en_US
Framework arguments: -product com.ti.ccstudio.branding.product
Command-line arguments: -os win32 -ws win32 -arch x86 -product com.ti.ccstudio.branding.product
This is a continuation of log file C:\Users\cliang\workspace_v6_0\.metadata\.bak_0.log
Created Time: 2015-01-16 17:17:24.102
!ENTRY org.eclipse.ui 4 4 2015-01-16 17:17:24.102
!MESSAGE Unhandled Exception
!ENTRY org.eclipse.equinox.p2.ui.sdk.scheduler 4 0 2015-01-16 17:17:24.102
!MESSAGE Unable to execute early startup code for an extension
!STACK 1
org.eclipse.core.runtime.CoreException: Plug-in "org.eclipse.equinox.p2.ui.sdk.scheduler" was unable to instantiate class "org.eclipse.equinox.internal.p2.ui.sdk.scheduler.AutomaticUpdateScheduler".
at org.eclipse.core.internal.registry.osgi.RegistryStrategyOSGI.throwException(RegistryStrategyOSGI.java:194)
at org.eclipse.core.internal.registry.osgi.RegistryStrategyOSGI.createExecutableExtension(RegistryStrategyOSGI.java:186)
at org.eclipse.core.internal.registry.ExtensionRegistry.createExecutableExtension(ExtensionRegistry.java:905)
at org.eclipse.core.internal.registry.ConfigurationElement.createExecutableExtension(ConfigurationElement.java:243)
at org.eclipse.core.internal.registry.ConfigurationElementHandle.createExecutableExtension(ConfigurationElementHandle.java:55)
at org.eclipse.ui.internal.WorkbenchPlugin$1.run(WorkbenchPlugin.java:282)
at org.eclipse.swt.custom.BusyIndicator.showWhile(BusyIndicator.java:52)
at org.eclipse.ui.internal.WorkbenchPlugin.createExtension(WorkbenchPlugin.java:278)
at org.eclipse.ui.internal.EarlyStartupRunnable.getExecutableExtension(EarlyStartupRunnable.java:117)
at org.eclipse.ui.internal.EarlyStartupRunnable.run(EarlyStartupRunnable.java:66)
at org.eclipse.core.runtime.SafeRunner.run(SafeRunner.java:42)
at org.eclipse.ui.internal.Workbench$55.run(Workbench.java:2551)
at org.eclipse.core.internal.jobs.Worker.run(Worker.java:53)
Caused by: java.lang.NullPointerException
at org.eclipse.equinox.internal.p2.ui.sdk.scheduler.AutomaticUpdateScheduler.<init>(AutomaticUpdateScheduler.java:73)
at sun.reflect.NativeConstructorAccessorImpl.newInstance0(Native Method)
at sun.reflect.NativeConstructorAccessorImpl.newInstance(Unknown Source)
at sun.reflect.DelegatingConstructorAccessorImpl.newInstance(Unknown Source)
at java.lang.reflect.Constructor.newInstance(Unknown Source)
at java.lang.Class.newInstance0(Unknown Source)
at java.lang.Class.newInstance(Unknown Source)
at org.eclipse.core.internal.registry.osgi.RegistryStrategyOSGI.createExecutableExtension(RegistryStrategyOSGI.java:184)
... 11 more
!SUBENTRY 1 org.eclipse.equinox.registry 4 1 2015-01-16 17:17:24.102
!MESSAGE Plug-in "org.eclipse.equinox.p2.ui.sdk.scheduler" was unable to instantiate class "org.eclipse.equinox.internal.p2.ui.sdk.scheduler.AutomaticUpdateScheduler".
!STACK 0
!ENTRY org.eclipse.ui.workbench 4 2 2015-01-16 17:17:24.227
!MESSAGE Problems occurred when invoking code from plug-in: "org.eclipse.ui.workbench".
!STACK 0
java.lang.ExceptionInInitializerError
at org.eclipse.rse.internal.ui.RSEUIStartup.earlyStartup(RSEUIStartup.java:19)
at org.eclipse.ui.internal.EarlyStartupRunnable.runEarlyStartup(EarlyStartupRunnable.java:87)
at org.eclipse.rse.internal.core.RSEInitJob.<init>(RSEInitJob.java:130)
at org.eclipse.rse.internal.core.RSEInitJob.<clinit>(RSEInitJob.java:62)
... 6 more
!ENTRY org.eclipse.ui 4 4 2015-01-16 17:17:24.227
!ENTRY org.eclipse.rse.ui 4 0 2015-01-16 17:17:24.227
!STACK 0
... 6 more
!ENTRY org.eclipse.core.jobs 2 2 2015-01-16 17:17:24.725
!MESSAGE Job found still running after platform shutdown. Jobs should be canceled by the plugin that scheduled them during shutdown: org.eclipse.epp.internal.mpc.ui.wizards.MarketplaceDropAdapter$1
!MESSAGE Job found still running after platform shutdown. Jobs should be canceled by the plugin that scheduled them during shutdown: org.eclipse.ui.internal.Workbench$55
!SESSION 2015-01-16 17:18:29.886 -----------------------------------------------
!ENTRY org.eclipse.core.resources 2 10035 2015-01-16 17:18:33.299
!MESSAGE The workspace exited with unsaved changes in the previous session; refreshing workspace to recover changes.
!ENTRY org.eclipse.osgi 4 0 2015-01-16 17:18:35.636
!MESSAGE Application error
!STACK 1
org.eclipse.swt.SWTException: Failed to execute runnable (java.lang.NullPointerException)
at org.eclipse.swt.SWT.error(SWT.java:4397)
at org.eclipse.swt.SWT.error(SWT.java:4312)
at org.eclipse.swt.widgets.Synchronizer.runAsyncMessages(Synchronizer.java:138)
at org.eclipse.swt.widgets.Display.runAsyncMessages(Display.java:4145)
at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java:3762)
at org.eclipse.swt.widgets.Display.release(Display.java:3815)
at org.eclipse.swt.graphics.Device.dispose(Device.java:295)
at org.eclipse.ui.internal.ide.application.IDEApplication.start(IDEApplication.java:140)
at org.eclipse.equinox.internal.app.EclipseAppHandle.run(EclipseAppHandle.java:196)
at org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher.runApplication(EclipseAppLauncher.java:110)
at org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher.start(EclipseAppLauncher.java:79)
at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:354)
at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:181)
at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method)
at sun.reflect.NativeMethodAccessorImpl.invoke(Unknown Source)
at sun.reflect.DelegatingMethodAccessorImpl.invoke(Unknown Source)
at java.lang.reflect.Method.invoke(Unknown Source)
at org.eclipse.equinox.launcher.Main.invokeFramework(Main.java:636)
at org.eclipse.equinox.launcher.Main.basicRun(Main.java:591)
at org.eclipse.equinox.launcher.Main.run(Main.java:1450)
at org.eclipse.ui.internal.Workbench.createWorkbenchWindow(Workbench.java:1376)
at org.eclipse.ui.internal.Workbench.getActiveWorkbenchWindow(Workbench.java:1369)
at org.eclipse.cdt.codan.internal.ui.cxx.Startup$1.run(Startup.java:39)
at org.eclipse.swt.widgets.RunnableLock.run(RunnableLock.java:35)
at org.eclipse.swt.widgets.Synchronizer.runAsyncMessages(Synchronizer.java:135)
... 17 more
!ENTRY org.eclipse.ui.workbench 4 2 2015-01-16 17:18:35.854
!STACK 1
... 11 more
!SUBENTRY 1 org.eclipse.equinox.registry 4 1 2015-01-16 17:18:35.854
!STACK 0
!STACK 0
!ENTRY org.eclipse.ui 4 4 2015-01-16 17:18:35.870
!ENTRY org.eclipse.equinox.p2.ui.sdk.scheduler 4 0 2015-01-16 17:18:35.870
!STACK 1
... 11 more
!SUBENTRY 1 org.eclipse.equinox.registry 4 1 2015-01-16 17:18:35.870
!STACK 0
!ENTRY org.eclipse.ui.workbench 4 2 2015-01-16 17:18:35.885
!STACK 0
... 6 more
!ENTRY org.eclipse.ui 4 4 2015-01-16 17:18:35.885
!ENTRY org.eclipse.rse.ui 4 0 2015-01-16 17:18:35.901
!STACK 0
... 6 more
!ENTRY org.eclipse.core.jobs 4 2 2015-01-16 17:18:35.901
!MESSAGE An internal error occurred during: "Workbench early startup".
!STACK 0
at org.eclipse.core.internal.registry.BufferedRandomInputStream.read(BufferedRandomInputStream.java:67)
at java.io.DataInputStream.readByte(Unknown Source)
at org.eclipse.core.internal.registry.TableReader.readStringOrNull(TableReader.java:376)
at org.eclipse.core.internal.registry.TableReader.basicLoadExtensionExtraData(TableReader.java:398)
at org.eclipse.core.internal.registry.TableReader.loadExtensionExtraData(TableReader.java:386)
at org.eclipse.core.internal.registry.Extension.getExtraData(Extension.java:81)
at org.eclipse.core.internal.registry.Extension.getContributorId(Extension.java:100)
at org.eclipse.core.internal.registry.Extension.getContributor(Extension.java:107)
at org.eclipse.core.internal.registry.BaseExtensionHandle.getContributor(BaseExtensionHandle.java:47)
at org.eclipse.core.internal.registry.BaseExtensionHandle.getNamespace(BaseExtensionHandle.java:39)
at org.eclipse.ui.internal.Workbench$55.run(Workbench.java:2549)
!ENTRY org.eclipse.core.jobs 2 2 2015-01-16 17:18:36.228
!MESSAGE Job found still running after platform shutdown. Jobs should be canceled by the plugin that scheduled them during shutdown: org.eclipse.ui.internal.AbstractWorkingSetManager$9
!ENTRY org.eclipse.core.jobs 2 2 2015-01-16 17:18:36.244
!ENTRY org.eclipse.core.jobs 4 2 2015-01-16 17:18:36.415
!STACK 0
!ENTRY org.eclipse.ui.workbench 4 0 2015-01-16 17:18:36.415
!MESSAGE An unexpected exception was thrown.
!STACK 0
at org.eclipse.ui.internal.services.WorkbenchServiceRegistry.getExtensionPoint(WorkbenchServiceRegistry.java:162)
at org.eclipse.ui.internal.services.WorkbenchServiceRegistry.loadFromRegistry(WorkbenchServiceRegistry.java:115)
at org.eclipse.ui.internal.services.WorkbenchServiceRegistry.getService(WorkbenchServiceRegistry.java:101)
at org.eclipse.ui.internal.services.ServiceLocator.getService(ServiceLocator.java:171)
at org.eclipse.ui.internal.Workbench.getService(Workbench.java:3404)
at org.eclipse.ui.internal.progress.ProgressManagerUtil.getNonModalShell(ProgressManagerUtil.java:385)
at org.eclipse.ui.internal.progress.ProgressManagerUtil.getDefaultParent(ProgressManagerUtil.java:376)
at org.eclipse.ui.internal.statushandlers.InternalDialog.<init>(InternalDialog.java:154)
at org.eclipse.ui.internal.statushandlers.WorkbenchStatusDialogManagerImpl.doAddStatusAdapter(WorkbenchStatusDialogManagerImpl.java:259)
at org.eclipse.ui.internal.statushandlers.WorkbenchStatusDialogManagerImpl.addStatusAdapter(WorkbenchStatusDialogManagerImpl.java:197)
at org.eclipse.ui.statushandlers.WorkbenchStatusDialogManager.addStatusAdapter(WorkbenchStatusDialogManager.java:156)
at org.eclipse.ui.statushandlers.WorkbenchErrorHandler.showStatusAdapter(WorkbenchErrorHandler.java:101)
at org.eclipse.ui.statushandlers.WorkbenchErrorHandler.access$0(WorkbenchErrorHandler.java:94)
at org.eclipse.ui.statushandlers.WorkbenchErrorHandler$2.run(WorkbenchErrorHandler.java:69)
at org.eclipse.swt.widgets.Display.msgFilterProc(Display.java:3477)
!SESSION 2015-01-16 17:18:57.266 -----------------------------------------------
!ENTRY org.eclipse.core.resources 2 10035 2015-01-16 17:19:00.445
!ENTRY org.eclipse.osgi 4 0 2015-01-16 17:19:02.673
!STACK 1
... 17 more
!ENTRY org.eclipse.ui.workbench 4 2 2015-01-16 17:19:03.234
!STACK 0
at org.eclipse.equinox.internal.p2.core.helpers.ServiceHelper.getService(ServiceHelper.java:74)
at org.eclipse.equinox.internal.p2.engine.SimpleProfileRegistry.updateRoamingProfile(SimpleProfileRegistry.java:156)
at org.eclipse.equinox.internal.p2.engine.SimpleProfileRegistry.updateSelfProfile(SimpleProfileRegistry.java:147)
at org.eclipse.equinox.internal.p2.engine.SimpleProfileRegistry.getProfileMap(SimpleProfileRegistry.java:344)
at org.eclipse.equinox.internal.p2.engine.SimpleProfileRegistry.internalGetProfile(SimpleProfileRegistry.java:248)
at org.eclipse.equinox.internal.p2.engine.SimpleProfileRegistry.getProfile(SimpleProfileRegistry.java:178)
at org.eclipse.equinox.internal.p2.ui.sdk.scheduler.AutomaticUpdateScheduler.earlyStartup(AutomaticUpdateScheduler.java:88)
!ENTRY org.eclipse.core.jobs 4 2 2015-01-16 17:19:03.234
!STACK 0
at org.eclipse.core.internal.runtime.InternalPlatform.getLog(InternalPlatform.java:354)
at org.eclipse.core.runtime.Plugin.getLog(Plugin.java:291)
at org.eclipse.ui.internal.WorkbenchPlugin.log(WorkbenchPlugin.java:818)
at org.eclipse.ui.internal.EarlyStartupRunnable.handleException(EarlyStartupRunnable.java:81)
at org.eclipse.core.runtime.SafeRunner.handleException(SafeRunner.java:75)
at org.eclipse.core.runtime.SafeRunner.run(SafeRunner.java:44)
!ENTRY org.eclipse.core.jobs 2 2 2015-01-16 17:19:03.265
!ENTRY org.eclipse.core.jobs 2 2 2015-01-16 17:19:03.281
!SESSION 2015-01-16 17:23:21.249 -----------------------------------------------
!ENTRY org.eclipse.core.resources 2 10035 2015-01-16 17:23:24.805
!ENTRY org.eclipse.osgi 4 0 2015-01-16 17:23:27.384
!STACK 1
... 17 more
!ENTRY org.eclipse.ui.workbench 4 2 2015-01-16 17:23:27.734
!STACK 0
!ENTRY org.eclipse.core.jobs 4 2 2015-01-16 17:23:27.744
!STACK 0
!ENTRY org.eclipse.core.jobs 2 2 2015-01-16 17:23:27.874
!ENTRY org.eclipse.core.jobs 2 2 2015-01-16 17:23:27.884
!ENTRY org.eclipse.core.jobs 2 2 2015-01-16 17:23:27.894
