I'm writing an application for TIVA using CCS 5.5.0
Is it possible to create a JAV or SVF images using this version ?
We have a generic JTAG burner which supports only those types.
Z.V
Zvi Vered said:Is it possible to create a JAV or SVF images using this version ?
The default output type generated by CCS for TIVA devices is ELF, which is a standard format generated by many compilers in the industry. If you require a specific format for your JTAG burner, you would need to find a converter that can convert the ELF executable into the desired format.
